Lightened Parma crown gears
109 replies to this topic
#1 TG Racing
TG Racing
  • 425 posts
Posted 21 January 2016 - 08:04 AM
Does anyone have pics they could post of lightened Parma crown gears?  I would like to see the "What and How" to do to these gears.
Thom Greene
  • 8,912 posts
Posted 21 January 2016 - 09:11 AM
I don'i run retro, but I would envision drilling one of the two setscrew holes larger & grinding flats on the hub areas between the two setscrew holes. You aren't allowed to shorten the hub length. What isn't clear to me is whether or not you are allowed to drill holes in the gear's plastic. If you can, you might be able to use a metal spur gear's holes for a drilling pattern. Otherwise, the RGEO jig or a lathe's indexing head will work.
#3 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 09:27 AM
You can drill holes in the plastic. You can reduce the hub size and flatten sides. You can sand the diameter and you can take off some of the plastic on the non-tooth side of the gear.
You CAN'T relocate the set screw holes nor reverse the hub in the gear.
  • Steve Deiters, TG Racing and Taylor Davis like this
#4 Steve Deiters
Steve Deiters
  • 1,906 posts
Posted 21 January 2016 - 09:34 AM
What Noose said.^
#5 Uncle Fred
Uncle Fred
  • 1,262 posts
Posted 21 January 2016 - 10:52 AM
The lighter the rotating mass, the faster the acceleration........
Fred Correnti
#6 Don Weaver
Don Weaver
  • 1,242 posts
Posted 21 January 2016 - 11:12 AM
.....and quicker braking (small difference tho it may be).
Don Weaver
L.H. Lapham
it will starve to death...
#7 Brinkley47
Brinkley47
    A winner is a loser who gave it one more try
  • 814 posts
Posted 21 January 2016 - 11:30 AM
Courtesy of Muffin
  • John C Martin likes this
Will Brinkley
willbrinkley@gmail.com
#8 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 11:35 AM
Does that have the sleeve in it?  Doesn't look like it.
  • Half Fast likes this
#9 John C Martin
John C Martin
    J.C Martin
  • 1,059 posts
Posted 21 January 2016 - 11:37 AM
How about backside --anything there?
Aluminum ? Nice
#10 Brinkley47
Brinkley47
  • 814 posts
Posted 21 January 2016 - 11:39 AM
Per Muffin, it has an Aluminum Sleeve. No pictures of the backside.
Will Brinkley
#11 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 11:57 AM
Ahh OK. Aluminum is lighter than the brass. Before Parma made the gears with the brass sleeves, and before C/R made the brass sleeves available, we did use aluminum IF you could cut the set screw notch and then get it into the gear without bending it.
#12 Tim Neja
  • 5,540 posts
Posted 21 January 2016 - 12:02 PM
WHY not move the set screw hole??  It's simple, and makes lightening the gear easier.
#13 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 12:13 PM
It is not allowed.
#14 Uncle Fred
Uncle Fred
  • 1,262 posts
Posted 21 January 2016 - 12:37 PM
Was the aluminum tube drilled out before installing?
Fred Correnti
#15 Tim Neja
  • 5,540 posts
Posted 21 January 2016 - 12:41 PM
It is not allowed.
I know that!!! I asked WHY???
#16 John C Martin
John C Martin
    J.C Martin
  • 1,059 posts
Posted 21 January 2016 - 12:48 PM
Just did a aluminum sleeve - easy to do using a 3/32 reamer and dremeled a notch for screw..
.2 gram lighter
  • CoastalAngler1 likes this
#17 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 12:49 PM
Because we said so.  Guys can drill holes and shave metal.  Relocating and tapping a new set screw hole is not something the normal racer can do.
  • B.C. and Dan Ebert like this
#18 Uncle Fred
Uncle Fred
  • 1,262 posts
Posted 21 January 2016 - 12:54 PM
When will hear "Oh no my gear broke!" for the first time?
  • Noose and Half Fast like this
Fred Correnti
#19 The Number of
The Number of
  • 1,484 posts
Posted 21 January 2016 - 01:41 PM
this is what you get when you allow set screw relocation.
  • Noose, Half Fast, Ace and 1 other like this
Bill Fulmer
#20 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 01:56 PM
Thanks Bill.
#21 Uncle Fred
Uncle Fred
  • 1,262 posts
Posted 21 January 2016 - 02:00 PM
I have my bearings gummed by toothless Eskimo women to make them smoother........
  • Racer36 likes this
Fred Correnti
#22 Mark Wampler
Mark Wampler
  • 7,003 posts
Posted 21 January 2016 - 02:43 PM
Assuming you have a drill press, you can relocate the set screw.   I’ve ruined several gears in the process.  I don’t recommend it.  Bryan has the setup and experience.  BP racers only!
  • MSwiss likes this
You can quote me.
-Mark
#23 Noose
Noose
  • 21,223 posts
Posted 21 January 2016 - 03:13 PM
I don't have a drill press, don't want one and more than half our racers don't have one.  Ruined is the magic word.  LOL
By the time you go through all of this you might as well buy a Red Fox or Koford gear.
  • brnursebmt, Half Fast, kvanpelt and 5 others like this
#24 jimht
jimht
  • 1,236 posts
Posted 21 January 2016 - 03:35 PM
The latest Board postings regarding the various Retro Rules Sets indicate The Peter Principle applies to rules as well as management.
What happened to "KISS".
:dash2:  :D
  • Mike K, NSwanberg and Markg like this
Jim Honeycutt
#25 Rick
Rick
  • Partial Member
  • 8,843 posts
Posted 21 January 2016 - 04:38 PM
With Noose being in such a generous mood, maybe the right time to ask for tape on the bottom?...........
Rick Bennardo
"Professional Tinkerer"
scrgeo@comcast.net
R-Geo Products
Lead! The easy equalizer...
