FNRS chassis regulations and guidelines
8 replies to this topic
#1 Ralph Thorne
Ralph Thorne
  • 2,152 posts
Posted 12 July 2017 - 10:20 AM
In order to clarify our chassis manufacturing guidelines and create stability in the FNRS series, we have created the following guidelines which are effective immediately for all FNRS series classes.
The FNRS requires all chassis and its components to be commercially available. The retail price for a complete chassis must be USD$30.00 or less. The center section and pan(s) must be USD$15.00 each or less.
The chassis must have a minimum of two and maximum of three chassis parts. All chassis will consist of one solid center section and a maximum of two separate pans. Two-piece center sections are not allowed. The portion of the center section to which the motor is attached must be steel. The pans may be steel or aluminum. No homemade parts allowed.
The chassis blanks may be cut with a laser, EDM, water jet, mill, or die stamp. All axle uprights, motor brackets, guide tongues, body clip mounting holes, etc., must be formed by stamping of the center section and pan(s). Spring steel solder together type chassis are not allowed. Chassis may not exceed 83mm width at any point on the chassis.
The FNRS will approve chassis and chassis components for FNRS competition on a individual and yearly basis. Decisions will be made and announced by no later than July 1 for the upcoming calendar year. All chassis and chassis components will be approved at the discretion of the FNRS.
If any manufacturer who produces a current FNRS approved chassis or chassis components is found to be altering the chassis after the FNRS approval and/or found to not be supplying sufficient inventory, they will be subject to removal from the approved list.
Please note: At this time no new chassis or components can be made legal until January 2019. Any new chassis manufactured between July 12, 2017, and July 1, 2018, will be reviewed for legality for the 2019 FNRS Series.If approved, they will become FNRS approved on January 1, 2019.
  • Half Fast, Justin A. Porter, Matt Sheldon and 1 other like this
#2 glueside
glueside
  • 434 posts
Posted 16 July 2017 - 01:36 PM
Can you please point me to an updated set of rules?
Jeff Strause
#3 Ralph Thorne
Ralph Thorne
  • 2,152 posts
Posted 17 July 2017 - 09:16 AM
Jeff,
You can find all the updated rules in the "Notes" section on the Facebook page or just click HERE.
#4 Frankie Schaffier
Frankie Schaffier
  • 365 posts
Posted 17 July 2017 - 07:24 PM
Ralph,
It would be nice to have a set of rules that can be printed off, in word, Excel, etc.. That way tracks can print them off for handouts. I'd gladly type them up for you and send your way, then you can attach that to the facebook page. I don't know how to do the facebook attach thingy, plus I probably need super secret clearance.
Frankie
Rob Voska's only friend.
#5 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,631 posts
Posted 18 July 2017 - 12:34 PM
No need to type them; cut and paste: :)
FNRS CAR/CLASS SPECIFICATIONS Revised 7-17-17
STAMPED STEEL CHASSIS REGULATIONS
The FNRS requires all chassis and it's components to be commercially available. The retail price for a complete chassis must be $30.00 USD or less. The center section and pan(s) must be $15.00 USD each or less.
The chassis may have a minimum of two and maximum of three chassis parts. All chassis will consist of one solid center section and a maximum of two separate pans. Two piece center sections are not allowed. The portion of the center section to which the motor is attached must be steel. The pans may be steel or aluminum. No home made parts allowed.
The chassis blanks may be cut with a Laser, EDM, Water Jet, Mill, or Die Stamp. All axle uprights, motor brackets, guide tongues, body clip mounting holes, etc must be formed by stamping of the center section and pan(s). Spring steel solder together type chassis are not allowed. Chassis may not exceed 83 MM width at any point on the chassis.
The FNRS will approve chassis and chassis components for FNRS competition on a individual and yearly basis. Decisions will be made and announced by no later than July 1st for the upcoming calendar year. All chassis and chassis components will be approved at the discretion of the FNRS.
If any manufacturer who produces a current FNRS approved chassis or chassis components are found to be altering the chassis after the FNRS approval and/or found to not be supplying sufficient inventory.will be subject to removal off of the approved list.
