Hudy tire truer problem
28 replies to this topic
#1 Tex
  • 8,993 posts
Posted 26 January 2018 - 09:56 PM
I was truing up some tires for tomorrow's races aaaaaand.... the Hudy starts giving me trouble. Flip the switch... nothing. Flip it a few more times and it then worked. Fortunately, I was about done and was able to finish. I've heard of the switch itself getting gummed up with tire dust and creating issues, so I opened up the switch housing.... no tire dust buildup. I screwed the housing back on.... flip the switch.... nada. Beat on the unit lightly, flipped the switch a bunch of times.... finally ran again. But I'm not confident it will work next time I need it.
Suggested course of action? Thanks in advance.
#2 Kim Lander
Kim Lander
  • 427 posts
Posted 26 January 2018 - 11:07 PM
Sounds like the motor is the problem.
#3 MSwiss
  • 20,620 posts
Posted 26 January 2018 - 11:54 PM
Replace the switch, or hot wire around it, and use your power supply switch, to turn it on and off.
Manta Ray had the same problem with his Hudy
#4 JohnnySlotcar
JohnnySlotcar
  • 1,986 posts
Posted 27 January 2018 - 12:48 AM
I fixed Rays a few years ago. Switch was inundated with rubber dust on contacts.
  • MSwiss and S.O. Watt like this
John Austin
#5 Pappy
Pappy
  • 13,352 posts
Posted 27 January 2018 - 03:13 AM
Mine did the same thing so I took my switch completely out and use the power pack to start and stop it. It keeps you from accidentally leaving the power pack on all night.
  • Tim Neja, munter and Samiam like this
Jim "Butch" Dunaway
#6 Samiam
  • 4,660 posts
Posted 27 January 2018 - 06:20 AM
Good idea. Now just have to figure a way to stop leaving my soldering iron on all night. :dash2:
  • Pappy, munter and Frankie Schaffier like this
#7 Racer36
Racer36
  • 856 posts
Posted 27 January 2018 - 07:13 AM
Mine did the same thing a few years ago. The switch was defective.
  • S.O. Watt likes this
Dennis Dominey
#8 dalek
dalek
  • 355 posts
Posted 27 January 2018 - 09:32 AM
I put a piece of scotch tape on top of the rocker, creating a shield.
It should keep flying particles of rubber from entering the switch through the crack between the rocker and cover.
So far, so good -- the switch hasn't quit working again.
#9 Eddie Fleming
  • 1,200 posts
Posted 27 January 2018 - 09:44 AM
I have a lamp over my bench that is plugged into a power strip. I plug the soldering  iron into the same strip. I use the strip switch to turn the lamp on and off. so far so good.
#10 Steve Ritter
Steve Ritter
  • 29 posts
Posted 27 January 2018 - 12:07 PM
My switch is also going bad. Mine is only two months old. I just leave it in the on position and use the power supply to turn it on and off until I replace the switch.
Sent from my LGMS631 using Tapatalk
#11 Randy Tragni
Randy Tragni
  • 382 posts
Posted 27 January 2018 - 03:19 PM
Me too (just to add weight to how common the switch failure is on this product). I jumpered across the leads and use the power supply to control switching. Problem solved, but you can try removing the switch, blow, dry, compressed air across it and see if it comes back to life.
#12 Mark Wampler
Mark Wampler
  • 7,058 posts
Posted 27 January 2018 - 03:25 PM
I operate the Hudy from the power supply switch.
You can quote me.
-Mark
#13 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,111 posts
Posted 27 January 2018 - 05:07 PM
Proformance, an advertiser here sells replacement switches.
Cheers
Faster then, wiser now.
#14 Shiggy
Shiggy
    Green Hornet race director
  • 109 posts
Posted 27 January 2018 - 05:39 PM
Know issue.
Hit the switch with contact cleaner
D. "shiggy" Person
#15 Chris Barnes
Chris Barnes
  • 552 posts
Posted 27 January 2018 - 06:20 PM
Even though you cant see it there is tire dust in the switch. Try spraying it with Pure and see if that fixes it. After getting the switch working, cut a finger out of an elastic rubber glove and stretch it over the switch housing. That will prevent dust from getting inside it. The switch will still work. I have been doing this for a while with no problems
  • Mike K, triggerman, S.O. Watt and 6 others like this
#16 gotboostedvr6
  • 1,545 posts
Posted 27 January 2018 - 07:33 PM
Great idea Chris
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free. - Ronald Reagan #40 (1911 - 2004)
David Parrotta
#17 Bill from NH
  • 9,828 posts
Posted 27 January 2018 - 09:24 PM
Mine must be an older model, It doesn't have an off/on switch, just connect the ps leads direct to the truer's motor.
#18 crazyphysicsteacher
crazyphysicsteacher
  • 161 posts
Posted 29 January 2018 - 07:03 AM
I had the same problem. Cut the switch out and just wired up a higher amperage toggle switch. Now no problems at all.
Chris Wendel
Silver Side Down Racing
Silver Side Down Graphics
#19 swodem
swodem
  • 810 posts
Posted 04 February 2018 - 03:23 PM
Me too. Wired an in-line switch into the leads from the PS
Steve Meadows
#20 Tex
  • 8,993 posts
Posted 22 February 2018 - 12:41 PM
OK, so I'm back to truing tires today. No problemo for a while, then.... when I flip the switch, the motor starts up a little sluggish and then revs up to "normal". I'm thinking this is strictly a motor issue. Thoughts? Or could this still be a switch issue?
#21 MSwiss
  • 20,620 posts
Posted 22 February 2018 - 12:47 PM
Hook up the leads straight to the motor, and see if it still happens.
  • Tex and Robert BG like this
#22 Robert BG
Robert BG
  • 381 posts
Posted 22 February 2018 - 12:48 PM
I've seen that happen when tire dust gets into the motor and bearings etc.
  • Tex and Rob Voska like this
Robert Fothergill
#23 Tex
  • 8,993 posts
Posted 22 February 2018 - 01:37 PM
I'll try that(I know this was suggested before.... finally "listening").
#24 triggerman
triggerman
    Lurkaholic
  • 57 posts
Posted 22 February 2018 - 07:37 PM
I just replaced a switch for an east coast racer. His motor was exhibiting varying speeds depending on the pressure I applied to the rocker on the switch. Does your switch do the same?
#25 Tex
  • 8,993 posts
Posted 22 February 2018 - 09:51 PM
I hadn't noticed; I'll be truing tires again tomorrow... I'll check then. Thanks.
