If you won't give a number.....then completely define available in a way that can be used to end the issue
There is no issue. The way to end your perceived issue is for you to quit posting about it.
I'm normally against the Forum Police interfering. But man, you are, as has been said, a broken record. You may not be getting the answer you want, but that's the only answer you're going to get. Everyone else accepts it. You should do the same.