*Please Note At this time no new chassis or components can be made legal until January 2019. Any new chassis manufactured between July 12, 2017 and July 1, 2018 will be reviewed for legality for the 2019 FNRS Series.If approved, they will become FNRS approved on Jan 1, 2019.
A) May use lightweight replacement pans and center sections.
B) May interchange parts from a single manufacturer; such as Flexi and Flexi--‐2 parts, JK long or short center sections, and heavy or light pans on JK, Champion, Parma, Mossetti chassis.
C) No modifications except for the following:
D) May solder or glue motor, axle oilites, and front wheel retainers.
E) May add lead weight and/or tape to chassis.
F) May file holes in motor bracket to allow better gear mesh, but must retain a portion of motor bracket.
G) No oilite modifications allowed. May use offset oilites. No Ball Bearings.
H) May add spacers between pan and center section.
I) May add a 1--‐inch (25.4 mm) long motor brace and a maximum of two upright braces (one for each upright).
J) The original manufacturer’s plating may be removed only in areas to be soldered.
K) May add pin tubes. Pin tubes must be in stock holes/location. Pin tubes may be either solid or floating. May add lead wire retainer.
L) May change stock bite bar diameter supplied by the MFG to a bar that is .062 maximum and .039 minimum diameter. The bar must be steel, straight, round, no bends, no flats and does not deviate from stock. May not solder bite bar to center section and/or pans.
M) Overall width maximum 83mm (3.268”)
N) May solder on steel guide tongue reinforcement but the original tongue may not be removed, modified, or moved.
O) No other--‐modifications, soldering, cutting grinding or bracing allowed.
P) May use any guide, nut, spacers, lead wire and clips. Only one guide flag per car.
Q) May perform reasonable filing of rear oilite chassis holes to allow for axle alignment.
R) On the Mossetti 1001, 1003, 1006, 1008, 2002, 2003, 2006, 2007, 2008, 2009, 2012, 2013, 2022, 2024, 2025, 2026 chassis…Must use either .062” dia brass tube or the M-1052 .064” stainless tube only. Must use push/body pins to retain the bar in the chassis. The MR-1051 Chassis Retaining Clip may be used and can not be modified or soldered to the chassis.
S) Front axles and front wheels are not required. If racer chooses to use front wheels the min. diameter is .500" o.d. Front axle minimum dia is .047" and max dia is .063". Front axle may be soldered to center section uprights.
T) On the JK C43 "A" chassis, front axles may not be added. Must use stock JK produced "J Bars" and sizes only. J Bars may not be soldered to the chassis.
MOTOR SPECIFICATIONS LMP & STOCK CAR Only the JK Hawk Retro long shaft motor and the JK Hawk Retro R7R7R7R7 with short shaft motors may be used at FNRS Events. May trim the pinion shaft. No trimming of shaft on endbell side of motor. No other modifications of/to motor allowed.
GTP Only the PS-4002 FK motor may be used. No modifications except for the following: Motors must be factory sealed and using the unmodified factory seal only.
Seals may have clear "finger nail polish" added to extend life of seal. NO other modifications to the seals allowed
Racers may change brushes and springs. Only 3 coil replacement springs are allowed. Any 36-D sized motor brushes may be used. Brushes may not be cut, slotted or modified on the surface touching the commutator. Brushes may be radiused prior to break in. No spring insulation or shunt wires are allowed.
Super Glue may be added to the endbell bushing. Can oilite bushing may be soldered in place.
Armature Shafts may be cut on both sides of the motor. Motors may NOT be rebuilt.
May use clip on type heat sinks or screw on type heat sinks that screw to the can on the pinion side of the motor. Comm coolers allowed. GEARS
All classes will use "spec" pinion sizes and will be 64 pitch only of any brand. LMP 10 tooth 64 pitch pinion only Stock Car 13 tooth 64 pitch pinion only GTP 11 tooth 64 pitch pinion only
Any size/brand 64 pitch PLASTIC ONLY spur gear may be used and gear must clear track by .047". No Metal Spur Gears allowed.
