Remounting tires
11 replies to this topic
#1 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 16 October 2015 - 10:15 AM
Probably a lot of people are doing this already... but for people wanting to save money on the tire bill.
With the best tire pushing $20, you can buy a smaller hub tire and use it until it techs no more. Small hub tires have much smaller inner diameter. To expand the outside diameter, I'll soak it in  lacquer thinner for appoximately four hours. It'll slide right off the small hub. Let the doughnut dry overnight then remount it on the next larger hub you have. And do it again and again to larger hubs, retruing each time.
JK makes the little tools for easy remounting and Lowes sells Super 77 spray glue. I only coat the hub with a thin coat with a Popsicle stick; no need to do the doughnut and just stay away from the set screw as much as possible.
The JK and Kelly plastic hubs are my preference; they come in all the sizes, small all the way to big (.600") as well as Alpha drilled..all nice and light.
I've seen people at races putting up a collection bag for people to place they're old tires just to get the hubs. This can also be done for the rubber to remount on a larger hub.
  • kvanpelt likes this
#2 Danny Zona
Danny Zona
  • 1,191 posts
Posted 16 October 2015 - 10:20 AM
Just remounted some small hubs on full hubs this week. Love to recycle.
  • kvanpelt and John C Martin like this
You're never fast enough!!! 💯
It's not about being right, it's getting it right.
Kelly Racing.
#3 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 16 October 2015 - 10:25 AM
Yep, when you get those Kelly small hubs working it's hard to pitch them away when they don't tech anymore, especially Wonders and Retros, not to mention the small hub silver label (specials).
#4 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,284 posts
Posted 16 October 2015 - 11:01 AM
I'm the new guy, and I must say I have not found tires as good as Kelly tires. The pros know!
Charlie McCullough
Charlie's Speed Shop
JK Hawk Horsepower Specialist
Bartos Chassis  CHR Cars
Outisight Bodies
Mossetti Racing
#5 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 1,711 posts
Posted 16 October 2015 - 01:12 PM
Good tip and obviously the durometer will change a bit.
Tires are just like chassis, some work great at some tracks and leave you out to lunch at others. On my flexis I have always preferred Alphas.
Matt Sheldon
#6 kvanpelt
kvanpelt
  • 1,114 posts
Posted 16 October 2015 - 01:46 PM
I also set my ISRA stuff up to use a different diameter tire. Tire gets used for one class, then cut down and all ready for the next. Same as we do in Retro; use for Can-Am them true and save for F1.
Racing Retro has really filled my tire box with scale rubber. It's been a couple years since I've bought anything for scale.
  • Matt Sheldon and John C Martin like this
#7 Dallas Jackson
Dallas Jackson
  • 323 posts
Posted 16 October 2015 - 02:04 PM
Yep; been reworking old rims for awhile..
If you really want to shine; get yourself a can of 'Never Dull' and clean up the rims before start mounting the rubber (don't put the ND where your "GS" goes).
Dallas
OLD36Dracer
#8 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 16 October 2015 - 02:15 PM
When I find out where my "GS" is I'll ask where my "GS" goes LOL... it's different in AL know.
#9 brnursebmt
brnursebmt
  • 660 posts
Posted 16 October 2015 - 02:43 PM
Drop those old hubs in a small amout of CLR for about five minutes. They will look brand new again!
  • John C Martin likes this
Bobby Robinson RN
#10 bluecars
bluecars
  • 1,134 posts
Posted 16 October 2015 - 07:12 PM
I live in AL and I'm not sure if I have a GS???  G-String, G-Spot, Gold Spoon. I've got some Get Some. :dash2: :sarcastic_hand: :sarcastic_hand:
  • John C Martin and CoastalAngler1 like this
Robert "Red" Valantine :diablo:
#11 Tim Neja
  • 5,768 posts
Posted 16 October 2015 - 11:30 PM
Toluene will melt the rubber off in minutes also!
#12 John C Martin
John C Martin
    J.C Martin
  • 1,066 posts
Posted 17 October 2015 - 08:42 AM
Right, Matt.
Quite often I'll use a bigger hub (harder, faster) for the outside in the bank, the smaller hub (softer, more grip) outside for the doughnut.
For an oval or tri-oval I try to put the harder tire on the outside for speed through the bank, and the tire wear doesn't change as much nor handling change as much throughout the race.
