Racer sideways car help
5 replies to this topic
#1 Rick42
Rick42
  • 9 posts
Posted 12 January 2018 - 02:00 AM
Just bought 2 of the racer sideways cars. It has no bushings on the front axle. Has the adjustable front axle , that came with the tiny Allen wrench. So the screw on top and a screw on bottom is what holds the axle in place? Wont the screws rubbing against it eventually mess it up ? Also , should it be set ?
Rick Dennison
#2 bbr
bbr
  • 1,402 posts
Posted 12 January 2018 - 03:56 AM
Set it so front wheels support car evenly.
Oil the area where setscrew touchs axle.
You can also polish the ends of the setscrew so there's less friction.
Mike Low
#3 Ramcatlarry
  • 2,095 posts
Posted 12 January 2018 - 11:38 AM
Adjust the axle height so that the flag is almost touching the track pickup surface, pressing the car braid without the full car mass on it.
Host 2006 ISRA/USA
#4 Dennis David
Dennis David
  • 3,380 posts
Posted 12 January 2018 - 11:47 AM
You can get oval pointset screws from Slot Car Corner.
Dennis David
#5 Arne Saknussem
Arne Saknussem
  • 979 posts
Posted 12 January 2018 - 04:56 PM
Yes.
No, especially if you put a bit of oil or grease on as Mike suggested.
I run entirely on routed wood tracks and use the thin copper braids.  I set the front axle so that the guide is exactly the thickness of the braid above my set-up block.  This works at my club track where the braid and track surface are flush.  I space the guide for other tracks rather than reset the axles on different tracks with recessed braid.  No experience on plastic tracks or with magnet cars.
Enjoy!
Pete Varlan
"Whenever you find yourself on the side of the majority, it is time to pause and reflect."
#6 Ramcatlarry
  • 2,095 posts
Posted 12 January 2018 - 09:53 PM
On plastic track, the contact rails are raised above the deck.  Some flags on plastic cars can be adjusted with flag spacers the way commercial cars are adjusted.
Host 2006 ISRA/USA
