JK Products 2018 Outlook
35 replies to this topic
#1 JK Products
JK Products
  • 144 posts
Posted 04 January 2018 - 10:19 AM
This is an update for the things we are working on and launching in 2018.
(Note: The clickable links will not work in the above image of the PDF, but will work if you download the PDF below.)
Attached File  JKP 2018 Outlook.pdf   813.3KB   132 downloads
  • Cheater, Mark Wampler, havlicek and 5 others like this
Tim Homola
JK Products
#2 Samiam
  • 4,343 posts
Posted 04 January 2018 - 10:40 AM
Tim,
With the handicap system, is the delayed start on only the first heat or all?
In the IROC race, how are the cars positioned for next heat?
Will the tire truer be AC or DC?
#3 Pablo
  • 12,784 posts
Posted 04 January 2018 - 10:48 AM
How do you "rotate the brushes" on a sealed motor?
#4 Tom Thumb Hobbies
Tom Thumb Hobbies
  • 3,104 posts
Posted 04 January 2018 - 11:01 AM
My understanding, Paul, is have them rotated during manufacturing. In other words orient them the "correct" way instead of the way it has always been done by the Chinese.
  • Tom Eatherly and Lee Palmer like this
Mike McMasters
460 Wilson Rd
Columbus, OH 43204
(614) 274-5150
Home of the ORIGINAL American blue King
#5 JK Products
JK Products
  • 144 posts
Posted 04 January 2018 - 11:17 AM
Hi Sam,
Handicap countdown for all heats. I think we will probably move the new lane car to the last lane's track position. Planning to offer AC and DC.
Hi Pablo,
Mike is correct, motor redesign and new tooling.
Tim Homola
JK Products
#6 Pablo
  • 12,784 posts
Posted 04 January 2018 - 11:28 AM
Ohhh, I got it now.  :)
#7 Gary Pershall
Gary Pershall
  • 114 posts
Posted 04 January 2018 - 11:33 AM
Very interesting. Hope you can fix the current motor problems and concerns and keep on innovating to help the sport grow. The digital body printing looks really cool...
#8 Fast Freddie
Fast Freddie
  • 584 posts
Posted 04 January 2018 - 11:36 AM
Any lighter replacement steel or better aluminum pans for the Aeolos chassis coming? The current all steel chassis is heavier than your main competitors aluminum/steel chassis and the current aluminum pan is quite easily bent even though using it makes the Aeolos lighter the reliability in a race comes into question. Just wanted to know if anything was coming.
  • Wizard Of Iz likes this
Fred Younkin
#9 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 1,782 posts
Posted 04 January 2018 - 11:44 AM
Thanks for the update.
I saw the cold/slow hot/fast issue last Tuesday night at Port Jeff to the tune of more than 0.2 sec a lap faster when the motor was hot.
Cheers,
Faster then, wiser now
#10 Samiam
  • 4,343 posts
Posted 04 January 2018 - 11:48 AM
Cool...
RIP, Malcolm Young.
#11 JerseyJohn
  • 3,851 posts
Posted 04 January 2018 - 01:01 PM
Tim,
A lot of good things coming from JK.
A tire truer around $99 to 125 would be great.
Getting the brush arcs to match the commutator would almost be like the second coming!!!
Thank you again for supporting the hobby/sport.
JJ
  • SlowBeas, Steve Deiters, Tom Eatherly and 2 others like this
John Chas Molnar
Email me
#12 Wizard Of Iz
Wizard Of Iz
    Slot Parrothead
  • 1,414 posts
Posted 04 January 2018 - 05:10 PM
Amen!!! It’s s great chassis but I can’t afford the weight disadvantage.
More than one A Main driver has suggested to me that a lighter steel pan - perhaps .025" - would make the Aeolous a game changer.
As it is, I have disassembled my Aeolous chassis and have gone back to the X25/.025" combo.
  • Danny Zona likes this
Rollin Isbell
#13 JK Products
JK Products
  • 144 posts
Posted 04 January 2018 - 05:59 PM
Hi Fred,
We agree with your observations/criticisms and are working on it. When we tried higher strength aluminum pans, even with slow hydraulic pressing, we kept getting cracks on the uprights. I'll test some thinner center sections. Thanks for the input, Fred and Rollin.
I'd sure like to get the motor, Bill. Can you hook me up?
Tim
Tim Homola
JK Products
#14 gotboostedvr6
  • 1,239 posts
Posted 04 January 2018 - 07:41 PM
Thin pans are yesterday's news. A much much better option is to use the same thickness steel and reduce width of the sections much like what Mossetti did.
I'd like to see .045" or thicker flexis with very narrow rails and pans. They would be bulletproof.
Those who work for a living are being quickly overwhelmed by those who vote for a living.
Thomas Jefferson: "Paper is poverty. It is only the ghost of money, and not money itself."
