Help with diagnosis
11 replies to this topic
#1 FVracer
FVracer
  • 317 posts
  • Gender:Female
Posted 05 June 2016 - 01:53 PM
I built a motor for RetroPro to SCRRA rules - X12 PS arm (reconditioned by Alfa) in a PS mini can. BB both ends and copper hardware. I used Champion light springs and Koford BFs. I broke it in and got the amp draw down to 3.2 after not much time on my power supply. I thought I'd run it in on the track I mounted it in the chassis, soldered, and tested it. It drew 5.4 and it was "free" not against a spur.
What do I need to look at? It's for the Caribbean Retro Championship and don't think I can get another motor in time. This combination is not stocked by distributors.
Thanks.
Diana Dyckman
#2 MSwiss
  • 25,622 posts
Posted 05 June 2016 - 01:55 PM
Make sure there isn't any comm dust, or other debris, in the slots.
#3 Robert BG
Robert BG
  • 427 posts
Posted 05 June 2016 - 03:24 PM
Have you ran it on the track at all yet?
Robert Fothergill
#4 Cheater
  • 25,543 posts
Posted 05 June 2016 - 04:41 PM
Diana,
Try another couple of sets of brushes and see what amp draw you get from them.
#5 Rob Voska
Rob Voska
  • 1,073 posts
Posted 05 June 2016 - 05:00 PM
Did you bind the can when you soldered it in?
#6 FVracer
FVracer
  • 317 posts
  • Gender:Female
Posted 05 June 2016 - 05:03 PM
No track test yet. I'll unsolder, check for binding, check for trash in the comm, and replace brushes. We'll see what happens.
In any event your help is very appreciated.
Diana Dyckman
#7 John Streisguth
John Streisguth
    Johnny VW
  • 5,638 posts
Posted 06 June 2016 - 12:05 PM
Diana:
I would be glad to send my RetroPro motors to you. I raced this past weekend at RetroPalooza and the X12 is fast; my chassis was not competitive.
I also have a motor with a Big Dog arm, in case you find the X12 is a bit "too much." LOL.
  • Cheater likes this
"Whatever..."
#8 gc4895
gc4895
  • 493 posts
Posted 06 June 2016 - 06:54 PM
Is the X12 in the mini-can competitive with an X12 in a C-can? Anybody make a comparison of these?
I weighed my mini-can motors at 20 grams vs C-can motors at 28 grams so they are lighter. I'm just wondering if, in the circumstances where the formula is simply "any X12 motor", the mini would offer an advantage?
Mark Bauer
#9 FVracer
FVracer
  • 317 posts
  • Gender:Female
Posted 06 June 2016 - 07:38 PM
Mark,
The rules in SCRRA RP require a PS mini-can.
The motor is working well now. The best result was changing brushes to PS Goldust and rotating the endbell 180 degrees. I tried another new set of Koford BF with a little improvement. Then I  put in the Goldust and there was significant improvement. I rotated the endbell 180 degrees and the motor spun up nicely. It's now pulling 2.7 and it hasn't yet run on the track.
Before doing the reassembly I cleaned the comm slots and wiped the comm down with PURE. Since the endbell might have been moving even with the can screws I used a little epoxy in the screw holes of the endbell before reassembly. Probably be a bit difficult to disassemble but the race is close.
Happy now. Thanks for the help and hints.
  • Cheater and Robert BG like this
Diana Dyckman
#10 Steve Boggs
Steve Boggs
  • 77 posts
Posted 08 June 2016 - 05:45 PM
You rotated the endbell and it got better? Were the lead wires soldered backwards making it run backwards? :shok:
Knowledge doesn't mean Understanding, and the Truth is the Truth, no matter what you think of it...........
#11 FVracer
FVracer
  • 317 posts
  • Gender:Female
Posted 08 June 2016 - 06:28 PM
No, the lead wires were correct. I think the 180 degree switch probably just corrected a tilt that I hadn't detected before. I probably could have rotated it back and made sure it was absolutely straight.
Diana Dyckman
#12 Jason Holmes
Jason Holmes
  • 1,259 posts
Posted 13 June 2016 - 10:13 PM
Diana
Most of my Little Motors (R/P) draw 4-6 amps at 5 volts when breaking them in
Jason
