Retro building jig
22 replies to this topic
#1 rodslot53
rodslot53
  • 57 posts
Posted 02 September 2016 - 10:34 AM
Looking to buy a jig for building up some Retro scratch builds. Any recommendations on jigs.
Rod.
Rod Morrison
#2 Matt Sheldon
Matt Sheldon
    Duffy's HMI Executive
  • 1,700 posts
Posted 02 September 2016 - 10:40 AM
All you will ever need.
http://www.pslotcar....304_preview.JPG
  • JerseyJohn likes this
Matt Sheldon
#3 Mark Wampler
Mark Wampler
  • 6,950 posts
Posted 02 September 2016 - 11:05 AM
I recommend the Retro Pro Backtrack.  This is an early pic.  Newer ones have a thick baseRetro Pro.jpg
You can quote me.
-Mark
#4 tonyp
  • 13,751 posts
Posted 02 September 2016 - 11:36 AM
I second what Matt says!
  • rodslot53 and JerseyJohn like this
1965 "Evil Bucks Racer" Team
Revtech Team Trinity
Noose Painted Bodies
Retro East co-founder
First IM Nationals Champion
Arco Champion
ip
#5 MSwiss
  • 19,010 posts
Posted 02 September 2016 - 11:46 AM
I recommend the Retro Pro Backtrack.  This is an early pic.  Newer ones have a thick baseattachicon.gifRetro Pro.jpg
Thanks for posting , Mark.
Below is a pic of the current model.
They just went up in price, $135.00 retail.
As Matt and Tony mentioned, the Presicion is also a very nice unit.
R-Geo also makes one that a lot of guys like.
If you plan to build 1/32nd cars, that might be the ticket for you.
  • Jencar17, rodslot53 and JerseyJohn like this
#6 Mark Wampler
Mark Wampler
  • 6,950 posts
Posted 02 September 2016 - 11:53 AM
The reason I like the Retro Pro is that it is straight forward, easy to setup.   Chassis building doesn't have to be complicated.
You can shop separately for custom jig wheels.  The RP has a wire bending fixture included.
I've always used them, so do your homework.  Ask around.
You can quote me.
-Mark
#7 MSwiss
  • 19,010 posts
Posted 02 September 2016 - 11:58 AM
Jig wheel blocks are included.(upper right hand in pic)
The $135 I quoted is just for the building jig, as shown.
With the separate bending jig, the current price is $165.00.
#8 Mark Wampler
Mark Wampler
  • 6,950 posts
Posted 02 September 2016 - 12:22 PM
I was thinking specifically of spec width rear jig wheels, which mine didn't include at the time.
jig wheels.jpg   These are from R-Geo
You can quote me.
-Mark
#9 Eddie Fleming
  • 939 posts
Posted 02 September 2016 - 12:38 PM
Mike Is the Backtrack drilled for 1/8 axles or 3/32? And what is the longest wheelbase?
#10 Mark Wampler
Mark Wampler
  • 6,950 posts
Posted 02 September 2016 - 12:40 PM
Mine is for 3/32
You can quote me.
-Mark
#11 MSwiss
  • 19,010 posts
Posted 02 September 2016 - 01:00 PM
I'm don't entirely understand the first part of your question.
The pins that hold your 3/32" jig axles are lathe turned brass, and stepped (with a shoulder) to make them easier to remove.
In the past, I have gotten smaller diameter pins, to use with 1/8" jig axles, but they are pricey.
You are better off to build with 3/32" bushings in the car, and then switching to 1/8".
If that isn't possible, I would still use a long pc. of 3/32" piano wire, and sweat on a pc. of 1/8" brass tubing in the middle, to simulate a 1/8" axle. You might have to sand down the brass a tiny bit to fit in your 1/8" bushings / bearings.
Max wheel base is 4 9/16", but you can really build to any length.
You install either your front or back first, and then slide it up or back, between the width pins,  to solder up the opposite side in the appropriate spot.
As long as your chassis width has a snug fit between the pins, the front and rear will be square.
Or square enough for slot racing. LOL
  • Ramcatlarry likes this
#12 Samiam
  • 4,465 posts
Posted 02 September 2016 - 02:13 PM
Forget the jigs with a built in bending fixture. Sounded like a good idea but ends up impractical to use.
  • Ramcatlarry, Joe Mig and Tim Neja like this
#13 MSwiss
  • 19,010 posts
Posted 02 September 2016 - 02:16 PM
Sam,
Agreed.
Those haven't been made for 5(?) years.
#14 Bill from NH
  • 8,713 posts
Posted 02 September 2016 - 02:23 PM
Sam, Backtrack changed to separate corian plates, one for the chassis jig, another for their bending jig about two years ago. RGEO's are separate too. I don't believe Precision ever came out with a wire bender. Are their any other jig/wire bender combinations out there?
#15 Tim Neja
  • 5,511 posts
Posted 02 September 2016 - 02:35 PM
I'd like to have a jig that goes down to a 3.625 wheelbase.  Any of those setup for that? :)
#16 MSwiss
  • 19,010 posts
Posted 02 September 2016 - 02:46 PM
Tim,
The R-Geo should do that, or see my post #11.
#17 Eddie Fleming
  • 939 posts
Posted 02 September 2016 - 03:23 PM
Thanks Mike.
More information than I was looking for, but good all the same.
I was asking if it was set up to use 3/32 Jig axles without using some sort of shims. I got my answer but I obviously did not ask my question well.
#18 MSwiss
  • 19,010 posts
Posted 02 September 2016 - 03:35 PM
Got it.
Correct.
You don't have to slide pcs. of tubing on the wheelbase pins to go smaller.
Sort of the opposite.
You would add a single pc. of tubing on the axle to go larger.
#19 Dave Crevie
  • 913 posts
Posted 02 September 2016 - 03:39 PM
I have the Backtrack jig, and I use 1/8th aluminum tubing as a sleeve over the 3/32nds axle on builds
that have 1/8th bushings. Solder won't stick to aluminum, so I don't have to worry about accidentally soldering
the sleeve to the bushing. I get a little shakey sometimes these days.
  • Ramcatlarry and MSwiss like this
#20 Zippity
Zippity
  • 4,600 posts
Posted 02 September 2016 - 04:26 PM
I love the bending device that came with my Backtrack jig - terrific for making those "U" bends for rear axle support on my Champion Turbo Flexi chassis :)
A great product.
  • MSwiss likes this
#21 Booger
Booger
  • 106 posts
Posted 02 September 2016 - 05:42 PM
Ceramic soldering board
$12.....Works great!
Not fancy.....Must make own pins and hold downs.
A JOY to solder on.
Don't HAVE to spend $100+ to make a straight/square chassis'
Don't get me wrong,those fancy chassis jigs are wonderful......Just another option that  works well.
  • MSwiss and Joe Mig like this
Gary "Booger" Baker
#22 Bill from NH
  • 8,713 posts
Posted 02 September 2016 - 06:40 PM
On the honeycomb ceramic plate I have, .047 piano wire works well for pins. A company down South sells pins with a taper that should fit tight in all honeycomb plates. I believe they make them in both steel & ceramic. Jewelers have used honeycomb ceramic plates for years.
  • Half Fast and Tim Neja like this
#23 rodslot53
rodslot53
  • 57 posts
Posted 06 September 2016 - 08:49 AM
Gentlemen,
Thanks for all the invaluable advice on building jigs. Looks as though it is between the PSC and the Retro Pro Backtrack jigs. Now I have to make my decision.
Thanks again.
Rod.
Rod Morrison
