New Chicagoland Group F chassis rusting issues
Posted 05 October 2017 - 04:56 AM
- Slot-Racer likes this
Posted 05 October 2017 - 06:25 AM
Scuff it off and spray a few coats on clear on it. I know Bud Bartos does that with his retro chassis to keep them looking good. Should work against rust or tarnish.
Dennis Dominey
Posted 05 October 2017 - 06:50 AM
Oil it.
Posted 05 October 2017 - 07:04 AM
All steel wing car chassis rust. Be sure and use some alcohol and swab it down after soldering in the motor. After racing take motor out and clean everything up. Just a normal thing.. no big deal.
- Rob Voska and glueside like this
Posted 05 October 2017 - 07:24 AM
After soldering in a motor, you need to swipe down the whole motor box area, from the fumes and splatter.
That said, the chassis has been a big hit, and the first batch has sold out.
The next batch will probably get plated, and of course, the price will be slightly higher.
Three cars from one of my local racers. Not perfect, but not awful.
- Lee Palmer and pmwslots like this
Posted 05 October 2017 - 07:30 AM
- Tim Neja likes this
Posted 05 October 2017 - 07:42 AM
Dennis David
Posted 05 October 2017 - 08:08 AM
Wash it with baking soda and water than put a coat of Gun Blue.
That worked for me.
Posted 05 October 2017 - 08:42 AM
Rust never sleeps......
- tonyp and C. J. Bupgoo like this
Posted 05 October 2017 - 09:13 AM
For soldering in motors, once I have tinned the motor and chassis I use a liquid rosin flux for all future motor installations. I bought a bottle on eBay and transferred it into an empty nail polish bottle with a brush in the head which I also got on eBay. That helps a bit with the rusting from soldereing in motors. It will also help on plated chassis where the acid flux can start eating away the plating. it is a must when soldering a motor in an aluminum plated chassis too. As far as rusting in general goes I use copious amounts of elbow grease. I was born with some and have yet to find the need to buy more. I would gladly pay more for a plated chassis. I have some old Koford plated EDM chassis that are 25 years old without corrosion.
Posted 05 October 2017 - 11:44 PM
I always scrub a blued steel frame in "barkeepers friend" before cutting the parts off the tree and soldering them together....and after soldering as well. Armature dye or nail polish also seals the bare steel, and shows cracks and rub areas.
racing around Chicago-land
Posted 06 October 2017 - 05:06 AM
Posted 06 October 2017 - 09:19 AM
Kofords are plated. I have some with a copper and maybe nickel? Some of the nickel has worn to show the copper underneath
Posted 09 October 2017 - 08:10 PM
#15
Posted 09 October 2017 - 08:26 PM
One word.... Ospho!
Gator Region Retro Racing Co-Director (2021-Present)
Posted 11 October 2017 - 05:42 PM
Soft Scrub with bleach and a Scotchbrite or stainless steel and or copper Brillo pad also work great. Using a wire wheel or steel wool will only create more rust.
- MSwiss likes this
Matt Sheldon
#17
Posted 11 October 2017 - 09:34 PM
This. Rosin flux is much less corrosive than acid flux.
#18
Posted 15 January 2018 - 04:25 PM
