How do you set motor spring tension?
Posted 28 December 2014 - 06:26 PM
I once read an article that said too low a spring tension and the brushes don't scrape away enough of the copper oxide that is formed by the arcing process. Too high a spring tension and you scrape away too much of the oxide layer. Just right and the amount of oxide formed is the same as the amount that is scraped away. Since copper oxide has a lot lower coefficient of friction the article said that a very thin layer (nanometers) was a good thing.
So how do people set their spring tension?
Rick Smith
Posted 28 December 2014 - 08:43 PM
I use a "Thorp Fiddlestick", the original to the Sonic versions, to set both springs at the same tension
- Steve Boggs likes this
Posted 28 December 2014 - 10:11 PM
I'm assuming you get the tension the same with the Fiddlestick but how much tension do you run in the first place? Given that the positive and negative brushes behave very differently with respect to electron flow I'm not convinced that you need the same tension on both.
Hence I'm wanting to play around with the tensions, so a Fiddlestick would be good.
Rick Smith
Posted 29 December 2014 - 08:23 AM
In brush-type Stock Class R/C motors, the "pros" insisted on specific tension and specific brush hardness on the positive and negative sides.
But, I haven't found many who agree on spring tension in slot car motors. Most agree that equal tension is desired, but accuracy is not paramount. Too little is bad and too much is bad. But somewhere within a range works equally as well. Low tension for low current motors, higher tension for higher current motors. I run 3 fiddles for a Deathstar, and used to run 4.5 Fiddles for G7 motors.
Here's three iterations of the Fiddlestick:
Posted 29 December 2014 - 09:19 AM
Rick,
My Fiddlestick is nearly 45 years old. If Sonic, on the other side of the country, no longer makes these, eBay might be your best choice for getting one. If any shop still has new ones hanging on the wall, it'll be someplace like (PCH) in California. You could contact them: (805) 988-8044, (800) 258-7441 to see if they have any.
Guy, if one wanted to get anal with those Fiddle numbers, since Fiddlesticks' internal spring tensions vary, you can calibrate them using a gram scale. I've never had the need to do this.
Posted 29 December 2014 - 09:27 AM
But I have a newer one floating around somewhere. Hope I find it before I die. Otherwise it will be thrown in the dumpster with all my other "toy car junk".
Posted 29 December 2014 - 09:38 AM
Guy, if one wanted to get anal with those fiddle numbers, since fiddlesticks' internal spring tensions vary, you can calibrate them using a gram scale. I've never had the need to do this.
Surprisingly, these three Fiddlesticks measure within 1/10 fiddle of one another.
I saw an evilBay auction for an older brass Fidllestick go to over $70.
I saw that one, too. Think it was the silver barrel with brass ends like the one in the middle of the photo. I also saw one for $47. But others go for under $20, and HERE's one now. This auction failed to sell at $16. I suspect the reserve may be $20.
Posted 29 December 2014 - 10:21 AM
Never been done fiddled with it.
Posted 29 December 2014 - 10:34 AM
Posted 29 December 2014 - 04:12 PM
A question. For the guys that have set up their spring tension equally, have you noticed which brush wears more? I'm thinking the positive brush will? Can I get some feedback on this and I might have to take a consensus if the answers vary.
Rick Smith
Posted 29 December 2014 - 10:47 PM
Posted 30 December 2014 - 08:06 AM
Not sure whether that means I should try more or less spring tension on the positive side??
Rick Smith
Posted 30 December 2014 - 09:05 AM
Posted 30 December 2014 - 11:23 AM
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
#15
Posted 30 December 2014 - 03:41 PM
these work very well to make certain each spring is even....
I like it. I think I have a jig in the making with a slight improvement that gets rid of the fiddlestick altogether. Replace the vertical dowel closest to the spring post (in your jig) with a horizontal rod that presses onto a digital scale. The horizontal rod can run in some brass tubing and you cut the length of rod so that the spring sits as it would in the motor.
Are you onto it? I'll buy the first one off you....save me making it myself.
Rick Smith
