Source of screws to hold Retro Hawks to motor brackets
33 replies to this topic
#1 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 11 January 2015 - 03:30 PM
Almost hate to ask this, because my memory is just getting terrible. Back in 2009 when I was building Retros and trying to get people locally interested in racing before the track closed, I sourced some hex head metric cap screws to hold the Falcon VII/Retro Hawk motors to the brackets. I do not like soldering in these motors. I can change out a motor faster using the screws and have never had one come loose.
Since I've started building again, I am running out of screws. The JK screw is really too short to effectively hold in a motor on a .050" motor bracket though it works well with the thin JK bracket, and I prefer to have the screw  properly threaded for the can and not self-tapping like the Parma screw. I believe they are 2mm Metric x 4MM and use a 1.5MM hex wrench (Wiha driver). I honestly can't remember where I got them before, I think it may have been an R/C supply house. I know there are some used in the 1/32 cars, but nearly all of these are phillips head and won't do for what I want.
Anyone have a source or somewhere to get them from or a part number?
Thanks in advance... build on...
#2 Rick
Rick
  • Partial Member
  • 8,843 posts
Posted 11 January 2015 - 03:33 PM
McMaster-Carr...
  • Michael Rigsby likes this
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
#3 Jay Guard
  • 1,322 posts
Posted 11 January 2015 - 03:45 PM
Try Fastener Express, great prices and service.
Retro Racer &
Flat Track Fanatic
#4 stemmy
stemmy
  • 1,028 posts
Posted 11 January 2015 - 03:58 PM
Fastenal. .44 cents apiece
Blair Stem
#5 slotcarone
  • 3,361 posts
Posted 11 January 2015 - 08:44 PM
Don't use the metric screws as they don't hold in a crash. Use 2-56x1/8 screws. you can get them at Fastenal or from Slotcarstore.net for 4 for a buck there.
If you go to Fastenal don't get the stainless ones, get the black oxide coated as they last forever.
  • S.O. Watt likes this
#6 slotcarone
  • 3,361 posts
Posted 11 January 2015 - 09:22 PM
When you use the 2-56 screws you will have to open up the screw holes in the bracket a small amount. It is worth doing as they never strip out.
#7 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 11 January 2015 - 09:39 PM
Mike,
I've been using the black oxide hex head cap screws in these since 2009. Have not had a motor come loose yet. With the 4mm screw, it goes all the way through the can and uses all the threads. I guess I've been lucky so far.
For that matter, I know a lot of guys that use the Parma black oxide screw in these as well, it self-taps into the can, but to me it's not long enough to do a good job.
#8 Rick
Rick
  • Partial Member
  • 8,843 posts
Posted 11 January 2015 - 11:57 PM
Don't use the screws the motor was designed for? I used to screw my motors in and never had a failure either using the correct screws. Makes two of us that was lucky, I guess? 2mm X 4mm L works great and uses a 1.5 mm key. The FK motors are extremely strong and flat and work exceptionally well as designed.
McMaster-Car sells them for about $5/100, and stainless works just fine too, and they're purdy...
Rick Bennardo
scrgeo@comcast.net
R-Geo Products
#9 slotcarone
  • 3,361 posts
Posted 12 January 2015 - 08:31 AM
If you run the metric screw into the motor is goes right in but is a loose fit. You run the 2-56 screw in and there is a little resistance the first time but they fit snug and will stay that way. I have Puppy Dog motors that are six years old and have been installed over and over and have not seen one strip yet.
This is my experience on this and has always worked for me in eight years of Retro racing and I have never had a motor even loosen up. The 1/8 long screws work even in the .050" thick brackets.
Keep in mind these motors weren't originally designed to be in a slot car going full speed into a wall. I am sure the metric screws are fine in other applications using this motor design.
  • S.O. Watt and George Blaha like this
#10 John Streisguth
John Streisguth
    Johnny VW
  • 4,841 posts
Posted 12 January 2015 - 08:42 AM
My train of thought is to use the thread that is put into the metal, and use a tiny amount of purple Loctite. Easily removed, but it's just enough to keep them from vibrating loose.
With the Retro Hawk motors, I also have gotten out of the habit of switching motors around like I used to with the Puppy Dog motors, unless the motor is a real dog (no pun intended). I've just found that the RH motors don't seem to have as much variation track to track, so I haven't felt the need to chase motors.
FWIW...
"Whatever..."
#11 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 12 January 2015 - 09:12 AM
All good points and I see the reasoning in all of them and I appreciate all the input.
John's point is valid as I tend to break-in a motor and not keep yanking it out over and over as the RHs that I run are very, very consistent (so far about .05 to .07 seconds within one another), and even if I had a super motor, it's a heckuva lot easier to change it out using the screws versus soldering and overheating the can.
I have found the can material in the Retro Hawks to be much, much stronger than the steel used in any PS Euro motor, so I will stay with what has worked for me for over five years. The tiny drop of purple or light blue Loctite thread locker as John suggested is also a good idea. The small head of the socket head screws also helps if the motor bracket area near the bend of the motor bracket is a little off. It seats better than a larger head screw.
Just my opinions, so please don't take offense. If what you do works for you, I appreciate that. If Jerry's JK screw was 1mm longer, I wouldn't hesitate to use that, but it's just too short for the thicker brackets.
Since I am in dire need of a few screws now, I will stop at Fastenal this morning and pick up some then order a bag from McMaster-Carr as Rick suggested.  Besides, when you build for someone, they really like the idea of the ease of changing a motor using screws. Some folks are afraid of soldering anything and don't even own an iron.
