Soooo, I was testing for an upcoming race(this past weekend, "Texas 2-Step" at Dallas Slot Cars).... my F-1 was working "OK" but not great. As the afternoon wore on and a number of offs accumulated, the handling deteriorated. A post-mortem revealed what you see in the pics. The marks on the lead shows where the arm shaft was hitting the lead as the chassis bowed under impact. Wow! That's at least a 1/8" bow of the chassis to do that! The impacts had also bent the main rails where they were soldered to the nose piece. Due to less-than-optimal construction techniques, the corrective action chosen was to grab the thing in both hands and bend it back. Qualified 9th(out of 15) and finished 4th overall(won the B-main).
How far will a chassis bow?
Posted 27 November 2017 - 11:43 AM
Posted 27 November 2017 - 12:00 PM
Rich, I've heard of a lot of excuses but this ones a real winner!
Seriously, it looks like the shaft hit the lead 5 or 6 times.......... First of all I cant believe you ran into the wall that often nor that you hit once and the chassis flexed 5 or 6 times?
Posted 27 November 2017 - 12:03 PM
Is your motor screwed or soldered in? You might think about stripping it down and heat the chassis up on a flat plate to "relax" the rails.
- Richard G With likes this
Posted 27 November 2017 - 12:38 PM
I didn't run into the wall(much) on race day.... this all happened the previous Sunday during testing/tuning.
Posted 27 November 2017 - 12:39 PM
The motor is both screwed AND soldered in. I'm not happy with the chassis anyway, so this will go in the old chassis bin as soon as I build a new one.
Posted 27 November 2017 - 12:59 PM
Unless I'm mistaken, it appears to be strictly a flex issue. I would think that reinforcing the rigidity around the motor would help. Maybe a short L-brace attached to the motor bracket and main rails? Of course, it could also affect handling, so it would require a little track time.
That's something I've never seen before. Amazing photos!
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
Posted 27 November 2017 - 01:25 PM
Have you tried manually bending the chassis to see if you can make the shaft hit the lead? Personally I cant imagine the chassis bending that much.
Posted 27 November 2017 - 05:44 PM
I'd like to see pics of the chassis to see what would allow that much movement
Posted 27 November 2017 - 06:34 PM
Broken chassis?
Mike Kravitz
Seems to me that the chassis itself would bottom out before it would be possible to bend far enough for that shaft to hit. (unless there were a broken solder joint like maybe one side of the bracket to the main rails)
Posted 27 November 2017 - 06:50 PM
How long is the WB?
I'm assuming the car is fairly soft, or long. I had an F1 car that I built super long at 4.25" WB for the Sano, in the bottom couple lanes at Mikes it would throw sparks because the car would bow and the motor would rub the track, and the motor didn't hang out the bottom when on the test block.
Posted 27 November 2017 - 06:54 PM
The car would "skate" and launch going over a "bridge" and hit quite hard, almost dead-on square; that's what was causing the bowing, NOT normal running. I guess I should said that before. LOL
Posted 27 November 2017 - 07:04 PM
scratch my theory then LOL
- tonyp likes this
Posted 27 November 2017 - 07:15 PM
#15
Posted 27 November 2017 - 07:22 PM
The hit marks are all over the place too. I think something is broken at the motor bracket..
#16
Posted 27 November 2017 - 07:31 PM
So you launched, hit the wall real hard, but didn't bother to check if you bent the chassis, and subsequently hit the wall another 4 or 5 times, and still didn't check the chassis?
- tonyp and Tim Neja like this
#17
Posted 27 November 2017 - 07:50 PM
- Tim Neja likes this
Posted 28 November 2017 - 07:20 AM
Well, I needed the trigger time regardless... you make it sound so.... so?..... unproductive. lol
- MSwiss and Racer36 like this
