Hey, everyone,
I have built the first JK C43, and also some of my friends, but some questions arrise now as we were much used to the JK X25, X24, X11, etc., even the Mossetti 1002, and we are not getting, in my opinion, yet the full potential of this new chassis.
Compaision with the older chassis:
in general we get less rear grip than the others (X25, Mossetti, X24), the tail is more all around, not so planted as to the others.
More forgiving than the others, when abused it stays in the track more, where others eventually deslot.
Good low weight, when we compare with the X25; this is a good advantage for the other JK chassis.
Revolutionary bar system, even if we at the moment do not yet understand well what to do with those two bars, and in what way the new assorted thickness option bars act or change the handling?
The center section normally comes flat as we get it, but the pans when they come twisted are more difficult to put correct than the older versions.
There is in my opinion too much side play in the pans as standard; how can we fix this?
In general seems to be a great chassis, but the rear loose feeling is something that I wish to know from you guys that already made set-ups and played with the optional bars, what can we do to get more rear plant (not so loose )?
If you can help this discussion, please. do. I think many racers will benefit from it.
Regards,
