Exploded view of a Globe motor
22 replies to this topic
#1 Hworth08
Hworth08
  • 3,563 posts
Posted 03 March 2008 - 12:29 PM
IIRC, without a special tool, a Globe motor should not be disassembled as the brushes cannot be replaced. Anyway here is a picture of the insides of a Globe motor lifted from an eBay auction..
  • Alchemist likes this
Don Hollingsworth
11/6/54-2/13/18
#2 Ron Hershman
Ron Hershman
  • 22,051 posts
Posted 03 March 2008 - 01:39 PM
That thing could be put back together no problem... and without special tools. ;)
#3 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 03 March 2008 - 01:43 PM
Globe motors! That goes way back. Our track owner at the time put together a track cleaner car, super heavy dragging pads to collect dust using a Globe motor for horsepower. It was geared at 8 to 1 or so as it putted around the track at full power. It worked. :)
Mark Wampler
?/?/1950-3/8/22
#4 GotToRace
GotToRace
  • 206 posts
Posted 04 March 2008 - 11:26 AM
Sure hope it can go back together. That one looks in sad shape.
Has anyone ever trued or balanced these things? I've got two I'm working with to re-build a car I had in the '60s just for the heck of it.
Steve (Spud) Saunders
Please! This is supposed to be a happy occasion.
Let's not bicker and argue over who killed who.
- King of Swamp Castle: Monty Python, Holy Grail
#5 Jairus
  • 10,174 posts
Posted 04 March 2008 - 11:43 AM
I have a couple of those arms here... One is epoxied and both are balanced.
The comms on these look way better than the one in the eBay auction. Wonder what it sold for?
#6 Hworth08
Hworth08
  • 3,563 posts
Posted 04 March 2008 - 01:01 PM
The brush-holding "ring" and end plate somewhat resembles those on a Falcon motor.
A couple of screws to convert a Falcon to a re-buildable motor? :unsure:
Don Hollingsworth
11/6/54-2/13/18
#7 TSR
  • 42,303 posts
Posted 04 March 2008 - 01:19 PM
Don,
At the price of a Falcon, who would want to spend time and money to rebuild? Do you rebuild used tires? :)
...without a special tool, a Globe motor should not be disassembled as the brushes cannot be replaced.
In case the brushes are damaged, worn or lost, it is quite easy to fashion a replacement set from Mabuchi FT16D brushes. The shunt wires (also called "pigtails") can easily be fitted by drilling the brushes and pushing a folded strand inside.
Your motor as shown in the picture is missing several parts: there is a white plastic insulator and a spring-steel ring missing. Do you have them?
Actually, Ron, if disassembling a Globe SS91 or SS101 is quite simple, reassembly is a major b*tch due to the brush springs' odd shape. And yes, it does take special tools, the first shaped as a long hook, to be able to perform that delicate matter, where the spring must be wound a full turn with the hook, while the very short spring tail can be held with another tool made of a handle and a shortened syringe needle, while the whole assembly is delicately held in a vertical position in a vise using V-shaped plastic jaws... without said tools I GUARANTEE that the assembler will royally screw up both brushes AND springs.
Even with such tools, it is not something I would recommend to novices. Assembly of any other slot car motor is a breeze compared to the Globe motors. ;)
#8 Prof. Fate
Prof. Fate
  • 6,580 posts
Posted 04 March 2008 - 01:32 PM
Hi
My friend, you collect die-casts for fun, I diddle with motors for fun, even the cheap ones.
Fate
Rocky Russo
3/6/48-1/1/12
#9 TSR
  • 42,303 posts
Posted 04 March 2008 - 01:37 PM
Rocky,
That's not the point. ;) We all like to tinker.
#10 Hworth08
Hworth08
  • 3,563 posts
Posted 04 March 2008 - 01:56 PM
Sure would and sure have!
I would relish the idea of being able to replace the brushes in a FK motor that had proven to be a good motor. Even if the brush assembly was "expensive" compared to the cost of a new motor.
As for tires, doughnuts.
Fair chance the importer that sold a re-buildable FK motor would quickly corner the market. The fact this would create a dwindling market is the reason it will most likely not happen.
