Heatshrink for leadwire - help!
49 replies to this topic
#1 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 14 September 2015 - 08:58 AM
Broke a wire twice this past weekend, cost me a podium... I want some leadwire shrinkwrap!
I looked around and found 1/8" in 2:1 and 3:1 shrink... some had glue lining, too??
What size and kind of heat shrink do you guys use?
Charlie McCullough
Charlie's Speed Shop
JK Hawk Horsepower Specialist
Bartos Chassis  CHR Cars
Outisight Bodies
Mossetti Racing
#2 Michael Rigsby
Michael Rigsby
    SRT Motorsports
  • 1,914 posts
Posted 14 September 2015 - 09:15 AM
What are you using for leadwire, Charlie?
Usually before any big race I'll change out the leadwire just to be sure. That and I use either 18ga TQ leadwire or 18ga R/C wire. I dont think I've ever broken a leadwire in a race, but I've split a lot of leadwire clips in collisions.
As far as shrinkwrap, I have some I got from Del City electrical supply that I use. Covers down to 1/16" of an inch and just will go over 18ga leadwire.
#3 brnursebmt
brnursebmt
  • 660 posts
Posted 14 September 2015 - 09:35 AM
Charlie,
If you're using Kelly wire it's a dangerous thing! DZ and John Martin have found out how to use it. It requires some glue on the guide clips. The risk is not worth it to me!
Bobby Robinson RN
#4 tonyp
  • 14,265 posts
Posted 14 September 2015 - 11:02 AM
Ditto. You have to strip the wire short. Solder it all the way towards the front of the clip. The jacket that sits on the clip you have to glue to the clip. That will keep it from bending at the solder joint and breaking.
  • Cheater, Tim Neja, John C Martin and 1 other like this
1965 "Evil Bucks Racer" Team
Revtech Team Trinity
Retro East co-founder
First IM Nationals Champion
Arco Champion
ip
#5 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 14 September 2015 - 11:25 AM
No Kelly wire - yet...
NASCAR oval - wire broke due to rear ending someone in my way, took a perfect 1 mm high guide width chunk off the front edge of Kelly Daytona body. Also got a cut braid later on with someone in my way, Parma cut-down held up! Then broke same wire again w 12 seconds left, solder joint came unbuttoned - repair under green by rookie was not good enough. Would of, should of, could of... I won't ever forget to use paste flux and tin wire before trying to hurry a solder joint in a race...
My slot car laboratory still needs shrinkwrap - what size, and kind of shrink tubing?
Charlie McCullough
Outisight Bodies
Mossetti Racing
#6 Cheater
  • 23,459 posts
Posted 14 September 2015 - 11:34 AM
Charlie,
If less than $13 plus a little shipping doesn't scare you off, consider this assortment from Del City. You'll never have to buy any more and I'll bet you'll find lots of other uses for it besides slot cars.
I bought a similar though smaller assortment many years ago and still grab a chunk for things every so often.
Thin wall heat shrink assortment
#7 brnursebmt
brnursebmt
  • 660 posts
Posted 14 September 2015 - 11:37 AM
Oh! When oval racing at Heart of Dixie... all bets are off!!!
Bobby Robinson RN
#8 Hworth08
Hworth08
  • 3,563 posts
Posted 14 September 2015 - 11:48 AM
Radio Shack has a small assortment for a small price if I recall correctly.
Don Hollingsworth
11/6/54-2/13/18
#9 Cheater
  • 23,459 posts
Posted 14 September 2015 - 11:52 AM
Yeah, if you can find a Radio Shack that's still open... most of the ones near me have shuttered.
#10 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 14 September 2015 - 11:59 AM
What I do, Charlie, works great, saves ~2 grams, and is stiffer than most all leadwire setups but not too stiff. I've used it for years now.
Kelly leadwire 24 gauge... I solder the wire the most forward on the clip... I use about 1" of shrink wrap. It's 1/16" diameter bought at most any electronic store in 3' lengths $2.
I cut the diameter In half about 1/4" inch back, see pic.
I smear that 1" of leadwire at the end with a two-part epoxy. Then slide the shrink wrap with the half cut diameter end over the soldered joint all the way forward on the clip. Then I add a small dot of the epoxy to the soldered joint and mash it down until the epoxy sets up, and a smaller dot to the top of the shrinkwrap to hold it even more.
Then a hair dryer will work to shrink the wrap.
