Champion front tire fix
7 replies to this topic
#1 Lone Wolf
Lone Wolf
  • 2,219 posts
Posted 05 January 2017 - 12:57 PM
I was working on some Champion chassis today, cleaning them up.
Both had the dreaded front tire rot.
I chucked the wheels in a Dremel and removed the offending crud using a single edge razor blade. Please be careful if you do this. A quick pass with a Scotchbrite pad finished them off. The tires are from older model kits. They seem to fit the bill although not original. You can chose different tires or sand these smooth or slightly resize them if you prefer. I have no idea where you could obtain originals as I doubt the tires were sold separately. I don't remember seeing the front wheels sold separate either.
Just my solution to a common problem.
  • hiline2 likes this
Joe Lupo
#2 Allan Feldman
Allan Feldman
  • 226 posts
Posted 06 January 2017 - 07:50 PM
Joe were the original front tyres Slicons?
Regards Allan
#3 TSR
  • 41,618 posts
Posted 06 January 2017 - 07:54 PM
The original Champion fronts are a mix of synthetic rubber and the real thing and can rot if left under certain conditions. The best repair is to make a composite silicone mold around a 1/8" axle and cast a new black urethane tire over the cleaned wheel. A bit of a bitch but it then lasts forever.
#4 Lone Wolf
Lone Wolf
  • 2,219 posts
Posted 06 January 2017 - 08:36 PM
Umm, casting tires in Urethane, sounds like an idea. Oh, wait, I bought this stuff years ago and never got "around to it" :dash2:
I wonder if its any good anymore. I guess theres only one way to find out.
Joe Lupo
#5 TSR
  • 41,618 posts
Posted 06 January 2017 - 08:38 PM
Joe,
these products have a fairly short shelf life... test it first!
#6 Mattb
Mattb
  • 1,293 posts
Posted 07 January 2017 - 10:26 AM
Silicone will cure around the old tires. It can be used to make a mold of the old tires. Urethane can then be poured into the silicone mold and it will cure and make a nice original size tire.
This process cannot be reversed using urethane as the mold and silicone as the the tire compound. Silicone will not cure when in contact with urethane.
Vintage Cox Slot Cars
#7 Allan Feldman
Allan Feldman
  • 226 posts
Posted 10 January 2017 - 11:06 AM
Was there Champion Tyres or Tyres and wheel Combi sold seperately at the time?
Regards Allan
#8 Lone Wolf
Lone Wolf
  • 2,219 posts
Posted 10 January 2017 - 11:54 AM
Well, as Dokk suspected, the stuff was junk. It was harder than learning Cantonese. I guess I should have gotten to it 8 years ago  :dash2: Stupid waste of money on my part. I hate when that happens.
Allen, I have not seen these sold separately although that means very little. If Scott does not have them, then they may not exist.
Maybe Dokk can verify.
Joe Lupo
