Pinion pullers and press
8 replies to this topic
#1 Jeff Fischl
Jeff Fischl
  • 31 posts
Posted 27 September 2014 - 09:15 PM
Was wondering what is a good puller and press to buy. I have both 1/24 &1/32 scale cars. Hudy seems to be the most versatile but a little price , don't mind if it's worth it.
Thanks,
Jeff
#2 Tom Thumb Hobbies
Tom Thumb Hobbies
  • 3,198 posts
Posted 27 September 2014 - 09:20 PM
They're worth it!
Mike McMasters
460 Wilson Rd
Columbus, OH 43204
(614) 274-5150
Home of the ORIGINAL American blue King
#3 stemmy
stemmy
  • 1,029 posts
Posted 28 September 2014 - 07:38 PM
I use a Lucky Bob's press. The Hudy is a good puller but the Parma works well also.
Blair Stem
#4 Tom Thumb Hobbies
Tom Thumb Hobbies
  • 3,198 posts
Posted 28 September 2014 - 09:46 PM
All true. But what you get for the higher price is the only press that will press beyond the end of the shaft and a puller that will pull gears closer to the bushing/bearing than any other and one made from harder steel so the pin doesn't mushroom and stick in the pinion.
Mike McMasters
460 Wilson Rd
Columbus, OH 43204
(614) 274-5150
#5 macman
macman
  • 1,108 posts
Posted 20 October 2014 - 03:35 PM
When I do use a press on gear, (which is VERY rarely, ) I use a pair of medium (10 - 12") channel locks.
Ben Kernan
Formerly of SARN
Yes, I am a sarcastic, smart-azz, know-it-all old bastard of a genius.
What is old is new again... Retro... Gotta love it !!!
"May all your inlines be Retro, my son."
The Englelman: a truly superior design.
#6 Ramcatlarry
  • 2,182 posts
Posted 20 October 2014 - 04:07 PM
All steel pinions should be soldered on and off....then will never damage any pinion.   Brass pinions stretch and are fine to press on/off.
  • macman likes this
Host 2006 ISRA/USA Nats
#7 Dennis David
Dennis David
  • 3,381 posts
Posted 20 October 2014 - 07:38 PM
I just broke a JK will get a Hudy puller next time.
Dennis David
#8 SlowBeas
SlowBeas
    Troublesome De-slotter
  • 901 posts
Posted 20 October 2014 - 08:39 PM
I find that most presses won't fit the motor shafts I need to place the pinion onto. Most times, I just use a bench vise with a countersink hole drilled into a piece of aluminum. Place the pinion in the hole, fit the shaft into the pinion, and crank the vise slowly and gently.
Maybe not the best-engineered solution, but it works.
Does anyone make a longer pinion press to avoid such ingenuity?
Jim Beasley
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
#9 Bill from NH
  • 9,823 posts
Posted 20 October 2014 - 08:44 PM
Some of the pullers, presses, & other hand tools sold under the JK label were made by Hudy. :roflmao:
Parma did, maybe still does, sell a pinion press made from a modified C-clamp. I saw them regularily on ebay, but I don't know what they fit. I stopped using press-on pinions about 15 yrs. ago, but if I do come across a press-on pinion, I ream it out to 2mm & solder it on.
  • macman likes this
