True Scale rules - final 12/18/16
#1 rvec
rvec
  • 1,341 posts
Posted 18 December 2016 - 09:30 AM
True Scale Rules
Rules applied to all True Scale Classes
Only production H-Bracket chassis are allowed. The following modifications may be made to any of legal H-Bracket chassis.
·       The front axle hanging systems of these chassis are typically weak and subject to bending. Fabrication of a custom front axle hanging system is allowed.
·       The H bracket may be stiffened by using piano wire or other material. The stiffening material may be soldered or attached using an adhesive substance such as JB weld.
·       Side and front pans may be added
·       Axle hanger holes may be reamed to fit the American bushings/bearings.
·       Bearings/bushings may be secured with super glue, other adhesives or soldered
·       Bolt holes may be reamed accept American bolts
·       Cooling hole may be cut under the motor
·       The 4 small “bump ins” in the center section of the chassis may be removed by filing away the material between them just enough to allow for the inner part of the side pan to sit flush on the center section.
·       No other chassis modifications are allowed unless shown for a specific chassis in the section below.
·       Tires must be black and centered in the wheel openings
·       Full interior tray with painted 3D driver figure is required
·       Two numeric decals are required. Three are preferred
·       Wheel inserts are optional but encouraged
·       Any major body piece such as a wing, if lost due to a mishap, must be reattached prior to the next heat
·       All motors must be sealed (no motor modifications are allowed). On 16D type motors, gold dust or equivalent brushes are allowed
·       The guide flag must not be visible as viewed from the top (exception Cobra/Corvette Challenge class)
·       Front tire width must be .4”. They may not be tapered but may be painted or hardened with super glue or nail polish to reduce rolling resistance. Front tires may not extend outside of the bodywork (although inserts may extend outside the bodywork)
·       Track Clearance – Front .055”, Rear .055”
·       Wheel wells may not be cut. The exception is for the TA2 and Historic Trans-Am (See rules specific to these two classes in their appropriate section regarding wheel well trimming and fender flares)
To date, legal chassis include the following:
·       Scholer
o   SCH1102001 Pantera – Center section may not be modified
o   i55-1360 Intruder – Ears on the Center section may be narrowed to the same width as the Pantera (approximately 2 inches)
o   i55-1360 LWB Intruder - Ears on the Center section may be narrowed to the same width as the Pantera (approximately 2 inches)
o   SCH1102002 Tiger - Ears on the Center section may be narrowed to the same width as the Pantera (approximately 2 inches)
·       Slotting Plus SP800001 Stainless Steel UNIVERSAL 1/24 Chassis
·       SCALEAUTO SC-8002c Adjustable LONG Wheelbase 1/24 Chassis
·       Plafit 1700 series
GT1 Specific Rules
Bodies:
Only the following bodies will be allowed:
·       Nissan R390 GT-1
·       Mercedes CLK GTR
·       Sauber Mercedes C9
·       Jaguar XJRM-8-LM
·       Jaguar XJR-9 IMSA
·       Jaguar XJ220 (1/24 scale)
·       Mazda 767B or 787B
·       Porsche GT-1
·       Porsche GT-1 EVO
·       Nissan R 88C
·       Toyota 88C
·       Porsche 956
·       Toyota 88C LM
·       Jaguar XJR-9LM
·       Toyota GT-1 TS020
·       Ford Mustang GTP
·       Porsche 962
·       Skyline GTR
·       Nismo GTR
·       Impulse GTR
·       NissanNSX
·       Toyota 84C
·       Additional bodies made by Carrera
o   Porsche 997
o   Corvette C6R
o   Ferrari 575 GT
o   Aston Martin DBR9
·       Nissan R89C and R90C
·       Ferrari Enzo
Modifications to body:
·       Dashboard may be cut out
·       Support may be added to the wing.
·       Support may be added to the front of the car.
·       Kits with closed rear wheel wells may be opened to the lines on the kit.
·       Kits with wings out behind the car may be mounted on the upper rear deck.
·       Side air vents that interfere with the mounting of the body may be modified or replaced with a flat piece of plastic.
·       All glass in the kit must be used
Motor:
Only the Falcon 7 or Hawk 7 motors are allowed.
Tires:
·       Rear tires must be at least 1.0" in diameter and must not extend beyond the bodywork
·       Front tires must be at least 15/16” in diameter
Bodies:
TA2
·       Years - from 2006 to present. 1/24th. / 1/25th. Camaro, Mustang and Challenger kits. No convertibles.
·       Minimum body height: 1.850" as measured from the bottom of the chassis. The Mustang and Challenger can be cut on the bottom of body to meet the minimum height. Camaro cannot be cut down
·       Front and rear wells may be trimmed for tire clearance.
·       Fender flares are required
·       Front and rear glass must be used
Historic Trans Am - Trans Am Series run from 1966 – 1972.
·       Classic Trans Am bodies are limited to those run in the series in the over 2.0 liter class with the following exception – Mustang fastback cars are allowed.
·       Only 1/25 scale kits are allowed.
·       Wheel wells may be trimmed for tire clearance
·       Bodies may not be cut down but may be raised to accommodate tire clearance.
