CNC - Moldmaking tools
Posted 28 December 2017 - 10:30 PM
https://www.freemansupply.com/
https://youtu.be/p4HJAjS78Ms
Dennis David
Posted 29 December 2017 - 12:48 PM
It would be interesting to see. I believe that most molds for parts with complex curves (like slot car bodies) are done with EDM these days. Because this application does not anticipate 100,000 parts, aluminum is certainly the material of choice. (At one time, I worked for Bayer. Our division was the largest manufacturer of disposable plastic petri dishes in the world. Our largest machine was a 250 ton (clamping pressure) toggle machine with a 36 cavity mold - it was steel.
The opportunity that intrigues me is offered by progress (i.e. better, cheaper) in 3D scanning + 3D printing. You could take a model of any car and scan it to a file. The model scale wouldn't matter - the file can be resized. A 3D drafting program could then be used to define thickness and interior features - mounting posts etc. and the lot fed to a 3D printer.
An engineer friend (Jim Butt) and I rolled this around years ago. At the time the scanner + printer gear was at least $25K - a lot less now.
EM
Posted 29 December 2017 - 01:05 PM
Materials have really progressed Alan. Immense Miniatures sculpts a driver head/figure in clay, does a 3D Scan and then 3D prints in 1/32 and 1/24 Scale.
- MattD likes this
Dennis David
Posted 29 December 2017 - 01:21 PM
Dennis David
Posted 29 December 2017 - 03:54 PM
Amazing stuff, more power to you Dennis for trying to learn this new technology. I've got some of the Immense Minature stuff and it is really something. The Jim Clark driver head is Jim Clark!
Posted 29 December 2017 - 08:56 PM
Looking good to me! How can I get my hands on one of the Thingie bods in 1/24 scale?
Posted 29 December 2017 - 09:32 PM
Dennis David
Posted 30 December 2017 - 04:44 PM
More complex shapes require a 4th and 5th axis but can be milked or printed.
I get the X Y and Z axis, but what are the fourth and fifth axes?
Cheers
Faster then, wiser now.
Posted 30 December 2017 - 05:22 PM
- Half Fast likes this
Dennis David
Posted 30 December 2017 - 05:27 PM
Dennis David
Posted 07 January 2018 - 03:21 PM
Just curious... what program generates the g-code from the scan? Is g-code even used in these machines?
Most of the sufaces you see are made with ball endmills using *very* small step-overs on the finishing pass(es). Even then, polishing will be required although should be usable in most "hobby" purposes right out of the machine. The trick is keeping the most effiecient part of the ball in contact with the work... that's a lot of math!
Anything over 3-axis work requires a computer, the exception is simple rotary work with a 3-axis job, so, yes, a 5-axis machine requires matching CAD/CAM and the knowledge to use it.
#15
Posted 07 January 2018 - 05:29 PM
I will be using ESTLCam that creates g-code and use g-code sender to interface with the controller.
Other software is Meshcam, Mastercam and Solidcam.
Dennis David
#16
Posted 07 January 2018 - 05:37 PM
All early days and most maker type machines at this stage come with with their own Cad/Cam software. Thats the issue with machines from China. Youre on your own.
Does that make sense Phill? These are all computer controlled.
Dennis David
#17
Posted 07 January 2018 - 05:41 PM
Dennis David