#11 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 14 September 2015 - 01:19 PM
Two grams - what? Heck ya - danger is worth it! For all the times I de-slot, I gotta be able to catch up. Hahahahaha
Many thanks for the lessons - you guys are a big reason my cars are fast.  :ph34r:  :tease:
Charlie McCullough
Outisight Bodies
Mossetti Racing
#12 Cheater
  • 23,459 posts
Posted 14 September 2015 - 01:29 PM
Who you blaming for your lousy driving? LOL...
#13 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 14 September 2015 - 01:40 PM
Hey, Cheater - send me that drivers manual since you don't need it anymore. LOL.
I need more lap time - forced to work, eat, and sleep... the tide has started to come in.
Charlie McCullough
Outisight Bodies
Mossetti Racing
#14 Dale B.
Dale B.
  • 1,698 posts
Posted 14 September 2015 - 04:11 PM
Harbor Freight has a small variety pack of shrink wrap if you have a store nearby.
Vintage Cox Slot Cars
#15 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 28 September 2015 - 11:45 AM
2 down, 14 to go - how is this before I continue?
  • John C Martin and Shooter7mustang like this
Charlie McCullough
Outisight Bodies
Mossetti Racing
#16 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 28 September 2015 - 01:49 PM
It's a lot nicer than my epoxy job .did you put a small amount on top of the clip and tubing, It's needed. Also I put end that runs to the clip on top of loop ,not under and a little bigger loop also ..they look really great and will give a much faster return to center ,helping get rid of any fishtail exiting corners..IMO.less drift in the curves.. Not to mention weight reduction ..
#17 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 28 September 2015 - 02:52 PM
Thanks JC for this excellent training :good: ...yes, epoxied both inside the shrink tubing, and a drop on end so that the wire insulation just behind the solder joint is stuck to the clip, then the shrink covers it.  And now with wire to clip on top, the loop doesn't hit the sharp edge of the chassis where the wires run through.  Rookie Tip: use a very small amount of epoxy before sliding the shrink tubing down toward the clip, or you could epoxy the clip to the guide. :crazy:
  • John C Martin likes this
Charlie McCullough
Outisight Bodies
Mossetti Racing
#18 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 30 September 2015 - 01:59 PM
Charlie epoxying the clip is not really that bad. It adds some strength.Even letting some get a little coverage on that thin outside edge of the guide next to the clip will strengthen that part as well. I added @ .50 thou to the outside edges from clip down to bottom of that weak portion.,( camera can't show it well.)Helping to maybe prevent it splitting.
AND
#19 Cap Henry
Cap Henry
    CHR Cars
  • 2,804 posts
Posted 30 September 2015 - 03:24 PM
You're worried about 2 grams of weight in the leadwires, but have that big ol' chunk of lead on the closest pan? Killin me John LOL
  • S.O. Watt, Matt Sheldon and John C Martin like this
Team PSC
Parma PSE
CHR Cars
JDR-Joe Dirt Racing
#20 tonyp
  • 14,265 posts
Posted 30 September 2015 - 04:06 PM
Lol.
Arco Champion
ip
#21 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 30 September 2015 - 05:19 PM
Tempted to hog out the pan holes on my dragonslayer 6.  109 grams before going on a diet.  That is ok in the rules?  Seat belts coming soon!
Charlie McCullough
Outisight Bodies
Mossetti Racing
#22 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 01 October 2015 - 12:09 PM
That's lead tape LOL.
Tony P. Knows..LOL.
IMO thus far any lead wire larger dia. Than the armature wire is overkill..especially with so little amp. Draw.
Seems the bigger hate of the small wire is to keep it from breaking on the guide..I now got that covered ,,with a much better (quicker ) return to center on the guide ,= a tighter car..no wiggles off the corners..Oh yeah 2 grams less.. With Lead tape ..LOL
#23 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 01 October 2015 - 12:29 PM
]Hog out all you want,,just be aware some tracks need more weight ..DZ cuts out everything then tunes with lead to different tracks as needed....works for him ...right. LOL
I'm trying to run a shorter car 3.75 . Shorter body ,=. 103 grams..I shortened this Arrow chassis. 1/4" off rear of pans .Then moved bracket forward 1/4" ..and cut the excess metals off the back ..It works great on the 3 tracks I've tryed it on. Love it..
  • Danny Zona likes this
#24 Cap Henry
Cap Henry
    CHR Cars
  • 2,804 posts
Posted 01 October 2015 - 01:09 PM
Whatever works for you LOL Im spoiled not needing super light cars in Ohio LOL
Team PSC
Parma PSE
CHR Cars
JDR-Joe Dirt Racing
#25 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 01 October 2015 - 01:38 PM
Heavy cars at "The Track " in Whitehouse Tn. Don't get on the podium. LOL.
Yet
