Inline gear mesh issues - help!
21 replies to this topic
#1 Joexemm
Joexemm
  • 156 posts
Posted 14 July 2015 - 11:22 AM
Since I started racing the H&R chassis one thing I have not yet figured out is how to quiet down the gear mesh. I tried the lighter method and that's not producing results. I leveled the motor shaft with the axele, new gear both steel and brass on the pinion. I can't get that screaming noise out of it.
Other cars are really quiet so I'm losing speed to friction and I hate losing speed to friction...
Joseph Emm
"Success is the best Revenge".... - someone smart.
C.O.W. retro chassis Everyone that runs one knows Checkers or Wreckers
#2 MSwiss
  • 20,460 posts
Posted 14 July 2015 - 11:36 AM
Use an ARP angled pinion, with a Parma pink crown, if you already aren't.
  • Joe Mig likes this
#3 Joexemm
Joexemm
  • 156 posts
Posted 14 July 2015 - 11:45 AM
Okay I'll have to pick up an angled pinion; right now I have all straight cut. Thanks for the tip.
Is there a particular angle I should look for with the motor or just level the shaft with the axle like I have been?
Joseph Emm
#4 Noose
Noose
  • 21,432 posts
Posted 14 July 2015 - 11:50 AM
You can also check this article out
How To Set A Gear Mesh
#5 MSwiss
  • 20,460 posts
Posted 14 July 2015 - 11:51 AM
ARP only sells one type of 48p angled pinion.
Yes, motor shaft alignment with the axle will always help.
Also, make sure you a little side play (approx. .005") in the back end, but not too much.
Also, make sure you can feel a tiny bit of lash.
#6 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 1,711 posts
Posted 14 July 2015 - 02:09 PM
Burn the mesh in as well.
Matt Sheldon
#7 Tex
  • 8,988 posts
Posted 14 July 2015 - 02:19 PM
If you have the armature shaft and the rear axle on the same plane, an angled pinion isn't necessary (it'll work fine, just not necessary). Beyond that, the two points above that Mike makes are crucial; setting a gear mesh too tight will sure screw you up and cause that "screaming" noise.
#8 Cheater
  • 23,308 posts
Posted 14 July 2015 - 02:37 PM
I've never had an H&R chassis in my hand, so maybe this is a dumb suggestion, but are the axle bushings solidly attached to the chassis?
#9 kvanpelt
kvanpelt
  • 1,096 posts
Posted 14 July 2015 - 02:45 PM
Are you sure both gears are 48 pitch?
  • Tex likes this
#10 Joexemm
Joexemm
  • 156 posts
Posted 14 July 2015 - 02:53 PM
100% sure both are 48p. Might not be the same brand.
Soldered in bushings jigged so the axle is square to the car and level. I'm going to try a angled pinion next when I get to the track again. Otherwise to my knowledge I have (from my experience with angle winder 48p) the right lash and the right side play. Just a little and no binding.
Finished product. I hope the noise is gone on track. The rear is braced.
Joseph Emm
#11 Cheater
  • 23,308 posts
Posted 14 July 2015 - 03:11 PM
Joe,
Try this...
Hold the chassis in one hand and with the other hand try to push the motor sideways gently, applying pressure on the end of the motor where the wires attach. Don't go crazy with force; you're not wanting to break it off the chassis.
It shouldn't move at all and should feel quite solid. If the motor moves at all sideways under anything less than a significant amount of force, that can cause the gear mesh issues you're having.
My thinking is that if you don't have problems with gear mesh on other cars, it's unlikely that it is simply an adjustment issue but rather that something is moving and/or flexing.
#12 Joexemm
Joexemm
  • 156 posts
Posted 14 July 2015 - 03:20 PM
Cheater,
yeah its pretty solid i gave it a pretty good shove just now and nothing moved around.
im wondering if the gears im using are just cheap. they all have a pretty obvious wear spot in them and i tossed a few out cause they are practically grooved. all press fit gears as well. Thanks for all the input guys!
