Can-Am Plus motor brackets by Nobu Hanada
8 replies to this topic
#1 usadar
usadar
  • 1,144 posts
Posted 19 August 2014 - 09:19 PM
I have just received the proto-type motor-brackets (1 inch wide & 3/4 inch wide) for Can-Am Plus from Nobu Hanada.
Their detailed dimensions of Hanada Can-Am Plus motor brackets (prototype) are shown in the following draft:
Made of 1.2mm (.047 inch) thick brass.
All the numbers are in Metric (mm).
1 inch equals 25.4mm
The holes for endbell metal bearings (6 mm dia.) and motor screws (2mm dia.) are slightly bigger to adjust the positioning of motor shaft against rear axle.
With .750" rear tires, the rear clearance would be around .060 to .068 inch.
Your feedback is most welcome.
Good racing,
Haruki
Haruki Kan
Retro Tokyo
Retro Tokyo
Retro Tokyo on Facebook
#2 Mark Wampler
Mark Wampler
  • 7,007 posts
Posted 20 August 2014 - 12:43 AM
Very interested in seeing the finished product!
You can quote me.
-Mark
#3 ejgehrken
ejgehrken
  • 338 posts
Posted 20 August 2014 - 11:51 AM
I would recommend raising the axle holes so a 27 or 28 tooth crown gear is flush with the bottom of the bracket. The current configuration is raising the mass of the motor and motor bracket 0.020" higher than it needs to be.
  • Half Fast likes this
Eric Gehrken
Gehrken Retro Chassis
2015-16 Retro East Overall Champion
2015-16 Retro East Constructor's Champion
2013-14 New England Retro Racing Overall Champion
#4 usadar
usadar
  • 1,144 posts
Posted 24 August 2014 - 09:40 PM
Erick,
After discussing with Nobu & Kamo, we have decided to raise a center of axle hole from 7.8 mm of the proto-type to 8.2 mm for the final production.
It will be raised by 0.4 mm(0.0157 inch).
With .750 inch dia rear tires, the rear clearance is .052 inch.
Parma 26T crowns have 16.3 mm dia, so they are placed within the new motor-racket.
If you use Parma 27T crowns, their dia is 17 mm (0.67 inch), the crowns come outside below the bracket by 0.6 mm(.0118 inch).
So the rear clearance becomes from the bottom of the crown to the racing surface.
In order to clear the .047 minimum rear clearance, rear tire must be bigger than .7633 inch.
In this case, the clearance of the rear motor-bracket from the racing surface is .0587 inch.
Haruki :good:  :dash2:
Haruki Kan
Retro Tokyo
Retro Tokyo
#5 bbr
bbr
  • 1,365 posts
Posted 24 August 2014 - 11:09 PM
From my testing of an CA+, you can run these cars light, the RP bodies gives so much downforce, the car has a lot of grip.
Can you lighten the motor bracket with holes in the legs, with 1.2mm brass; the bracket will still be strong.
Mike Low
#6 usadar
usadar
  • 1,144 posts
Posted 25 August 2014 - 07:01 PM
Mike,
This is what Kamo has done to reduce the weight of the motor-bracket: cutting & shaveing off some metal from the upper part & bracing with a piano wire to which the motor is to be soldered.
Haruki
  • John Miller and kvanpelt like this
Haruki Kan
Retro Tokyo
Retro Tokyo
#7 NSwanberg
NSwanberg
  • 1,035 posts
Posted 25 August 2014 - 09:31 PM
Wow! Six bends on that brace. I still try and build with one bend to a wire.
Remember the Steube bar!
SUPPORT YOUR LOCAL RACEWAY!!
Nelson Swanberg
#8 bbr
bbr
  • 1,365 posts
Posted 25 August 2014 - 10:14 PM
I like the slotted motor screw holes. The PS/FK can is a taller than the sealed FK can
Mike Low
#9 usadar
usadar
  • 1,144 posts
Posted 16 August 2015 - 12:12 AM
I made a big mistake. Nothing is allowed to exceed the bottom surface of the chassis, so when you use 27T you should grind it down by 0.6 mm in diameter.
Haruki Kan
Retro Tokyo
Retro Tokyo
