Help! Trying to fit tires/wheels
14 replies to this topic
#1 hiline2
hiline2
  • 468 posts
Posted 08 January 2018 - 10:12 PM
In my collection of "stuff"  I have these vintage wheels and tires and have no clue how they were fitted !
The brand is VECO, the tires are actually in very good shape and serviceable, the tires that had been on the wheels were dry rotted
and fragmented off.
Ive tried several ideas to fit the new tires and wheels together! i even have that tire tool with different size cones to slide over, for the life of me I cant NOT get those tires on the wheels,  ieven tried just straight compression of wheel/tire in vice but they would not pop on!
Do any of you Older Slotters have any idea ? I know I could go modern but these are still good so I want to try !
Paul Bass
#2 Jairus
  • 10,174 posts
Posted 08 January 2018 - 10:27 PM
Try warm soapy water.
Very soapy!
  • hiline2 and Pete L. like this
Jairus H. Watson
3/12/59-5/19/25
#3 Steve Okeefe
Steve Okeefe
  • 1,139 posts
Posted 08 January 2018 - 11:28 PM
I agree with Jairus; if there is any chance of getting those tires onto those wheels, very soapy water will help make it possible.
Steve Okeefe
#4 Rob Voska
Rob Voska
  • 1,133 posts
Posted 09 January 2018 - 07:09 AM
NAPA has something called Tire Rue.  Go to a tire shop & see if they will give you a dab of it.
#5 John Streisguth
John Streisguth
    Johnny VW
  • 5,638 posts
Posted 09 January 2018 - 07:12 AM
Here's a trick I learned working on mountain bikes, putting on handgrips....hairspray!  Acts as a lubricant when it's wet, then becomes an adhesive when it drys.
  • hiline2 likes this
"Whatever..."
#6 Lone Wolf
Lone Wolf
  • 2,740 posts
Posted 09 January 2018 - 08:33 AM
1. Trim some of the inner flash with an X-acto.
2. Soak the the tire in the hottest tap water you have for 1 minute, refresh the hot water and soak again. May take up to three times.
3. Chuck an old axle upright in a vise with the wheel on it. Leave the wheel about 1/2" above the jaws. Make sure axle does not protrude.
4. Remove tire immediately from hot water and apply some liquid dish soap to the inner bead.
5. Work over the wheel with your palm and fingers.
6. If this does not work throw them away  :laugh2:
Joe Lupo
#7 Steve Deiters
Steve Deiters
  • 2,317 posts
Posted 09 January 2018 - 09:04 AM
Veco tires on a slot car track.  Now that is retro mid-60's to the max!  I think we also called other brands of this type "German" tires.
  • Pete L. likes this
#8 hiline2
hiline2
  • 468 posts
Posted 09 January 2018 - 11:11 AM
Think I give this the best shot,   will let you know if it works !
I just like using the "old" stuff if it still has life in it !
Paul Bass
#9 Ramcatlarry
  • 2,956 posts
Posted 09 January 2018 - 11:51 AM
WD-40 works as well for hand grips and such.  I still have a set of set screw rims I made in the early 1960s for Veco tires.
NOS tires still dry out and have a loss of stretch.  I have used 'Brown aircraft tires' on some restorations - still foam, but fresher.
#10 Dennis David
Dennis David
  • 3,426 posts
Posted 09 January 2018 - 12:11 PM
Doesnt Ortmann have replacement tires? Check with Electric Dreams.
Dennis David
#11 hiline2
hiline2
  • 468 posts
Posted 09 January 2018 - 06:45 PM
the tires I have (in package still) are good just really hard to fit., It is just wanting to use these as the yare designed.
Paul Bass
#12 Ramcatlarry
  • 2,956 posts
Posted 09 January 2018 - 11:48 PM
Maybe soaking the donuts in a lanolin for a while will soften them up some.
#13 don.siegel
  • 5,890 posts
Posted 10 January 2018 - 12:38 PM
I like all these creative suggestions, but in fact on these Graupner "German sponge" tires, you had to grind out the inside a bit - they were originally for model airplane hubs and were never meant to be mounted on slot car wheels...
  • hiline2 and Jesse Gonzales like this
#14 olescratch
olescratch
    olescratch
  • 979 posts
Posted 10 January 2018 - 04:52 PM
EXACTLY!  That's the fun of scratchbuilding, taking things and using them where they may not have been designed to be use.  What motor is it that was designed for the automotive industry, but is now one of the most widely used in slots, fk comes to mind!
John Stewart
#15 Tom Katsanis
Tom Katsanis
  • 376 posts
Posted 10 January 2018 - 07:45 PM
Do you guys use lighter fluid for that over there down here we soak donuts in shellite (same as lighter fluid or white fuel over there) & I can squeeze this rim into that donut no worries without it it's nearly impossible.
I'm not sure if it works on the german sponge but I have soaked some & they expand.
Tom