#12 MG Brown
  • 5,780 posts
  • Location:The Land of Lincoln, where governors make the license plates.
Posted 12 January 2015 - 10:27 AM
IIRC, JK Products makes a nice stainless steel motor fastening screw. Part no. 3019.
"I'm just here for the entertainment." George Carlin
#13 Ramcatlarry
  • 2,079 posts
Posted 12 January 2015 - 11:14 AM
My preference is to use a standard motor screw wrench of 5/64" that has been on everyone's bench forever. I also chase the 'furin' metric threads with a 2-56 tap and use those nice McCarr SS screws. Straight and ball head tips in my drivers - and have never broken a tip or striped out a motor.
McMaster-Carr sells 2-56 screws in any length you could possibly need... for the same low price.
Host 2006 ISRA/USA
#14 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,009 posts
Posted 12 January 2015 - 12:01 PM
Does anyone have the McMaster-Carr part number for the metric screws?
Cheers,
  • George Blaha likes this
Faster then, wiser now.
#15 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 12 January 2015 - 12:23 PM
MG,
I have some of the JK screws and use them in the JK Retro brackets for builds. They are not, however, long enough for an .050" motor bracket. If you try to use them in an .050" bracket, they lack about .5mm going all the way into the threads on the can unless you countersink the heads, which is why I want the longer 3mm or 4mm screw. I'm going for strength and can stability here which means I need the longer screw.
And Fastenal in north Florida does not stock any small M2 screws at all. I checked three stores and they all said nada, "But we can order it", with me replying..."so can I".
#16 John Streisguth
John Streisguth
    Johnny VW
  • 4,841 posts
Posted 12 January 2015 - 04:00 PM
3 mm length  91290A010
4mm length 91290A011
"Whatever..."
#17 Half Fast
Half Fast
  • 2,009 posts
Posted 12 January 2015 - 06:39 PM
Thanks. John. You are the McMaster-Carr expert!
Cheers
#18 John Streisguth
John Streisguth
    Johnny VW
  • 4,841 posts
Posted 13 January 2015 - 06:58 AM
No problem... I place an order with them a couple times a week at work, so I have them on "speed dial". LOL.
I use the 3mm length on most brackets, even the .050" thickness. That still results in the screw thread going past the end of the inside of the can. The only time I use the 4mm length is with the Prof. Motor cast bracket. I find the 4mm will hit the magnets with the real thin brackets like the original JK. I figure that's probably not a good thing when a hard crash happens.
  • Half Fast and Michael Rigsby like this
"Whatever..."
#19 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 13 January 2015 - 08:18 AM
That's the numbers I ordered yesterday morning. Figured I would lay in a supply of both, and can give some out to any of the local racers that need them. The original screws I have measure about 3.31mm in length, so who knows if it corresponds to the 3mm or 4mm length. Still wish I could remember where I got them from. A Main Hobbies keeps popping into my mind, but they no longer catalog them so I can't be sure.
Thanks for posting those part numbers, John, as I didn't see Bill's post requesting the part number. I had to order some lathe bits from McMaster-Carr anyway, so it was a no-brainer to order from them, and they are close enough the order will be delivered by UPS today.
#20 John Streisguth
John Streisguth
    Johnny VW
  • 4,841 posts
Posted 13 January 2015 - 08:29 AM
I love McMaster-Carr. I very rarely don't find what I need, and 99 times out of 100 I have it the next day.
"Whatever..."
#21 usadar
usadar
  • 1,148 posts
Posted 22 January 2015 - 05:16 AM
Micro Fasteners
Try the above website.
Haruki Kan
Retro Tokyo
Retro Tokyo
Retro Tokyo on Facebook
#22 Greg VanPeenen
Greg VanPeenen
  • 1,007 posts
Posted 22 January 2015 - 01:53 PM
Love the Micro Fasteners button head machine screws. Got to order some of those.
Thanks for the link, Haruki.
GVP
  • usadar and George Blaha like this
#23 usadar
usadar
  • 1,148 posts
Posted 27 January 2015 - 04:19 AM
GVP
Greg,
I have been using Metric M2 x .4 x 3mm button head socket screws.
http://www.microfast...lloy-steel.html
Haruki
Haruki Kan
Retro Tokyo
Retro Tokyo
#24 Nate Graham
Nate Graham
  • 65 posts
Posted 03 March 2015 - 01:19 PM
Gentleman,
Thanks for the interesting discusson. I am a newcomer to slot car racing, but have a fair amount of experience with hobbies and building - Model warship combat and R/C cars. This sounds like a case of you - Mike and Rick - are both right. And the culprit is tolerances.
The motor is spec'ed as having M2 mount holes. The holes are out of spec - what a shock, a third world inexpensive toy part with out of tolerance something. Get a little wobble in the drill press drilling or tapping the hole and, voila, hole is a little loose. It happens that an English thread size is a tiny bit bigger and can give a good interference fit or the hole can be re-tapped for 2-56.
I live in Northwest Pennsylvania and am about to complete my first retro build. I think I will go with 2-56 and yes, I have a 2-56 tap in the shop just n case.
On a related note, why hasn't everyone changed to torx heads?  They are available at McMaster-Carr and would solve the bind and strip problems with these little screws?
Thanks,
Nate G
first post
#25 MSwiss
  • 19,977 posts
Posted 03 March 2015 - 01:40 PM
"Bind and strip problems"
I wasn't aware there was any.