-David Parrotta
#15 gotboostedvr6
  • 1,239 posts
Posted 04 January 2018 - 07:42 PM
I would caution rotating the brushes so that radius in the "correct" direction. If the brush is not in nearly perfect alignment with the comm many other problems will present.
  • NSwanberg, DOCinCocoa and Racer36 like this
-David Parrotta
#16 gotboostedvr6
  • 1,239 posts
Posted 04 January 2018 - 07:47 PM
Brushes produced with no radius would be a much safer option.
-David Parrotta
#17 Eddie Fleming
  • 867 posts
Posted 04 January 2018 - 08:18 PM
IMO flat-faced brushes would be worse than what we have now because of the amount of brush material that would need to be worn away to match the curvature of the comm.
#18 gotboostedvr6
  • 1,239 posts
Posted 04 January 2018 - 08:30 PM
As it is now you have way more material to wear through before the brush is seated.
Something that is not accounted for with the current orientation is the comm gets worn in a hourglass shape during the break-in process. This is absolutely not good for motor performance. If the brush was flat the comm would not get the hourglass shape.
-David Parrotta
#19 stemmy
stemmy
  • 1,011 posts
Posted 04 January 2018 - 10:31 PM
Need to fix the JK controller issues also.
Blair Stem
#20 The Sawdust Man
The Sawdust Man
  • 47 posts
Posted 05 January 2018 - 07:04 AM
Very happy to see that JK is working towards providing new products and is trying to fix old problems. I for one hope that 2018 is a great year for all of JK's product offerings!
  • Cheater, Wizard Of Iz, SlowBeas and 8 others like this
Robert Manzitti
#21 SlowBeas
SlowBeas
    Troublesome De-slotter
  • 815 posts
Posted 05 January 2018 - 11:51 AM
I agree wholeheartedly, Sawdust Man.
I was among the minority that was excited about JK's earlier efforts to offer direct pricing with commissions sent to raceways. Although that concept was abandoned, I think Tim continues to make attempts to please us racers while trying to grow his business.
IMHO, the only way we will continue to have products from which to choose is if someone (like Tim) has the guts to fix problems and change the current business model. If it were working well, we'd be seeing more suppliers – not fewer. I'm not smart enough to know what that model will be, but at least he's trying.
I hope 2018 brings much success to our cottage hobby, as well as suppliers and raceways. We need you.
  • Cheater, DOCinCocoa, Samiam and 6 others like this
Jim Beasley
South Carolina, USA
- Pat Paulsen, 1968
- Steven Wright ca. 1983
#22 Eddie Fleming
  • 867 posts
Posted 05 January 2018 - 11:59 AM
You nailed that one, Jim.
  • Cheater, SlowBeas and JK Products like this
#23 Fast Freddie
Fast Freddie
  • 584 posts
Posted 05 January 2018 - 12:18 PM
Thanks for taking a look at it Tim.  I think you would be best served by going with a .025 steel pan.  I say this mainly because of the design of the pan.  It would appear that the long outer legs (the ones touching the out riggers) of the pan are meant to allow some flex when the car is in the corner.  When racers tape the center and pans of this chassis I don't see them taping the outer legs only the inner legs and center.  One more thing, while aluminum flexes somewhat it usually doesn't return to it's original set, where as steel does.  It's not necessary that the chassis be lighter than the competition but just as light as the competition.  Taking away the weight advantage of the competition will go a long way in proving the actual viability of the design.  As Enzo Ferrari once said "weight is speed".
Fred Younkin
#24 gotboostedvr6
  • 1,239 posts
Posted 05 January 2018 - 12:48 PM
Not enough weight and g forces for the pans to "flex" with the current pans. They tilt and slide.
-David Parrotta
#25 The Sawdust Man
The Sawdust Man
  • 47 posts
Posted 05 January 2018 - 01:36 PM
I agree with all you said, Jim Beasley.
If it's true what many have said about the problems they have had in the unprofessional way they have been treated by JK, that is indeed a problem that Tim needs to address and fix.
But the last time I checked, we all bleed red, we all are humans, and we all makes mistakes. Perhaps Tim may feel in hindsight that he could have handled things in a better way, but that's not for me to judge. I will say that in the few dealings I've had with Tim he has been perfect! Totally professional. Completely fair, in fact went out the normal expectation of business protocol to take care of any problems I had.
And furthermore, just because he is having problems with one product in his line-up does not mean he shouldn't be working on other new and innovative products to allow his company to grow and prosper. I'm kinda amazed at some people who post they will never buy another JK product because of the whole motor issue. Jeez, if that's the way things work in this world, we all would be walking or riding horses again, as every manufacture of cars (ya know, Ford, GM VW, etc.) have had hundreds of recalls, or cars that explode when hit in the rear (remember the Ford Pinto problem?).
99% of the products I have purchased from JK are awesome. Keep up the good work, Tim!!