Joseph Emm
#13 Paul5097
Paul5097
  • 265 posts
Posted 14 July 2015 - 03:36 PM
From your picture it looks like the motor shaft is directly in line with the axle, so a straight pinion should work fine. However, you need to toss the press on pinion and go to a solder on pinion, either straight or angled. The press on fit pinions almost always deform when you are pressing them on the motor shaft and can cause noise and friction.
Paul Murr
#14 Gator Bob
  • 13,350 posts
Posted 14 July 2015 - 03:37 PM
'Look at me when I'm talkin' to ya boy'    :laugh2:
You're doing great, learning this stuff. and ...what everyone said.
Did you make sure the car is square and solder it all on a jig?
Pitch - is a standard but there can be variance in quality of maintaining that standard. ARP steel angled or MSwiss for the 'super' press-on pinions if you have to have straight and don't want to solder or 'glue' them on.
Caveat : I don't know about setting up H&R chassis cars.
#15 John Streisguth
John Streisguth
    Johnny VW
  • 4,893 posts
Posted 14 July 2015 - 03:38 PM
Whatever you do, DON'T use brass pinions (or chrome plated brass ones). They wear out quickly, and as they wear out they screw up the teeth on the crown gear. You may have to start fresh with new crowns and good steel ARP tapered pinions.
At the track that used to be local to me there was a group running the races, and one of the rules was you had to use the stock pinion, saying it simplified things for beginners.  Well, if they allowed upgrading to the steel angled pinions, they would last ten times longer, so what's REALLy better for beginners? :dash2:
"Whatever..."
#16 Joexemm
Joexemm
  • 156 posts
Posted 14 July 2015 - 04:00 PM
Here is what I'm taking from this.
a). Throw out all your gears cause the press-on ones are bent. (I should have thought of that myself... helloooo.)
b) Buy the good gears.
c) I'm doing one thing right... asking questions as this is not my forte!
Joseph Emm
#17 Gator Bob
  • 13,350 posts
Posted 14 July 2015 - 04:16 PM
You're asking the right questions, too.
#18 Matt Sheldon
Matt Sheldon
  • 1,711 posts
Posted 14 July 2015 - 07:56 PM
Nothing wrong with the Parma crown gears. Sure they may be a little out of true, but so are the majority of the others. They are made of a softer material and in general are quieter.
Put on an ARP angled pinion, set it, and forget it.
Matt Sheldon
#19 slotcarone
  • 3,414 posts
Posted 14 July 2015 - 08:38 PM
Doesn't matter if you use an angled or straight pinion but it has to be a quality one that you solder on.
#20 Bill from NH
  • 9,707 posts
Posted 14 July 2015 - 09:53 PM
Joe,
Like most others here, I prefer to use solder-on pinions. However, if you want to use press-ons, look into the Sonic SS pinions. I think the 48 pitch starts at 7t. 15-20 years ago, I and my two kids used these pinions extensively, mostly in flexi programs. They last a lot longer than brass gears.
I don't own an H&R chassis, but I've driven a couple of them on a club track. They make sweet-handling hard body cars, much better, in my opinion, than an FCR. :)
#21 James Wendel
James Wendel
  • 817 posts
Posted 14 July 2015 - 11:36 PM
I have gone to Loctite red rather than solder. It's so much easier, and I haven't had a failure yet.
#22 Randy Tragni
Randy Tragni
  • 382 posts
Posted 15 July 2015 - 09:30 AM
One thing I haven't seen come up is run in. Once you have all the right stuff incorporated there is nothing left except to break in the gears. The flame/soldering iron thing does help but sometimes certain gears can be stubborn.
You can use a lapping compound (various types available, I use Simichrome) to run the gears in. It takes a long time (maybe ten hours) and can wear out a good motor (so maybe use a dog motor). Apply compound, place in your favorite break-in box and run everything at 5 volts. Be aware of the motor sound (i.e. frequency and pitch amplitude). Add more compound occasionally and run until the gears sound smooth. Afterwards clean all of the compound off your gears and anywhere else it may have migrated to.
