How to treat tires patent
Posted 27 March 2016 - 11:21 AM
Process for treating racing tires with perchloroethylene, naphtha, and a rubber solvent and composition
Posted 27 March 2016 - 12:03 PM
I tried this. If you want to soften tires this will do the trick, almost soften them too much! So beware!
As far as sticky goes very mild stickiness wears off kind of quickly.
In my own opinion 60% cut tire glue is way better.
Ken
Posted 27 March 2016 - 12:26 PM
What Is cut tire glue?
Posted 27 March 2016 - 12:43 PM
I think this is for making tires harder....Like buying "treated" tires.....This is from the time when tires were SBR rubber with too much traction,though there is a date from 2010,not sure how this would work on today's compounds.....Just thought it would give folks something to think about today besides candy....
I think he talking about thinning tire goop.....
Posted 27 March 2016 - 01:25 PM
I read this as another name for thinning tire glue to 60% glue plus 40% solvent.
Steve King
Posted 27 March 2016 - 01:37 PM
I have the same problem my tires start drying up and I got tired of buying new tires. The place that I run my cars at was selling this stuff by Trinity called yellow dot traction and it works and worth the cost of this product, now can I can not get this stuff any more.
I tried different hand creams and tried this paint remover for latex paint removed some of the dried surface material and also penetrate in the tire. I wipe off and the tire softens up a bit and traction but does not last long so then I use automotive belt dressing, work it in to the tire get some descent traction.
I tried a silicone latex caulk and foam sealant remover and seems to work better than the other stuff I mention, and then use that belt dressing and much better results. I know can redirect my money to buying more parts and less buying of new tires.
Nothing like slot cars
Posted 27 March 2016 - 02:32 PM
I just read this again.....This seem to be something that was done BEFORE mounting tires.....I still think this is for giving tires less traction and help them slide more,though there are parts that say it softens tires....Maybe it did both?....Still interesting to read.....Crap,I don't know......
- Tim Neja likes this
Posted 27 March 2016 - 02:33 PM
- tonyp likes this
Posted 27 March 2016 - 06:22 PM
"Perc" isn't something that's easy to find for the consumer. Maybe a sympathetic dry cleaner but you're not finding it at Ace Hardware or Home Depot..... oh, at high temps it decomposes into very nasty chemicals.
Posted 27 March 2016 - 07:10 PM
The date was 1965 on that paper.
Posted 27 March 2016 - 10:28 PM
If you go to the bottom of the page,this patent was referenced as late as 2010 with the paper written in 2013.....Click on those papers for more recent mumbo jumbo about treating tires......Should keep you busy for awhile.....
When your done treating tires with the perc.....You can catch some neutrinos.....
Posted 30 March 2016 - 12:49 AM
Tires last longer than 2 hours now ?
Posted 30 March 2016 - 01:24 PM
