Spur and pinion gears to build HO anglewinders?
8 replies to this topic
#1 brucefl
brucefl
  • 689 posts
Posted 21 May 2017 - 12:47 PM
I'm going to build anglewinders batman HO chassis, like the one in the photo so I need spur and pinion gears. Does anybody know where to get them?
Bruce Schwartz
#2 Tim Neja
  • 5,572 posts
Posted 21 May 2017 - 02:07 PM
Check with Dan Cronin - Viper Scale Racing.
#3 MSwiss
  • 19,689 posts
Posted 21 May 2017 - 02:17 PM
The big gravity HO proponent is Al Thurman.
He can be reached here as: chaparrAL.
#4 brucefl
brucefl
  • 689 posts
Posted 21 May 2017 - 03:41 PM
Thanks, Mike.
Bruce Schwartz
#5 Foamy
Foamy
  • 1,577 posts
Posted 22 May 2017 - 11:13 AM
Back in the day, I used T-Jet gears. Rear gear plate gear on the axle, ended up with Tyco 7 tooth gear for motor. This was with rewinds. 12-tooth T-Jet hope gear on stock motors.
Dennis Hill
#6 bbr
bbr
  • 1,373 posts
Posted 22 May 2017 - 12:16 PM
Is that "HO World" article written by Dale Flanigan?
Back in the days, he would come to our HO races with all his cars and stuff in a briefcase.
Mike Low
#7 Dennis David
Dennis David
  • 3,377 posts
Posted 22 May 2017 - 01:53 PM
Please post pictures of your progress.
Dennis David
#8 Pshoe64
Pshoe64
  • 130 posts
Posted 22 May 2017 - 02:10 PM
That is a later article when the column was written by Howard Kilgore. Dale had the column in earlier issues.
As for the spur gears, I also used the T-Jet brass gear with the smaller hole as a spur gear for angle or sidewinder HO builds. There are some nice 7 tooth brass pinions that came on the TCR can motors that mess well with the old T-Jet Idler gears. The nine tooth pinion from the 4-Gear/Specialty gear plate works well also and can give you some ratios to play with.
-Paul
Paul Shoemaker
#9 brucefl
brucefl
  • 689 posts
Posted 22 May 2017 - 07:21 PM
Well we'll see I'm waiting for a boat load of supplies,if that boat ever arrives and it's G ds will then the success of the mission is on track,pun intended,just as long as I SERVE the plan of the one above,and make the difference in some lives (positive influence )then I deem it a success,AMEN.
Bruce Schwartz
