Problem with Third Eye Hitman FET controller
Posted 12 February 2017 - 03:08 AM
First problem is when I hooked up my controller incorrectly correctly - pressed the trigger, no or little power. I sent the controller to Howard once and he had it working again but the same thing happened as soon as I went back to the track to test it but, this time my controller was hooked up correctly.
This time when the car deslots, there's no or little power as soon as I press the trigger after putting the car back on. The track owner sent it back to Howard because he saw I was not using the controller and I explained the problem to him. He sent it to Howard again, got it back and I got the same results, deslot and then little or no power. No explanation given as to the cause of this problem.
Can anybody help?
- Bazzie likes this
Posted 12 February 2017 - 03:02 PM
Dennis Dominey
Posted 13 February 2017 - 03:22 AM
The fact your car de-slots won't have anything to do with it I wouldn't think.
Are you left-handed or right-handed?
Steve Meadows
Posted 13 February 2017 - 09:25 AM
Rick
I like to look for the simple problems first. Have you tried another car to see if you get the same results. Or drive someone else’s car.
Or give your controller to another driver and see if they get the same results. I’m sure you did all this but I had to ask.
I raced a Third Eye for many years and never had this or any other problems. I’m sure Howard will get it right.
Rick, after you find out what was wrong post what the fix was.
Roger
Posted 13 February 2017 - 09:49 AM
I doubt this is it, but try wiggling your brake wire.
While the red wire, physically, is large in diameter, the wire inside is tiny.
We had an issue here locally, with three controllers acting erratically.
Note, in this case, they all had "clamps" on the wires to prevent hooking up wrong, which probably brought on the problem.
If I had an idea how thin that red wire was internally I would have modified the clamp a bit.
Posted 13 February 2017 - 06:49 PM
I was at Chicagoland practicing and a friend was having problems. He thought his motor was bad. I ran his car with my controller, no problem. I ran his car with his controller, no problem. He ran his car with his controller, big problem. Handed the controller back to me and no problem. I handed the controller back to him, big problem.
He was lifting the wiper off the resistor and there was some play there. If you pulled straight back it was fine but if you put side pressure on the trigger it lifted the wiper off the resistor. Took controller apart tweaked it and it was fine... and he ran very very well the next day in all classes.
Posted 13 February 2017 - 06:58 PM
The mystery is the "deslot and then little or no power."
If it was his triggering style, pulling the arm away from the resistor, it seems like the "little or no power" would be from the get-go.
Posted 13 February 2017 - 07:19 PM
I'm confused... Does it work normally, then you deslot and then it stops working correctly, then, after a period of time, start working again until you deslot again?
Michael Colvin
- Pit dads of the world unite! -
Posted 13 February 2017 - 09:22 PM
Posted 13 February 2017 - 11:27 PM
If it was my controller I would have never had a problem with it the way it was.
Putting a little more wiper pressure on it fixed "his" problem and he ran very well the next day.
More like "if it works for you" things.
Posted 15 February 2017 - 12:15 AM
Needless to say, the arm did not lift off the resistor as I applied power. I decided to call Howard as I was testing the controller and described the controller situation. First, the car did exactly the same thing - no pick up and go. I moved the red wire around and no changes. Before I went to the track I removed the handle and checked the arm contact with the resistor - excellent contact.
As I was talking to Howard, my red wire clip fell, off leaving only the white and black wires connected to the track. My car picked up speed and it was moving but my sensitivity and brake knobs did not work as they should have and Howard told me to stop which I did.
He told me to send the controller back to him so he could check the brake system.
Posted 15 February 2017 - 12:40 AM
- Rob Voska likes this
John Chas Molnar
" Owner / Sponsor, TEAM JERSEY-TEAM AUSTRALIA
Posted 15 February 2017 - 03:24 AM
Correct!
"My understanding is FETs and transistors need the ground in order to work properly."
Without a connection to "ground" (0v, the brake wire) the relatively-complicated electronics will not have a reference to work from. And from there anything can happen.
Steen
- Cheater, Mike K, JerseyJohn and 1 other like this
Posted 29 June 2017 - 08:49 AM
Was the problem ever diagnosed and corrected?
3/24/54-3/25/2023