Tracking:
·       Rear tire track is limited to 3.25. Rear tires may not extend beyond the bodywork (excluding the insert)
·       Front tire track is limited to 3.15
Tires:
·       Front tires to be a minimum of 15/16" diameter
·       Rear tires to be a minimum of 1.0"
Motor:
Only Deathstar and Proslot PS-2002 SpeedFX 16D balanced motor (sealed) are allowed
True Scale Can Am and Gran Sport
Bodies:
Can Am
Only plastic bodies allowed (no resin cars). Limited to actual race cars run in the series from 1966-1974. Tamiya slot car Can Am bodies are available and are light and relatively inexpensive. These include:
·       Lotus 30
·       Lotus 40
·       King Cobra
·       Lola T70
·       Ferrari P330 P2
·       McLaren Elva
Accurate Miniatures sells a plastic McLaren M8
Other models may be approved by the Track owner
Gran Sport
Gran Sport bodies are typically 60s sports cars. The goal will be to include cars that have the same wheelbase as the True Scale Can Am cars so that a single chassis may be used for either class. The following bodies will be allowed:
·       Ford GT-40
·       Porsche 904
·       Porsche Carrera 6 (aka 906)
·       Porsche 917
·       Corvette Stingray
·       Toyota 2000, 427 Cobra & Cobra Coupe
·       Ferrari GTO, 275P, 250LM
·       Corvair Corsa
·       Lamborghini Miura
Tires:
·       Front tires are to be a minimum of .85 inches in diameter.
·       Rear tires to be a minimum of  .925 inches in diameter
Motor:
Track:
Rear track Can Am/Gran Sport may extend beyond bodywork and if so is limited to 3.17 inches
Background:
The Cobra/Corvette challenge (CCC) class will be based upon the KISS principle. The place to start is with the 289/427, 1/24th scale Cobra. This model has the same wheelbase as the True Scale Can Am cars. The Cobra is quite narrow but can be “stretched” to fit an unaltered True Scale Can Am Chassis. This class is meant to re-create early Cobra/Corvette racing, therefore cars will be limited to 1953-1967 model years. In order to promote “competitive diversity”, bodies with approximately the same wheelbase will be selected and “stretching and/or wheel flares will be allowed (but not required) to facilitate tracks that are equal. Again, to promote simplicity, the same chassis may be used on Can-Am, Gran Sport and Cobra/Corvette challenge cars.
Bodies:
Only plastic bodies are allowed (no resin cars). Cobras may be 1/24th scale. Corvettes may be1/24th or 1/25th scale models with the exception of the 53 Corvette for which only the 1/25th scale version is allowed. Only replicas of cars for model years 1953-1967 will be allowed.
·       Bodies may be raised to facilitate wheel clearance
·       Wheel openings may be enlarged to facilitate wheel clearance
Tires:
Motor:
Track:
·       Front tires may extend beyond bodywork as viewed from above but track is limited to 2.90 inches
·       Rear track may extend beyond bodywork and if so is limited to 3.17 inches
Miscellaneous:
·       Guide flag may extend beyond the front bumper as much as a quarter inch as viewed from the top.
·       Cobra windshield and windscreen are flimsy and may be replaced by a custom windscreen made from any transparent material. Some Corvette convertible windscreens are flimsy and hard to mount and may be replaced by a custom windscreen made from any transparent material.
Sports Car
This class includes contemporary limited production and production based closed sports cars (no convertibles or sypders are allowed). The class specifically excludes all cars included in the GT1 class (see above for GT1 list of legal cars).
Bodies:
·       Wheel wells may not be trimmed for tire clearance
·      Maximum body width at the front and rear openings may not exceed 3.25 inches
 Approved bodies are as follows
·       Ferrari Modena
·       Ferrari Testarossa
·       Ferrari F50
·       Ferrari F40
·       Ferrari 458
·       Ferrari 430
·       Audi R8
·       Jaguar XJ220 (1/25 scale only)
·        Ford GT (not the Ford GT40)
·       Porsche 918
Bodies not on the approved list will be considered, however, please contact the track owner prior to the build. In the interest of competitive diversity, long wheelbase cars such as the Ferrari 599 are excluded from the class. The intent is to be able to use a Tran-Am chassis for cars in the Sports Car class.
Tires and Tracking:
·       Front wheel diameter shall be at least 15/16 inch
·       Rear wheel diameter shall be at least 1.0 inches
·       Rear or front tires may not extend outside of the bodywork (wheel inserts excluded)
Motor:
·       Only Deathstar and Proslot PS-2002 SpeedFX 16D balanced motor (sealed) are allowed
  • Samiam likes this
Rich Vecchio
#2 rvec
rvec
  • 1,341 posts
Posted 05 March 2018 - 06:13 PM
Note that the original post has been edited to incorporate all changes enumerated below.
I was looking at the rules and found that one was a typo, one needed to be clarified and  a couple of others changed.
Below are the corrections/changes
In the section entitled Rules applied to all True Scale classes - Track clearance should be .055 inches front and rear  Also, wheel wells may not be cut. The exception is for the TA2 and Historic Trans-Am cars (rules specific to these two classes are specified in the appropriate section)
For Can-Am and Gran Sport cars. Rear track is limited to the outside edge of the rear fender. If the outside edge of the fender is less than 3.17 inches, then the tires may extend beyond the bodywork but track is limited to 3.17 inches.
In the list of GT1 approved bodies - Instead of Charge Mazda 767B, the rules should read Mazda 767B or 787B.
That's all for now. I will update the original post sometime soon
Rich Vecchio
Rich Vecchio
