Beginners need help for an office competition
24 replies to this topic
#1 Steve Lewis
Steve Lewis
  • 4 posts
Posted 15 May 2017 - 01:52 AM
Hi there,
A group of us from work have enrolled in an office competition where we put together a slot car and race it against other office teams.  We're all pretty excited about it, but unfortunately none of the people in my group have any experience building slot cars so we have no idea where to start. We're likely going to fabricate the shell of the car to match a fun theme, but we don't really know what basic parts to get (frame, tires, motor, etc...). We have a budget of around $175. Here's some event restrictions:
  • 1/24 Scale Car
  • 55' Track (1/4 mi Drag Race)
  • Max Size 9"L x 3.25"W x 3"H
  • Max Weight 12oz
  • Track Power: Input ac100-125v 60hz 100w. Output: dc18v 2x21 .6VA Amps: 30A across both lanes.
  • Track Guide Minimum 1/4"
  • Guide Rail and pickup assemblies: 1/24
An F1 frame is preferred as it best matches our theme, but anything will likely work. Any ideas to get the best bang for our buck?
Thanks in advance! :)
  • Mebrown likes this
#2 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,294 posts
Posted 15 May 2017 - 02:48 AM
Sounds like you're going to need something reasonably simple, if you just going to have a drag race comp.
There is a miriad of parts available from quite a few great suppliers.
Have you investigated to see if there is a commercial track in your area?
That would be a good place to start, as the track owner would be able to help with all your parts needs, and provide the technical knowhow to boot.
If there are no commercial tracks handy, check out Professor Motor, or PCH, (for starters) to get an idea of what to look for.
What does that $175 cover?  Each car, or the whole series??
:huh:
Steve King
#3 Samiam
  • 4,459 posts
Posted 15 May 2017 - 06:25 AM
Are Parma Edge cars still available? They would make a good start. Use Pro-Slot sealed S16-D motors. Best bang for the buck.  Then send everyone to Michael's or a similar store for a car model of their choice. They offer 40% off coupons. Their variety is a little limited though.
A spec tire and gear set will make things easier too. But you're going to need a local Pro to show how to set up the car. Things like gear mesh can be tricky.
#4 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,270 posts
Posted 15 May 2017 - 02:11 PM
Is this heads up racing, or bracket racing on the 1/24 scale quarter mile drag strip?
You should strive for a light car, and put a strong motor in it if you are heads-up racing.
  • Joe Mig likes this
Charlie McCullough
Charlie's Speed Shop
JK Hawk Horsepower Specialist
Bartos Chassis  CHR Cars
Outisight Bodies
Mossetti Racing
#5 Dave Crevie
  • 912 posts
Posted 15 May 2017 - 02:49 PM
Right, for drag racing the Parma Edge is the best for the price. A couple years ago I ordered four cars (through Mike Swiss) and got them very quickly, so I would guess they are still plentiful.
You can get them RTR with a 16D or Super 16D. All you need to do is tuning, and, after all, that is all that should be done in a spec series.
#6 Mattb
Mattb
  • 1,129 posts
Posted 15 May 2017 - 03:07 PM
Bear in mind aero is as important in 1/24 as in full size cars. A narrow and low body is real important if you are running heads-up.
  • CoastalAngler1 likes this
Vintage Cox Slot Cars
#7 Steve Lewis
Steve Lewis
  • 4 posts
Posted 15 May 2017 - 07:50 PM
Thanks for the suggestions everyone.  This is helpful to get us started.
This is heads up racing.
This covers the parts for my group's car.
This is the Los Angeles area.  I'll take a look.
#8 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,270 posts
Posted 15 May 2017 - 07:56 PM
Buena Park Raceway Rocks!
Go as lightweight as you can, and with as much motor and gears as you can get to hook up...Good Luck.
Can you buy a stock drag car ready to run and modify it?  (Parma Edge - chassis and body with axles, gears, guide flag and braid, etc)
Charlie McCullough
Outisight Bodies
Mossetti Racing
#9 Mike Patterson
    Village Luddite™
  • 2,070 posts
Posted 15 May 2017 - 09:35 PM
Where is the race being held? If it is being run at commercial raceway, I would tell you to call them or visit the track and check things out in person. They should be able to give you the best advice.
#10 Robert BG
Robert BG
  • 326 posts
Posted 15 May 2017 - 11:02 PM
I would definitely recommend visiting a raceway if possible before you start buying stuff.It will give you a much better start.Then once you've got some ideas,come back and we'll help you hash them out.
Although it's going to be a stretch on the budget I'd definitely try and go with a C can motor like a group 12 or 20 if you can.They truly fly and there's no replacement for HP in a heads up race ;)
You mentioned F-1 bodies so here's a link to a few that are available http://www.shoppscr..../formula-1-indy
Also here's a link to the Parma Edge kit mentioned earlier http://www.shoppscr....kit-P582K.htmlI
It's a little more then some of the other starter chassis.But it has everything minus the body and motor.
d
As far as motors go,skip the 16D and Super 16D's mentioned earlier.Yes they are cheap and great starter motors that do very well in bracket racing.dThing is you are racing heads up so you'll want as much power as possible anda group 20 is going to be tough to beat.Prices are all over the map but this Proslot sshould do the trick  http://www.shoppscr....bb-PS101BB.html
Or even better for your use and budget would be this one here http://www.shoppscr....motor-P456.html
Robert Fothergill
#11 Steve Lewis
Steve Lewis
  • 4 posts
Posted 15 May 2017 - 11:41 PM
The event organizer will be setting up the track at the office for the event.
d
Thanks for all the suggestions.  The faster, the better!
