JK comm lathe drive belt / O-ring size
4 replies to this topic
#1 Phil Smith
Phil Smith
  • 3,582 posts
Posted 11 February 2018 - 10:15 PM
I dug a comm lathe out the other day. I didn't think I still had one, but it turns out I do!
No drive belt though. Anyone have any idea what size it needs?
Phil Smith
???-2/31/23
#2 Rob Voska
Rob Voska
  • 1,133 posts
Posted 11 February 2018 - 11:29 PM
Put an arm in it wrap a string around the pulley & arm stack.  Use a sharpie to put a dot on the string that transfers to the over lapping piece of string, stretch it out measure length & divide by 3.14.  Then go a little shorter as you want some tension.  Usually a good hardware store plumbing section has them.  Pulley is probably set up for 3/32 dia but no worries as they are less than $1 each.
#3 Ramcatlarry
  • 2,956 posts
Posted 11 February 2018 - 11:30 PM
I have a 3/32" X 1-3/16"OD with mine.  Anything close should work.
#4 airhead
airhead
  • 730 posts
Posted 12 February 2018 - 07:35 AM
Harbor freight sales a large box with about 20 different sizes, one will fit the drive on your  lathe, and some of the others can be used for front wheel O rings
Billy Watson
#5 Phil Smith
Phil Smith
  • 3,582 posts
Posted 12 February 2018 - 10:33 AM
Thanks gentlemen!
Phil Smith
???-2/31/23