Don Hollingsworth
11/6/54-2/13/18
#11 TSR
  • 42,303 posts
Posted 04 March 2008 - 02:50 PM
Don,
Do you really think that the people using the Falcon motors would care if the motor was rebuildable or not at the price they cost? Especially the TSR D3 at $9.95... I would bet that may be 5% of the customers would... if that! If someone wants a rebuildable motor of the same size, it seems to me that the Pro Slot 4002 in its various iterations fills the bill, no?
Do you have the missing parts for your Globe motor?
#12 Cheater
  • 25,752 posts
Posted 04 March 2008 - 02:53 PM
P,
As Don mentioned in his first post, the Globe motor pic was lifted from an eBay ad. It isn't Don's motor...
#13 TSR
  • 42,303 posts
Posted 04 March 2008 - 02:57 PM
That will teach me to read with my monocle. ;)
#14 Hworth08
Hworth08
  • 3,563 posts
Posted 04 March 2008 - 03:39 PM
Dokk, you're completely forgiven! It was nice to offer your help anyway! :)
PS... Another Champion of Chamblee 285 frame is on ebay, $90 opening bid, I can't find a cheap one!
Don Hollingsworth
11/6/54-2/13/18
#15 Larry LS
Larry LS
  • 1,661 posts
Posted 04 March 2008 - 05:07 PM
Well here is one of my old Globes that I have left. Back in the day we had a local racer who out at Vandenburg air when there was lot going on there. And he had a source of these Globe motors and we could buy them from him for $6.00. Through him and the base. We did not ask too many questions.
Not too many went for them but I had three It think. I used to modify them a bit, to get more air flow into them by opening up the end plate and on the side of the can. I also turned the arm shafts to to .093 to get a better pinion selection to use then. I will never restore it as the brush's are gone and one ball bearing has gone into hiding.
The "arm" has been cleaned up and seems to be in good shape yet. Anyone want it?
Larry Shephard
1937-2011
#16 Ron Hershman
Ron Hershman
  • 22,051 posts
Posted 04 March 2008 - 07:42 PM
Never had any problems nor special tools. An Exacto knife and tweezers, that was it. No screwed up brushes or springs. All that I worked on ran fine.
Had one guy send one in with melted spring posts. Knocked those off and put in C-can spring posts/cups and used Champion 3 coil springs with the stock brushes.
That one ran pretty awesome.
#17 TSR
  • 42,303 posts
Posted 04 March 2008 - 08:03 PM
Hey, we can't ALL be geniuses! :laugh2:
Larry, I have the parts to repair it if you want to restore it. Just let me know... :)
#18 Ryan Miller
Ryan Miller
  • 11 posts
Posted 10 May 2008 - 03:16 PM
Don,
Phillipe:
You said you have parts for the SS-91.
I have one that I would like to restore. At a minimum, I need brushes, springs and terminal post insulators (only a black one, actually), and perhaps one or two of the steel shims that go between the magnet and the brush carrier.
What do you, or anyone else that might read this, have?
Thanks,
Ryan Miller
#19 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,343 posts
Posted 10 May 2008 - 04:19 PM
This goes for the Globe/Versitec 101 also, as I found out personally. The brushes are impossible to put back. I would not disassemble it if it's still running. I sold a new one (SS-91) 5 months ago for $300.00. :shok:
Gary Stelter
#20 Paul Menkens
Paul Menkens
  • 455 posts
Posted 16 March 2021 - 04:44 PM
at the time Globe claimed that there was no need for cooling vents as long as you (they) knew how to design motors correctly, I guess that's all they knew
  • Bill from NH and Jesse Gonzales like this
#21 Clyde Romero
Clyde Romero
  • 1,168 posts
Posted 18 March 2021 - 04:23 PM
These motors were used to open the canopies on F-100 F-101 jet fighters
#22 Clyde Romero
Clyde Romero
  • 1,168 posts
Posted 18 March 2021 - 04:25 PM
Yes the motor was used to operate the canopy on many early fighters
F-100/101/104/105/106
that’s why he had so many of them
#23 Tom Thumb Hobbies
Tom Thumb Hobbies
  • 3,623 posts
Posted 18 March 2021 - 10:49 PM
They were made in Dayton OH near Wright Patt AFB so we saw way more than our fair share at the raceway. We had a couple dozen AF personnel make the hour drive weekly to race.
Sent from my iPad using Tapatalk Pro
  • Jesse Gonzales likes this
Mike McMasters
Former home of the ORIGINAL American blue King