We might be able to check out BPR, thanks.  We can buy a stock car if needed.
#12 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,270 posts
Posted 16 May 2017 - 09:04 AM
After you get the chassis and motor figured out, tires and gears will make you win or lose.  Go to BPR and test that car - on the parma edge, I'd put .500 wide in the rear, and try gearing 14/52?  you'll also need glue and a glue board - go to BPR and they will dial you in - go there when they are racing drags, someone will help you with setup and testing.  Ask them for gear and tire recommendations too!
Also, go to the track you will race on after you get the car initially setup.  Test the car there so that you know the wheelie bar setting is good - track braid depth may change track to track, therefore adjusting the wheelie bar is necessary.  Ask for help - you'll get some.
Testing will also tell you what the car needs at the starting line (staging).  Adding lots of glue may or may not make the elapsed time go down...
Charlie McCullough
Outisight Bodies
Mossetti Racing
#13 Steve Deiters
Steve Deiters
  • 1,877 posts
Posted 16 May 2017 - 09:46 AM
Are your Steve Lewis formerly with PRI show?
#14 Joe Mig
Joe Mig
  • 2,938 posts
Posted 16 May 2017 - 10:39 AM
What are you getting for 175.00?
Are they supplying the parts and you have to build it from there?
Can you buy a car that is built or have someone build you the car?
#15 PCH Parts Express
PCH Parts Express
  • 2,122 posts
Posted 16 May 2017 - 03:08 PM
Edge cars are still on the market
Scott Salzberg
PCH Parts Express
#16 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,294 posts
Posted 16 May 2017 - 03:15 PM
Looks like plenty of good suggestions coming through.
Curious to know, is the proposed powere source going to handle the motors that have been suggested?
:huh:
Steve King
#17 Steve Lewis
Steve Lewis
  • 4 posts
Posted 16 May 2017 - 06:51 PM
Can you explain what you mean about gearing and 14/52?
Nope, not me.
We were not supplied with anything.  We can buy a stock car or build from parts.
:huh:
That is a good question.  We're currently looking at the ProSlot Sportsman 550 which was linked earlier.
Thanks all for the continued feedback, it's super helpful. :)
#18 slotbaker
slotbaker
    Dan Gurney Fan
  • 2,294 posts
Posted 16 May 2017 - 06:57 PM
Hope you're going to share some piccies with us, of what you ended up with.
Steve King
#19 Joe Mig
Joe Mig
  • 2,938 posts
Posted 16 May 2017 - 09:13 PM
I would hook up with someone that builds cars and have one built. Maybe a slipjoint dragster. 1/24th or 1/25th they are so close in size.
#20 Mattb
Mattb
  • 1,129 posts
Posted 16 May 2017 - 09:17 PM
I don't do any drag racing, so I may not have a clue about this stuff, but it looks like they would have been assigned a spec motor the same  and maybe even a spec frame.   Just a thought.
#21 Samiam
  • 4,459 posts
Posted 16 May 2017 - 09:32 PM
  That's what I thought. But it appears the only spec is $175.
  Is this retail $ or can parts be alternatively sourced ? I'll sell him a $25 C-Can set-up and he can stuff a H-Power smoke packed arm in it that will suck amps like Charlie Sheen snorting coke off a hooker's butt.
  • C. J. Bupgoo likes this
#22 Robert BG
Robert BG
  • 326 posts
Posted 17 May 2017 - 12:23 AM
I just noticed the power supply specs myself and I'm thinking a Group 12 might be a better choice then the 20 I recommended earlier.I'm going to ask a friend of mine who drag races to be sure.
Also Scott at PCH has used cars on his website.I dont know if there are dragsters but it might be worth a shot.You could also call Speedzone in NJ as I know they usually have a used RTR drag car or 2 in the case for sale too.
Robert Fothergill
#23 Mattb
Mattb
  • 1,129 posts
Posted 17 May 2017 - 08:06 AM
They might be going counter to the goal here if they just buy a car and don't create something as a team.
  • Samiam likes this
#24 Robert BG
Robert BG
  • 326 posts
Posted 17 May 2017 - 11:40 AM
Matt,I agree and the reason I mentioned the used cars was a source of cheap parts and as a working example to work/learn from.
Robert Fothergill
#25 CoastalAngler1
CoastalAngler1
    Outlaw Racer
  • 1,270 posts
Posted 17 May 2017 - 02:21 PM
I ran .640 with a 67 gram DRS C-10 chassis, and a lexan .10 thick 57 chevy body with a small downforce wing added - velociraptor bb motor!
(16.5 volts, 100 amp bulldog power supply per lane)  Cost of materials right at $175...but I had a pro build the car - Tem Raskin w Slot Car Drags Orlando.
It took a few times at the track to get the thing to hookup - finally got small hub .435 wide DRS tires that hooked w clear drag glue.  After about 20 of these fast times, the motor needed a re-fresh.
I have an 87 gram similar car with a gp 20 arm, vette pro mod lexan body w small downforce wing - she dials .875 sec.
Go as light as you can, and with as much motor as you can afford in your budget.
Spending some recon time at the track will be invaluable to your chances of winning.
Charlie McCullough
Outisight Bodies
Mossetti Racing
