Harry Olds "Long John" 4WD drag car build
Posted 13 June 2015 - 03:05 PM
As I sat down to study just how I might do this and looking at how to mount up this dubble end bell drive motor I remember some old motor mounts I had so I dig them out and they fit perfectly.
I had some axel carriers but im not sure if ill be using them.
I do have an idea on how to build the chassisso I can remove the motor if needed.
- Tim Neja, havlicek and C. J. Bupgoo like this
Posted 13 June 2015 - 03:20 PM
- Jairus, slotbaker, MSwiss and 3 others like this
Posted 14 June 2015 - 12:42 PM
Hi Joe...I love the model you chose! Keep on a-buildin' !
- Joe Mig likes this
Posted 14 June 2015 - 02:28 PM
- havlicek likes this
Posted 14 June 2015 - 05:32 PM
Mig, if you need any odds and ends to complete the car, no charge, let me know.
Maybe I'll meet you at Slots for a Hairy Olds showdown with my car when you are done.
I am sure you will have a large weight advantage on me.
Here are a couple construction pics. You can see how I retained the model interior by building a false floor.
- Joe Mig, havlicek, boxerdog and 1 other like this
Joe Lupo
Posted 14 June 2015 - 07:27 PM
Very cool car Joe!
With such unusual cars, I think it's about way more than *just* sheer performance (although 2 Kemtrons ought to provide a LOT of torque!). I think it has a lot to do with elegance and engineering "period" solutions, and yours has plenty of both. That's why I'm very interested in all this and to see what Joe Mig comes up with.
Posted 14 June 2015 - 08:10 PM
Thanks John. A lot of work went into the car including making a "front" motor mount and getting the guide to work. The body was a soggy mess that my Godson rescued from the dump!
I sent it to the proxy drags but it didn't perform as I expected. it only made two runs there and I never had any tuning time on it.
I want to maybe zap the motors and fool with the gearing a little to see what happens.
If all else fails I know this guy here on Long Island that rewinds arms
Joe Lupo
Posted 14 June 2015 - 08:56 PM
Nice build Joe get that bad boy redy to do some heads up racing.
I guess the Hairy olds did a number to most of us seing the builds and intrest.
Posted 15 June 2015 - 09:33 AM
Neat project Joseph!
Since Drag cars don't require the normal weight placement, I would push that monster motor as far forward as possible and use an extension shaft at the rear. That way you might be able to get away without using wheelie bars. ( I think they ruin the scale aspect of these builds)
Also, since the car doesn't go around corners, maybe try moving that guide back behind the front bumper.
I have been thinking about building a drag car myself. Even built one stock just so I could "bench race" other ideas.
As for a two-motor Hurst Hairy Olds.... I got one started myself too!
Well, it's not duel motored yet. The idea was to write an article about modifying the newer AMT chassis with a 1966 Olds body mounted on top.
First stage is finish the body and race the stock chassis with an average drag race time.
Then start modifying until ultimately two chassis are soldered together to provide two motor brackets.
Building this Hairy Olds as the early 1966 car by the way.
Posted 15 June 2015 - 09:53 AM
What a nice thread.
So hard a judge they hope never to meet as themselves.
Posted 15 June 2015 - 09:55 AM
Joe L. ... your car is very nicely built and performed perfectly fine, no bad habits it just was slow.
IMO ... It's geared much too high (numerically) for the power band .. bigger pinion/smaller crown and your done.
If you look at the timeslips you got back with the car check the incremental. You were killing me at the 60ft and then had no 'steam' at the other end.
Joe Mig, ... about the 'Show and Tell' drift.
For reference not sure you saw it ... here is that car you don't want to take but I said run for pink slips .. LOL
Posted 15 June 2015 - 12:31 PM
[/quote]
Thats what i have in mind and did some mock up using the motor mount from a sprint car chassis up in front.
putting the weight up front and a drive shaft to a rear motot mount.
Nice build by the way and I think most of us building this car feel the same about no wheelbars.
Now all I need is one of those littli Linder V.
- Gator Bob likes this
Posted 16 June 2015 - 01:20 PM
its not your standard build so it takes some extra time thinking and fabricating things like the motor mount and how to build so you could remove the motor if needed.
- C. J. Bupgoo likes this
Posted 16 June 2015 - 01:23 PM
with a shaft to mimic an armature and make sure there is no bind.
this is where I left off and needed a little break.
#15
Posted 18 June 2015 - 01:51 PM
Nice build Joe
#16
Posted 21 June 2015 - 11:43 AM
motor mounts complete and this way I will be able to remove it if needed.
Next uo what to do for the guide flag.
i think ill do a drop arm.
- hiline2 and SlotStox#53 like this
#17
Posted 21 June 2015 - 01:00 PM
#18
Posted 21 June 2015 - 04:25 PM
got to work on a drive shaft next.
- Jairus, slotbaker, hiline2 and 1 other like this
#19
Posted 23 June 2015 - 08:21 PM
- slotbaker and C. J. Bupgoo like this
#20
Posted 24 June 2015 - 06:48 AM
how fast do you think this no wheelie bar car will cover the 1/4 mile track?
#21
Posted 24 June 2015 - 09:54 AM
eh, fast ?
#22
Posted 24 June 2015 - 08:45 PM
Depends on the output of that double ended motor and gearing, waiting to see myself!!
#23
Posted 24 June 2015 - 09:00 PM
swag method - 1.85
Charlie McCullough
Charlie's Speed Shop
Kelly Racing Wanna Be
#24
Posted 24 June 2015 - 10:40 PM
#25
Posted 25 June 2015 - 08:48 AM
I like Charlie's 1.85 if you are talking about the 1000' track. Maybe 2.0 on 55 feet???
