Screws on Alpha medium Wonder tires not grabbing axle
36 replies to this topic
#1 Race O' Rama
Race O' Rama
  • 1,107 posts
Posted 30 March 2017 - 05:34 PM
I have had problems recently with the Alpha medium Wonder tire screws not cinching down on axles tight enough.
Has anyone else have this problem? How can this be solved? I have run the screws all the way down to clean out any extra metal or any non-threaded part and still have a problem. I have broken many tips off from my tire wrench and am very frustrated with this issue.
#2 Cheater
  • 22,922 posts
Posted 30 March 2017 - 05:37 PM
Karl,
Have you tried contacting Paul Pfeiffer about the problem?
  • Mike Patterson likes this
#3 mgerbetz
mgerbetz
  • 99 posts
Rubber stuck in the allen screw?
Mikey
  • Tex, tonyp and Frankie Schaffier like this
Michael Gerbetz
#4 Steve Deiters
Steve Deiters
  • 1,922 posts
Posted 30 March 2017 - 05:42 PM
I always pull out the set screws and dig out the socket with and X-Acto pointed tip to remove rubber, glue. etc. It comes out very easily. This debris in the set screw is found more often than not.
If the set screws are hollow, get rid of them and use "standard" set screws.
I also "chase" the threads in the wheel with tap while the set screws are out.
  • TG Racing likes this
#5 Tim Wilkins
Tim Wilkins
  • 1,053 posts
Posted 30 March 2017 - 06:14 PM
Lost two Alpha medium Wonders in separate races this past Saturday. I think the stock Alpha set screws are fine unless you take a few big hits. They may become loose and slightly stripped at that point.
Corrected:  A lot of racers like the set screws manufactured by McMaster-Carr.
#6 swodem
swodem
  • 706 posts
Posted 30 March 2017 - 07:08 PM
A lot of racers like the set screws manufactured by McMasters-Carr.
The link you sent was to a 5-40 set screw
Was that intentional? I have always believed we used a 4-40...
#7 swodem
swodem
  • 706 posts
Posted 30 March 2017 - 07:12 PM
Definitely sounds stripped from your description.
When the wheel is off the axle, the set screw will behave normally and travel right through like normal, using the remaining thread not stripped due to the beveled tip that doesn't engage in any thread when the axle is in place.
It's a real bummer, especially when you discover this when putting fresh donuts on the tyre truer for turning down - grrrr, all that work!!!
It's a piss off I agree.
Breaking the tips off your hex key? Maybe your doing them up too tight?
#8 boxerdog
boxerdog
  • 696 posts
Posted 30 March 2017 - 08:41 PM
Get American and/or knurled set screws:
Set Screws
David Cummerow
#9 Samiam
  • 4,660 posts
Posted 30 March 2017 - 09:16 PM
Make sure the axle and wheel hub bore are clean and oil-free. It is not the grip of the screw on the axle that holds the wheel, it's the friction of the rest of the bore against the axle. Try roughing up the end of the axle with some medium Scotchbrite. A highly-polished axle may be too smooth.
#10 Howie Ursaner
Howie Ursaner
  • 1,306 posts
Posted 31 March 2017 - 09:53 AM
i always take out the set screws from alpha wheels and throw them away and put in the ones i like from mcmaster carr
  • Noose, Mark Wampler and boxerdog like this
Howie Ursaner
#11 Noose
Noose
  • 21,291 posts
Posted 31 March 2017 - 10:06 AM
I do what Howie does on all my tires and gears too.
#12 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 1,946 posts
Posted 31 March 2017 - 10:13 AM
Also if you are breaking wrench tips, you are way over tightening it and will strip the threads on the wheel.
Cheers
Faster then, wiser now.
#13 Half Fast
Half Fast
  • 1,946 posts
Posted 31 March 2017 - 10:15 AM
While we are on the subject of screws...
What is the thread destination for the screws that attach at the end of the Hawk Retro motor.
Thanks in advance.
#14 Upfront slot cars
Upfront slot cars
  • 179 posts
Posted 31 March 2017 - 10:19 AM
What set screws do you guys use from McMaster?
Andrew Ford
#15 Noose
Noose
  • 21,291 posts
Posted 31 March 2017 - 10:34 AM
91375A103p1-b01-digitall@100p_6361129922
Alloy Steel Cup-Point Set Screw
Black Oxide, 4-40 Thread, 1/8" Long
91375A103
  • S.O. Watt and Frankie Schaffier like this
#16 Bill from NH
  • 9,082 posts
Posted 31 March 2017 - 10:36 AM
M2 x 3mm long, but some racers use 2-56.
  • Noose and Half Fast like this
#17 Hermit #1
Hermit #1
  • 174 posts
Posted 31 March 2017 - 11:06 AM
They're a little pricey, but the SPS-Unbrako Knurled Cup Point set screws have served me well since the early 1970's. MSC has them listed here:
Unbrako Knurled Cup Point Set Screws.
The material used is about the best on the market – the hex socket almost never strips out. The knurled point resists loosening, and seems to hold better than a regular cup point.
McMaster-Carr only lists a generic version of this set screw - I can't speak for its quality.
Cheers!
Dave "Hermit" Jones
5/26/??-9/12/17
#18 stevphens
stevphens
    Over the Hill...
  • 180 posts
Posted 31 March 2017 - 11:08 AM
How much is shipping for 100 set screws from Mcmaster-Carr? When ordering, they say, "Applicable shipping charges and tax will be added," but they don't say how much. MSC Industrial charges $11.60.
Rick Stevens
#19 Noose
Noose
  • 21,291 posts
Posted 31 March 2017 - 11:17 AM
How much is shipping for 100 set screws from Mcmaster Carr?
Depends on what else you order. They usually ship UPS. If you are close then it is cheaper.
#20 stevphens
stevphens
    Over the Hill...
  • 180 posts
Posted 31 March 2017 - 11:44 AM
Thanks, Noose!
I just contacted McMaster-Carr, and the shipping estimate for 100 set screws alone is: $6.00.
Rick Stevens
#21 JerseyJohn
  • 3,894 posts
Posted 31 March 2017 - 11:53 AM
Noose as always is dead on... The McMaster 4/40 holds well. FYI you might want to invest in a 4-40 tap to clean out the treads and hole.
i mount my own rubber and use mostly used rims. Running the tap through keeps me from having to toss a new mount because the threads are messed up.
Regards from the Dungeon,
JJ
John Chas Molnar
Email me
#22 ejgehrken
ejgehrken
  • 338 posts
Posted 31 March 2017 - 12:00 PM
Has anyone ever checked the 4-40 threads with a "Go/No-Go" gage?
Eric Gehrken
Gehrken Retro Chassis
2015-16 Retro East Overall Champion
2015-16 Retro East Constructor's Champion
2013-14 New England Retro Racing Overall Champion
#23 Hermit #1
Hermit #1
  • 174 posts
Posted 31 March 2017 - 12:40 PM
I used to do it all the time at work (aircraft machine shop). But you'll pay through the nose to buy one - Mcmaster-Carr wants $109.69 for a suitable one
Dave "Hermit" Jones
5/26/??-9/12/17
#24 Ramcatlarry
  • 2,055 posts
Posted 31 March 2017 - 12:44 PM
Hollow set screws for flats only, cup point on round shafts.
  • Samiam likes this
Host 2006 ISRA/USA
#25 Hermit #1
Hermit #1
  • 174 posts
Posted 31 March 2017 - 12:47 PM
MSC is a little cheaper on the Go-No Go gage.
Dave "Hermit" Jones
5/26/??-9/12/17
