You sound like a new guy, but you tried a lot of material.
That suggests something else.
I suggest you set your sights on one paint type and figure out what works best for that media.
Forget Pactra because it's discontinued. Spider webs are because it's way too thick out of the bottle. Thin with good quality thinner and use only on Lexan till it's all gone.
Learn to use water based paints.
Yeah they scratch easy because you are not prepping the surface right. Try sanding the inside with course steel wool first. Clean thoroughly and then shoot light coats.
Will still scratch, but then so does lacquer so .... what of it?
Any surface that touches the chassis needs to be backed with strapping tape anyway.
Ok, and I've heard that some people use other lacquers under the water based, and that hardens it up, or they use faskoat. As for water based paints, I'm probably going to use faskolor because I can easily get it, and it's not very expensive for how much you get. As for being new, I am a relative newbie when it comes to painting, and I have only been doing slot cars since about last November.
I also did some painting of RC cars, and got a few bodies from the local raceway. I'm getting better, and I need to find something and stick to it!
and I am not good at cutting bodies (but that comes with practice. Lots and lots of practice).
Hi Sean
I went to a Mickey Harrson Air Brush class locally....... Mickey's trick is to say a zin montra wile painting .........
Less....is...more.......less...is...more......less...is...more........oooooooommmmmm........... ( Mick is a TRIP ..... Good painter )
This means less paint = more effect......you need to remind your self so the mantra .............
You can do nice work with any gear... even rattle can's....... just take your time & please your self...... you cant go wrong !!!!!
GAV
Another good montra is "I am in no rush" (now only if I could apply that to break out races
). I just need masks to get some basic designs, and unless I want to get really detailed, I would like to stick to solid tape.
Here are some of the bodies I've (tried) painting. I like the wing car, but it's getting the tape on that is the tricky part. As for the black car, I did the costs WAY too thick. If I want a dark color, I need to do multiple coats. With that said, my airbrush seems to be having a bit of a hard time getting the paint out...
