Hello,
First time Poster.
If anyone could help me out with this, would be most appreciative.
Know nothing about "slot cars, but an interesting subject.
Will enjoy learning about hobby.
Grandson has a two car slot racing setup received as a gift.
The hand Controller says:
Midwood Brands
Kidztech Toys
Made in China
And, on the battery pack it says:
Gear G Maxx
Slot Racing
1:43 Track
Have the following two questions, please:
a. The cars do work, and run around the track.
But, the headlights on one of the cars do not work. Other car's work fine.
Grandson is very disappointed, and am trying to help him out.
The lights are LED's which I've discovered after opening the car up.
All the wiring looks fine. Nothing obviously wrong.
When car is reversed in the slot, and the Controller activated, there is a momentary
blink of the lights. So, I guess it's reasonable to infer that the LED's
are probably O.K. (Cars are apparently designed to only run in one direction, I think; no reverse on Controller)
Any thoughts as to what might be the problem ? What should I check ?
What usually goes in this kind of setup: the diodes in the car, or...?
LED's in these type of cars only have two leads; correct ?
b. And, the conductive very fine wire "fuzz" that is mounted
on the car's bottom for electrically contacting the rails:
It's in bad shape, and I would like to replace.
Any idea where to get a few pieces of this "stuff" ?
Can't find anything suitable, anywhere.
Much thanks, appreciate any thoughts or help,
Bob
