Sometimes I ask myself, "Do (sane) people know what goes into bringing back an old motor?" Then I answer myself, "of course they don't!".
Here's a nice Mura, that's all Mura (well, there's a bit of Champion endbell hardware in there if you check out the bussbars... but not at all inappropriate).
The armature was made up from reclaimed Mura .007" lams pressed onto a new shaft and topped off with a reclaimed Mura commutator and then wound with #28 wire. There's more work in just getting the parts off old motors, cleaning them up, and making a motor out of them here than say four "regular" vintage builds. Those .007" lams are pretty fragile and pressing them into a nice stack to be powder-coated is a whole different thing than using nice new .014" lams.
"Unwelding" the comm tabs and then pressing the comm off it's old shaft is no picnic either!
Then there's the winding itself... not a lot of real estate in there compared to modern lams, or even compared to old Mabuchi lams for that matter.
Then again, there IS the "payoff", because you wind up with a classic motor that will run just like it would have when new... maybe better!
