Large diameter Wonder rubber tires?
Posted 30 January 2016 - 06:28 PM
Anyone manufacturers out there interested in a new market??
Posted 30 January 2016 - 11:57 PM
Dennis David
Posted 31 January 2016 - 09:41 AM
Posted 31 January 2016 - 09:53 AM
Posted 31 January 2016 - 12:38 PM
SO FAR, the B&E use rims similar to ProTrack only in 1/8 axle, but if enough of a interest is there the 3/32 axle wheels could happen. Donuts and finished 1/8 axle tires are available NOW. B & E Slotsports
racing around Chicago-land
Posted 31 January 2016 - 02:49 PM
Larry,
I already queried Brian last night about 3/32" rears.
No interest by him at the moment.
http://slotblog.net/...r-rubber-tires/
This is a case of why not to pose the same question twice.
Answers in 2 different threads.
As far as donuts, Brian said he would be willing to sell some separate, when he gets his next shipment in.
He's a bit tight right now.
Posted 01 February 2016 - 10:41 AM
Sleeve the rims like in parma retro gears!
Posted 01 February 2016 - 10:55 AM
Posted 01 February 2016 - 05:24 PM
They work great rim width on the Hot Rod class you ran on the flat rack. Just enough slide factor!
Posted 01 February 2016 - 11:56 PM
Sorry, I didn't mean to create two threads!! One wouldn't post--- till a moderator looked it over. I thought it wasn't going to be posted. Just looking to find large diameter WW tires. Not easy apparently.
Posted 02 February 2016 - 11:36 AM
Posted 02 February 2016 - 12:26 PM
Dennis David
Posted 02 February 2016 - 12:33 PM
You can easily push a .950 OD tire to 1.1 with the right wheel size.
willbrinkley@gmail.com
Posted 02 February 2016 - 02:29 PM
Dennis David
#15
Posted 02 February 2016 - 04:20 PM
You should probably let them rest a few days between gluing and truing.
#16
Posted 02 February 2016 - 07:04 PM
Dennis David
#17
Posted 02 February 2016 - 07:40 PM
Not sure if you could (and get it to clean up) or if it would be a good idea. JMO.
Anyone who wants to try it, go for it.
I have the ones in the below pic.
1/8" axle, but I think you could sleeve them and true them up.
They are approx 1.110"+ OD.
Rim ID - approx. .600"
Rim width - approx. .540".
Foot print - .approx. .700".