I do hope Tim finds and fixes the motor problem. And I personally know, respect, like, and consider my friends some of the people who have stated they have a problem dealing with Tim. I believe they are telling me the truth.
But life's a daily challenge. Pick your battles, people. Forgive, forget, and move on. I'm just grateful to be alive!
Regards,
Bob
  • Cheater, Gene/ZR1, SlowBeas and 1 other like this
Robert Manzitti
#26 Samiam
  • 4,343 posts
Posted 05 January 2018 - 05:52 PM
. .  As Enzo Ferrari once said "weight is speed".
A lot of brave drivers lost their lives due to that philosophy. But that won't be an issue here.
  • Jesse Gonzales likes this
#27 jimht
jimht
  • 1,195 posts
Posted 05 January 2018 - 07:16 PM
Note that as of when this was posted yesterday Tim has still  received only 2 motors for evaluation.
Considering all the video that has been posted showing motors with the 2 step flaw, this is surprising.
Are these racers so proud of their cheap useless broken motors that they won't send them back so Tim has actual examples (from the field) of defective product to show the manufacturer?
Not only that but one of the lesser lights in the industry claims on his Facebook page that this problem can only be solved by the manufacturer, but he doesn't feel that it's right for him to divulge the information even though this problem has supposedly been endemic to all the FK motors from day one, go figure.
We have met the enemy and he is us.
  • Cheater, SlowBeas, kvanpelt and 2 others like this
Jim Honeycutt
#28 Tim Neja
  • 5,483 posts
Posted 05 January 2018 - 07:25 PM
Geez people---IF you have motors that are demonstrating these problems SEND THEM IN!!  Help Tim help us!! I don't have any at the moment or I would!! If I find any in my preparations for the Check Point--I'll send them!  I see a LOT of the people commenting and complaining on various web sites are not even retro racers!!! They just want to get their two cents in on the keyboard!  I'm sure that Tim want's what we want--a simple motor he can sell thousands of that works for us!!
  • Cheater, SlowBeas, Samiam and 1 other like this
#29 Samiam
  • 4,343 posts
Posted 05 January 2018 - 08:04 PM
I said it before and I'll say it again now....
We know what and who this is really all about.
So does anyone know if the hoods on the new and improved 4002FKs are still being aligned by the blind?
#30 The Number of
The Number of
  • 1,396 posts
Posted 05 January 2018 - 10:07 PM
I bought 2 4002 FKs in the last week, 1 tied and 1 untied arm and both had properly aligned brush hoods, didn't have to get out my alignment tools.
Bill Fulmer
#31 havlicek
  • 9,385 posts
Posted 06 January 2018 - 08:47 AM
So, what we have here is news from a manufacturer about what's coming down the pike.  The same manufacturer comes here and responds to racers' concerns and wishes...continuing to innovate and cater to his market.  Boy, that happens all the time ( ;) )
  • Cheater, Wizard Of Iz, SlowBeas and 6 others like this
#32 Eddie Fleming
  • 867 posts
Posted 06 January 2018 - 08:54 AM
Amen
  • Cheater, SlowBeas and havlicek like this
#33 Bernard Powell
Bernard Powell
  • 80 posts
Posted 06 January 2018 - 09:16 AM
Wow I have to agree, this is a beautiful thing! As for a manufacturer JK is really really good he checked out a problem, and states that he's going to work with everyone who is willing to be a part of it to solve the situation! In this day in age of manufacturing is not caring it's a very novel approach.
And believe me with all the product that JK puts out that we all use, I think we owe them the benefit of the doubt!
Remember prosperity is not only in dollars, it is peace of mind with the things that we do to relax ourselves to get away from our everyday lives are Hobby and what it means to all of us.
  • Cheater, SlowBeas, Mattb and 3 others like this
#34 Shooter7mustang
Shooter7mustang
  • 70 posts
Posted 06 January 2018 - 12:18 PM
I for one am looking forward to an affordable automatic tire-truer and winning the lottery
Kevin Myhaver
Bad Dog Racing
Retro Racing
"Till the wheels fall off"
#35 Shiggy
Shiggy
    Green Hornet race director
  • 36 posts
Posted 11 January 2018 - 09:49 PM
I have returned two motors to Tim, along with a track test report I conducted. He has been very responsive. He did find issues with both motors.
  • JK Products likes this
D. "shiggy" Person
#36 Shiggy
Shiggy
  • 36 posts
Posted 11 January 2018 - 09:58 PM
You do not need to be a Retro racer to be encountering questionable motors. The Hawk 7 is also affected, and is the motor I have had issues with. We run LMP and 4-1/2" Vintage Stock Car (flexi) with the H7 as our spec motor.
Also run Retro CanAm where most use the Retro Hawk. I have yet to run a truly bad 7R yet.
Any suspect motors I get will be offered to Tim. I will have little use for them.
D. "shiggy" Person
