Hudy tire truer abrasive wheel
8 replies to this topic
#1 SlowBeas
SlowBeas
    Troublesome De-slotter
  • 901 posts
Posted 14 September 2015 - 12:02 PM
This might be a stooopid question, but I have to ask anyway.
Is my only option to replace the entire wheel when the abrasive wears down? Seems like such a waste of otherwise good materials when all that's needed is new sandpaper.
Jim Beasley
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
#2 John Streisguth
John Streisguth
    Johnny VW
  • 4,895 posts
Posted 14 September 2015 - 12:07 PM
Get the diamond coated one. More expensive but should last much longer than the standard one.
One of these days I may play around with the standard one I took off....maybe when I retire in 5 years  LOL
  • fohoover likes this
"Whatever..."
#3 Pablo
  • 14,106 posts
Posted 14 September 2015 - 12:28 PM
Good question, Jim. I've wondered the same. The answer is, with a Hudy, yes that is the only "right" option.
Mike Swiss has sold truers from time to time that utilize inexpensive easily-replaceable sanding arbors available at hardware stores.
Wish I had one.
You could try gluing your own sandpaper to the wheel, I've been tempted to try it myself. But fear stops me.  :)
If it flings off it could be bad.
Also your Knob Job would need re-calibration...
#4 PCH Parts Express
PCH Parts Express
  • 2,130 posts
Posted 14 September 2015 - 12:36 PM
Standard Hudy drum #3040
Optional diamond drum
Re-coating the worn-out drum would not be cost effective.
Scott Salzberg
PCH Parts Express
#5 Cheater
  • 23,373 posts
Posted 14 September 2015 - 12:49 PM
I was just about to post the same opinion.
#6 PCH Parts Express
PCH Parts Express
  • 2,130 posts
Posted 14 September 2015 - 12:56 PM
Britney buys a new truer when her drum is worn. Do it like Britney. Have a smoking bod... live large.
  • CoastalAngler1 likes this
Scott Salzberg
PCH Parts Express
#7 DFranklin
DFranklin
  • 8 posts
Posted 14 September 2015 - 01:24 PM
I had the same problem with mine. I was at BPR and one of the drag racers told me about some sanding sleeves that McMaster-Carr sells. I tried them and they seem to work pretty good.  Here is some info about them:
1.25" X 1"
36, 50, 60 , 80  grit    4719A108          $8.58/25
120, 180                    4719A506            8.58/25
240, 320                    4719A573            8.58/25
I hope this will help you with your problem.
David Cantwell :sun_bespectacled:
#8 Bill from NH
  • 9,823 posts
Posted 14 September 2015 - 01:45 PM
FYI most of the tire truers I've seen that used replaceable abrasives use sanding bands (sleeves) rather than sandpaper. Sanding bands have a much thicker backing sheet and are factory formed and glued to fit rubber arbors for spindle sanding. Bands don't tear and fly apart at speed as might sandpaper.
In addition to previously mentioned Chicagoland, Cobra, JK, Prime Racing, and several others have sold truers using replaceable sanding bands of various sizes and grits.
#9 SlowBeas
SlowBeas
  • 901 posts
Posted 15 October 2015 - 12:13 PM
What grit is the paper on a Hudy? I assume it's standard.
Jim Beasley
South Carolina, USA
- Pat Paulsen, 1968
