How to build a Shinoda Lampray, old school method
12 replies to this topic
#1 Gene/ZR1
Gene/ZR1
  • 843 posts
Posted 01 December 2017 - 02:02 PM
ROUND NO.1
This how to is about how a thingie was originally constructed with basic tools, I have always built my cars this way. If you take your time you can build a really nice racer.
The chassis build will be a rear hinged ISO.
Lets get started.
 Shinoda Lampray
The tools shown here is what built this how to chassis.
This is the only part you need to purchase.
This motor bracket will accept more than one type of 16D's
Get a flat board
Take the Lampray body and a sharpie marker and mark the wheel base.
Starting to layout the chassis hands on jig, "1960's Style"
Take the square and mark the required wheel base.
Additional line work added,wheel base, chassis width, pickup guide hole location, chassis centerline.
Some additional lines will be added as we go.
Mark the hinge hole location as shown,
Use your hand drill and drill a 1\16" hole on each side.
Take a piece of 3\32" piano wire and bend to fit around the motor bracket. We will cut this later.
WILL CONTINUE, stand by.
gene\zr1
  • slotbaker, proptop, Pablo and 3 others like this
Gene Adams AKA Gene/ZR1
ZR1 Corvette owner
Genes_World@ymail.com
#2 Gene/ZR1
Gene/ZR1
  • 843 posts
Posted 01 December 2017 - 02:54 PM
ROUND NO.2 continue
Mark up the center guide section, make the pickup guide end piece and solder.
Center guide section, with the pickup guide end piece soldered together.
Motor bracket and pickup center section. place the pieces on the 1960's chassis jig and check for fit up.
Solder to piano wire side rails to center section as shown.
Notice that the back of motor location has been marked on the 1960's chassis jig.
Solder the purchased motor mount to the center section side rails. Use the 1960's chassis jig to locate the parts in the proper location.
Cut the 3\32 u-frame made in round one post as shown.
As shown cut a piece or brass tube and slip each piece of the u-frame and solder as shown.
I use a steel weight to hold pieces flat during solder and prevents burnt fingers.
Completed u-frame, Note the temporary brass spreader\spacer at the right end, to hold u-frame rails parallel.
END OF ROUND NO.2
gene\zr1
  • slotbaker, anglicanbeachparty, Jencar17 and 3 others like this
ZR1 Corvette owner
#3 Jairus
  • 10,174 posts
Posted 01 December 2017 - 03:17 PM
:clapping:  Go man GO!!!!
  • Maximo and miko like this
Jairus H. Watson
3/12/59-5/19/25
#4 Gene/ZR1
Gene/ZR1
  • 843 posts
Posted 01 December 2017 - 03:28 PM
ROUND NO.3
Starting to assemble u-frame side rails to carry the front axle.
Tack solder 1\16" brass rails for now. Use your chassis jig to locate parts.
Front axle assembly parts.
Tape 2 pieces of 1\16" brass rod to building board as shown. This will provide a 1\16" frame clearance.
Front axle tube assembly, tack solder in place as shown.
Finish the u-frame side rails to carry the front axle as shown.
Place the u-frame side rail axle frame in place as shown, should not bind to center section.
Cut 2 "L" pieces of piano wire and solder in place as shown.
Hinge view
Progress view
END OF ROUND NO.3
gene\zr1
  • slotbaker, proptop, anglicanbeachparty and 5 others like this
ZR1 Corvette owner
#5 Maximo
Maximo
  • 1,789 posts
Posted 01 December 2017 - 04:10 PM
Gene,
You are the Man!
You and Jairus and a few others post great How-To builds. Yours is awesome as it doesn't mandate an expensive chassis jig!
Go Gene Go!!!
MaximO
  • Old Pilot likes this
David Ray Siller
MAXImum MOtion
Thingies are my thingy!
#6 Gene/ZR1
Gene/ZR1
  • 843 posts
ROUND NO.4
Make a 1\16" U-bracket and solder in place as shown. This stops the center guide section from rising to high. NOTICE; the 1\32" "V" shape shim , this will allow the center guide section to rise  1\32".
 Completed U-bracket soldered in place.
Solder a piece of piano wire as shown, this prevents the completed motor center section from dropping.
Make 2 side pans as shown, use the chassis jig for sizing and fit up.
Square tube size.
Cut the square tube and slide into place and solder.
Slip a piece of piano thru the square brass tube, bend and solder as shown in the photo.
Make 2,  "z"-bends as shown.
Solder the  2,  "z"-bends in place as shown. These stops the side pan from rising.
Bottom of chassis view.
END OF ROUND NO.4
gene\zr1
  • Jairus, slotbaker, anglicanbeachparty and 6 others like this
ZR1 Corvette owner
#7 Gene/ZR1
Gene/ZR1
  • 843 posts
Posted 01 December 2017 - 04:35 PM
ROUND NO.5
Any of the motors as shown will screw to this bracket. Build the chassis, put in your motor of choice.
Completed chassis
Completed chassis
Approximate just the chassis cost including motor bracket  $9.00
This build is "Certus" powerd and it is going to the 2017 Shinoda Reunion December 16 2017.
No bells or whistles, just an easy common sense down to earth build, simple basic tools required.
This method can be modified to fit just about any body. Side pans  can be reconfigured to even fit a Shinoda Large Dart or others.
This is the way it was done in the 60's,  good luck and happy racing.
Body mounting post soon.
END OF ROUND NO.5
WILL CONTINUE with body soon.
"end of transmission"
gene\zr1
  • slotbaker, proptop, anglicanbeachparty and 12 others like this
ZR1 Corvette owner
#8 olescratch
olescratch
    olescratch
  • 979 posts
Posted 01 December 2017 - 04:38 PM
Gene making it all look easy.  How long does it usualy take for you to build a chassis like this?  Do you tumble your chassis once completed?
John Stewart
#9 Gene/ZR1
Gene/ZR1
  • 843 posts
Posted 01 December 2017 - 05:04 PM
John
Yes it is easy, give it a try. I only build old vintage style.
About 7 - 8 hours off-on taking my time,
No I do not tumble as I see no reason to. If I want bling I will wax my ZR1  :laugh2:
regards; g
  • Maximo and olescratch like this
ZR1 Corvette owner
#10 Pablo
  • 18,495 posts
Posted 01 December 2017 - 05:48 PM
Excellent tutorial :good:  :sun_bespectacled: :heart:
#11 The Sawdust Man
The Sawdust Man
  • 141 posts
Posted 02 December 2017 - 05:14 AM
Very nice job Gene!
Robert Manzitti
#12 anglicanbeachparty
anglicanbeachparty
  • 44 posts
Posted 03 December 2017 - 07:14 AM
Wow!  Great write-up, Gene!!
Paul Erlandson
#13 grooverunner
grooverunner
  • 157 posts
Posted 03 December 2017 - 09:44 AM
Thanks Gene !
Ken
Ken  Hill
