True 2 degree guide tongue from Chicagoland Raceway
28 replies to this topic
#1 MSwiss
  • 20,637 posts
Posted 12 November 2016 - 12:01 PM
AFAIK, the first commercial, ground, true 2 degree, angled guide tongue.
Made from .050", full hardened, spring steel. Precision ground to provide correct guide rake.
Only $5.50 each. Standard discount available to raceways. Available through Eagle Dist.
Available in 1-2 weeks, possibly less.
Shown upside down, to clearly display 2 degree angle.
Two tongues, right side up, nose to nose.
Slightly wider and longer than my popular .042' "small" tongue. .5 grams heavier.
  • race301, John Gorski, Tex and 6 others like this
#2 slotcarone
  • 3,437 posts
Posted 12 November 2016 - 12:15 PM
Great thinking!! :)
  • MSwiss likes this
#3 Tim Neja
  • 5,760 posts
Posted 12 November 2016 - 12:43 PM
Are these 3/4" wide?
Looks good, Mike.
#4 MSwiss
  • 20,637 posts
Posted 12 November 2016 - 01:00 PM
They are .562"W x 1.122"L.
#5 John Streisguth
John Streisguth
    Johnny VW
  • 4,895 posts
Posted 12 November 2016 - 01:25 PM
I'll take 5 as soon as they are available
  • MSwiss likes this
"Whatever..."
#6 Arne Saknussem
Arne Saknussem
  • 981 posts
Posted 12 November 2016 - 05:18 PM
Always with the useful stuff, Mike?  What the hey?
Pete Varlan
The most radical of revolutionaries inevitably becomes an arch conservative immediately after his revolution succeeds.
#7 MSwiss
  • 20,637 posts
Posted 14 November 2016 - 11:49 AM
On the slight chance anyone is interested in the non-ground version of the tongue, they are only $4 retail.
Again, a full discount is available to raceways.
#8 MSwiss
  • 20,637 posts
Posted 14 November 2016 - 10:52 PM
I thought these would take a little longer, but my grinder guy got a' grindin', and at least got some done right away.
For those wondering how you know these are 2 degrees, you use the device (pun intended) in the pic below, to make the grinding fixture.
  • Mach9 likes this
#9 Jay Guard
  • 1,403 posts
Posted 14 November 2016 - 11:10 PM
Oh, a sine bar with a precision toolmakers vise on it.  Doesn't everyone have one of those?
  • MSwiss likes this
Retro Racer &
Flat Track Fanatic
#10 Joe Mig
Joe Mig
  • 2,961 posts
Posted 15 November 2016 - 07:47 AM
Great idea, I'm surprised it took so long for somebody to think of it.
  • MSwiss likes this
#11 MSwiss
  • 20,637 posts
Posted 17 November 2016 - 10:55 PM
OK. Grinder guy got back to work.
I'll be able to ship all the orders with these, tomorrow.
#12 MSwiss
  • 20,637 posts
Posted 03 January 2017 - 04:37 PM
Temporarily sold out.
I will get my machinist going on more.
#13 Eddie Fleming
  • 1,208 posts
Posted 19 January 2017 - 11:36 AM
I may be the slow one to catch on but if you want a flat tongue just flip this over.
#14 MSwiss
  • 20,637 posts
Posted 19 January 2017 - 03:23 PM
Yes, that will work.
They are only ground on one side.
#15 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,112 posts
Posted 19 January 2017 - 03:39 PM
Works well. Slots in tongue allow you to flow the solder in.
Cheers
Faster then, wiser now.
#16 MSwiss
  • 20,637 posts
Posted 19 January 2017 - 03:48 PM
Thanks, Bill.
Flow it in, or confirm solder you have applied from the perimeter, has flowed all the way, underneath.
  • tonyp likes this
#17 Cap Henry
Cap Henry
    CHR Cars
  • 2,780 posts
Posted 22 January 2017 - 10:18 PM
Just got a bunch of these for my new builds and really like them!
Team PSC
Parma PSE
CHR Cars
JDR-Joe Dirt Racing
#18 kvanpelt
kvanpelt
  • 1,109 posts
Posted 23 January 2017 - 04:22 PM
Mike, I would like 10pcs when available.
#19 Cap Henry
Cap Henry
    CHR Cars
  • 2,780 posts
Posted 23 January 2017 - 04:44 PM
And I'd like commission when KVP pays LOL
  • kvanpelt likes this
Team PSC
Parma PSE
CHR Cars
JDR-Joe Dirt Racing
#20 MSwiss
  • 20,637 posts
Posted 06 February 2017 - 05:20 PM
Plenty back in stock.
#21 brnursebmt
brnursebmt
  • 654 posts
Posted 06 February 2017 - 08:15 PM
Mike,
I've had a question about these guide tongues for a while now.  With the car set up with tires on all around the chassis is accually raked downward from the rear to the front.  So with using this two degree tongue does it let the guide sit level with the track or is there a slight upward attitude of the guide.
I've never used one, or seen a car with one, just curious.
Bobby Robinson RN
#22 MSwiss
  • 20,637 posts
Posted 06 February 2017 - 08:53 PM
I haven't built a chassis with one, so I can't say for sure.
Cap just showed a chassis, he built with one, in the scratchbuilt chassis gallery.
Maybe he'll chime in, when he sets the car, up into a roller.
Regardless, it will be predicated by the rake on your particular car.
IOW, a car will obviously have more rake if it is at the minimum front clearance, .015", vs. being at say .030".
Best I can do is give you a visual how it's sits on a flat surface.
#23 Jay Guard
  • 1,403 posts
Posted 06 February 2017 - 10:55 PM
Assuming a nominal .050 clearance at the rear and .015 at the front the resulting chassis angle is just half a degree.  Therefore Mikes guide tongue should yield a 1.5 degree "up angle".
Here's the calculation:   .035" / 4" = .00875"  ->  arcSin .00875"= .5 degrees  ->  2 degrees - .5 degrees = 1.5 degrees
Obviously if you have different clearances at the front or rear this will change the resulting angle.
A good rule of thumb for figuring (small) angles is .017" per inch per degree.  An example would be if you had a one inch long block and it was touching the ground on one end and raised .017" at the other it would be lying at a one degree angle.
  • MSwiss, Half Fast and Richard G With like this
Retro Racer &
Flat Track Fanatic
#24 Cap Henry
Cap Henry
    CHR Cars
  • 2,780 posts
Posted 06 February 2017 - 11:15 PM
Jay is correct.
The car with .050 rear clearance and .015 front clearance the guide still has a slight up angle.
These are really nice pieces
  • MSwiss and tonyp like this
Team PSC
Parma PSE
CHR Cars
JDR-Joe Dirt Racing
#25 tonyp
  • 14,235 posts
Posted 07 February 2017 - 07:44 AM
Mike, send me 10 and a bulk bag of pin tubes when you get a chance.
  • MSwiss likes this
1965 "Evil Bucks Racer" Team
Revtech Team Trinity
Retro East co-founder
First IM Nationals Champion
Arco Champion
ip
