Legendary (but never seen) Mabuchi FT46Q at Casa H-Power
13 replies to this topic
#1 havlicek
  • 10,572 posts
Posted 05 February 2018 - 01:00 PM
OK, I lied again.  :D  Anyway, I've said it before, but the Mabuchi one-piece can makes for a better motor (IMO) than the modern D-cans. I think that some more can be had from them by closing up the two rectangular holes.
Keeping that in mind, I decided to get busy and make a "best of both worlds" motor for drags or whatever other big-time performance applications are out there. So natch, the can got drilled for mounting and a bearing installed. It also got drilled to match the drilling on some D motor endbell I found in my "pile-o-stuff."
Speaking of the endbell, since the drillings are a match for the old Mura pattern holes, I used two of the stock bottom plates on each side, with a pair of Mura hoods. After installing a set of beefy modern D motor magnets, I'll be ready to build and wind an arm.
  • slotbaker, Jencar17, Tex and 4 others like this
#2 Eddie Fleming
  • 1,199 posts
Posted 05 February 2018 - 02:32 PM
It looks good.
#3 havlicek
  • 10,572 posts
Posted 05 February 2018 - 03:47 PM
Thanks, Eddie.
These make for great motors, I think this one will be a little "greater."
#4 olescratch
olescratch
    olescratch
  • 805 posts
Posted 06 February 2018 - 04:46 PM
Look's kinda "beefy" with the choice of hardware.
  • havlicek likes this
John Stewart
#5 havlicek
  • 10,572 posts
Posted 07 February 2018 - 07:54 AM
Yeah John, but the idea here isn't a "vintage style" (TM Steve Okeefe) thing or even just the updating of an old motor.  It's more about just making what I think is a "better" D motor.  These one piece cans are light and strong, and I think this one will make for a better field with the cross pieces.  Modern strong D motor magnets and a better end bell should complete the package.  Getting those cross pieces on there was more than a little of a PIA, and they're only "pretty much" straight ;) , but the function is more important than the beautiosity.  Last, of course, can drive and full sized brushes are "givens" for any modern motor.
#6 Eddie Fleming
  • 1,199 posts
Posted 07 February 2018 - 08:56 AM
With that BR Green it looks like it should be pushing an early Lotus of some kind.
#7 havlicek
  • 10,572 posts
Posted 07 February 2018 - 09:41 AM
Yeah Eddie.  I get the same thing with that green also...but then again, there's the Mura "Green Giant".  If I was better with a paint brush (*like WAY better), I'be tempted to do some pinstriping, but I ain't so I won't!  :D
Anyway, I'll press-up a stack later for this, and keep the airgap wide here.  I think a middle-of-the-road wind like a #28 or a #27 is the way to go with this one.  Either way, it should whistle pretty nicely. (*cue the Andy Griffith theme song)  ♪ ♫♪ ♪ ♫
#8 olescratch
olescratch
    olescratch
  • 805 posts
Posted 07 February 2018 - 02:39 PM
#27, would be staying in the "unique" character of this build IMO!  Or, it could come with both!!  In regards to the green, Mura was my 1st thought.
John Stewart
#9 havlicek
  • 10,572 posts
Posted 07 February 2018 - 05:00 PM
I'm kinda leaning that way myself John.  With a .518" arm in the chamber, the performance will skew more towards revs than torque, and such an arm WILL spin fast!
#10 havlicek
  • 10,572 posts
Posted 09 February 2018 - 04:49 PM
Okey dokey then.  I wound me up an arm for this bad boy...27/26...so shoot me.  :)  I "figgered" that a motor like this is a "go big or go home" situation, so I went big (wire that is!).  The force is strong with this one...or...this motor will kill!  :)
  • slotbaker, NSwanberg, boxerdog and 3 others like this
#11 old & gray
old & gray
  • 576 posts
Posted 09 February 2018 - 07:24 PM
Is that 27 turns of 26 OR a 27/26 double wind?
Bob Schlain
#12 bradblohm
bradblohm
  • 213 posts
Posted 09 February 2018 - 07:37 PM
Hey, my lights just dimmed...  John, did you just power it up?  Seriously, work of art!
Brad Blohm
#13 havlicek
  • 10,572 posts
Posted 10 February 2018 - 07:18 AM
Hi Bob,
     It's a #26 sgl.  27 Turns of #26awg, which is one turn more than I usually do 26/26.  Lately I've been adding the extra turn as I can get it on there without "shmooshing" the wire and still have a four layer coil.
:)  Thanks Brad.  Actually, #26 wire arms are a very cool option when the motor isn't stock.  Still being what I think of as "big wire", the #26 is sort of a chameleon wind generally speaking if you stick enough of it on there :)  In the right setup, it can be super fast and probably more likely to "finish the race" than a #25.  Guys who are careful about how they build a motor like Pablo, have used them in "similar" setups recreating early anglewinders with good results, and they're very fast...but a little "safer" than a #25.
This motor was never intended to be "vintage" or even "vintage style" (TM Steve Okeefe), just what I think is a "better 16D", so I wasn't constrained as to end bell or magnets, and is certainly up to the task of being appropriate for a #26.  So, some nutty "Thingie", more modern anglewinder, drag car etc. are all potential homes for it.
  • boxerdog, olescratch and Tom Katsanis like this
#14 havlicek
  • 10,572 posts
Posted 16 February 2018 - 03:40 PM
Got the arm back from grind/balance:
I was eager to get the motor assembled and dove in:
Firing this bad boy up was a beautiful thing.  I love it when things go right, because they don't always.  VERY fast, smooth and powerful, but not "stoopit" fast and powerful.  A "76" in this setup seems like it's actually almost "reasonable"...almost.  :D
  • Samiam, Eddie Fleming and Geary Carrier like this