FNRS reserves the right to change the pinion specs based on different track size ( shorter or longer ), power/voltage, etc. If the pinion spec is to change for certain events, this will be announced in advance of the event.
REAR WHEELS/TIRES/AXLES Black rear tires/rubber only. No dyed tires allowed. No Speed Rubber allowed. Wheels/tires/rubber may not be wider than .815" max width. Max wheel dia is .625". Axles minimum 3/32" dia. Drill blanks allowed. No hollow, non steel or light weight axles allowed. Axle flats for gear/tire set screws allowed.
FRONT WHEELS/AXLES Front wheels and tires are optional and not required. If using front wheels: Min dia .500" o.d. with o-ring or rubber. Fronts do not have to touch the track surface. Front axle minimum dia is .047" and max dia is .063". Axle may be soldered to chassis front uprights. Axle must be one piece, solid and steel. Wheel retainers may be soldered.
CLEARANCE
Rear Clearance will be .047" minimum including the spur gear.
Clearance will be measured under the rear of the car, directly under the rear axle and between the rear wheels, with the car at rest on a flat tech block with the guide in the tech block slot. Clearance will be checked at the beginning of the race, with no check at the end. If a car is suspected to be dragging on the track during racing, the race director, at his discretion may check clearance.
Any car found to be dragging the track will be repaired during green flag racing conditions.
A mid race clearance check may be carried out by the tech director/race controller at the beginning of any heat of any race.
Any car found with rear clearance less than .039” inches at the beginning of any heat will have to change tires and have the clearance rechecked under green flag racing conditions.
BODIES
Bodies must be fully painted and opaque. Sides may be left clear in the body pin/clips area only. Must have three numbers. Must have suitably painted 1/24 scale (with head, helmet, shoulders, torso, arms and steering wheel) 3-D, vacuum formed lexan driver in the proper cockpit position. Chassis or track may not be visible when looking through windows. All windows must be clear. Bodies may have tape/lexan/mylar added for reinforcement. No additional air control/spoilers/diaplanes may be added. Body must completely cover chassis/tire when looking directly down on the car at tech except for the front chassis wings. Blade portion of guide flag may extend past the front bumper/nose of body. No braid, clips or top of guide may be visible. No cutting into the top surface of the body. The back of the body ( rear bumper/valance portion ) may be cut out/removed. No rear body height requirement in any class.
FNRS reserves the right to reject any body at tech that does not meet these requirements.
Front Wheel Area: Must use sticker fronts if no front wheels are used. If front wheels are used; front wheel openings must be cut out/open or left clear and 80% of the front wheels must be visible in the opening or clear area. No cutting into the top surface of the body.
LMP Bodies are to be either open or closed cockpit LMP or GT-1 type/style bodies with a "Stepped" type rear spoiler and are commercially available. FNRS reserves the right to reject any body at tech that does not meet these requirements.
Stock Car Bodies that are commercially available and 4" 1/24 scale style. COT bodies allowed. FNRS reserves the right to reject any body at tech that does not meet these requirements.
GTP Bodies that are commercially available are allowed. FNRS reserves the right to reject any body at tech that does not meet these requirements.
Cheers
PS: These should be posted in the Rules section of this blog
  • Hot Rod Huey likes this
Faster then, wiser now.
#6 Cheater
  • 25,821 posts
Posted 18 July 2017 - 01:11 PM
Before the rules were updated, there was a downloadable PDF of these rules in Slotblog's Rules Library.
I changed the FNRS entry there to show a link to the Facebook page the other day as, so far as I know, there isn't a PDF of the updated rules currently available.
#7 Ramcatlarry
  • 2,956 posts
Posted 18 July 2017 - 01:38 PM
"Approved parts", body, and frame list??
#8 glueside
glueside
  • 434 posts
Posted 18 July 2017 - 06:47 PM
Thank you!
Jeff Strause
#9 Kirbert
Kirbert
  • 13 posts
Posted 16 February 2021 - 04:19 AM
Please don't use Facebook as the place to post updates to the rules. Some of us have deleted our Facebook accounts and most definitely will not be creating new ones.
  • Pablo and dave burch like this
–  Kirby Palm
   Havana, FL
