1) Parma controllers use tungsten wire for the resistance coil. IT CORRODES and needs to be either sanded or lubed or BOTH periodically. The wiper button is copper and it corrodes and needs to be sanded if it is not shiny.
2) Parma (and other brands) one barrel resistor controllers have not changed much since the were first used for HO and homeset slotcars in 1965. They are about 25 WATT capable - that computes to about 2 amps at 12 volts DC - Falcons and smaller motors (homeset and slow HO) . The Parma turbo and other two barrel resistor controllers are rated at about 40 Watts or less than 4 amps at 12 volts DC. This the 30 ga armature range - 16D, wasp, contender, and other under $20 motors.
3) Brass on brass - as in the nice Koford units and Prof Motor controllers - have much less corrosion due to dis-similar metal electrolysis. They still benefit from periodic clean and lube.
4) The diodes I use are the common Radio Shack 3 amp size - about 1/4" dia about 1/2" long. Bigger or smaller can be used. All drop voltage the same. The 3 amp size is a better size to limit current without excessive heat. The six amp ones work in a commercial setting as well. The "chain" is in the white input power line. The grey post is hooked up with the white wire as the 'chain' comes from the white to the grey. Old Difalco and Cidex rental controller systems used the same concept in their rental kits
racing around Chicago-land
