Inconsistent wheel width
6 replies to this topic
#1 Samiam
  • 4,772 posts
Posted 12 November 2016 - 08:51 AM
While rebuilding my F1(Grand Prix) car I wanted to calculate the width of the axle tubes. So I measured some different brand rear wheels and came up with quite a variance. Came up with .798" to .818" hub width. Obviously I set my tube width for the widest ones.
Do you guys think an industry standard should be set? Sure would make tire testing on race day easier.
#2 tonyp
  • 15,325 posts
Posted 12 November 2016 - 09:11 AM
It would make things easier. But it will never happen.
  • S.O. Watt likes this
#3 Noose
Noose
  • 23,299 posts
Posted 12 November 2016 - 09:31 AM
Sam if you are comparing say a JK wheel to a medium Thunder as an example there is going to be a difference because the the JKs have that little nub/spacer on the inside for a reason. Saves them adding a spacer on a RTR car.
Trim them off and you can flip tires easily and make width.
#4 MSwiss
  • 25,909 posts
Posted 12 November 2016 - 09:33 AM
If it will make you feel any better, Kelly Retros are about .775"-.780".
  • Noose likes this
#5 Ramcatlarry
  • 2,944 posts
Posted 12 November 2016 - 11:35 PM
Most rule sets REQUIRE 0.810" maximum wheel width.  Anything narrow can be spacers added to the tube dimension. Rims wider have to be narrowed anyway - and SHOULD be manufacturer defect/carelessness.
#6 Brian Cochrane
Brian Cochrane
    Brian Xpro Retro East Member
  • 195 posts
Posted 14 November 2016 - 09:09 PM
Sam,when I change my rear tires to another brand I take one side off at a time and slide the new tire on and check the width so it fits  the max width to the guage, then I tighten it on. Then I take the other side off and slide the new tire on and add or remove spacers as needed to met the max width of the guage. If you take both rear tires off at the same time it takes much longer to get it all correct.So far the tracks we have been racing at on the Retro east series is pretty much Kelly retros on all of them except for Port Jeff.Port Jeff is always Thunder medium. I have found that the rim width is not always consistant even on the same brand at times. Always keep in mind that you need to have just a touch of side play in your axles for maximum speed.Just an added side note,never set your guide flag depth or height until you have the proper size rear tires on the chassis.All set up adjustments should be done in the proper sequence......
  • tonyp, Half Fast and Samiam like this
#7 Samiam
  • 4,772 posts
Posted 15 November 2016 - 07:11 AM
Good advice.
Thanks Brian.
