This is what I found in the bottom of a "Used 1/32 Parts Lot" box I recently purchased.
Did this come in kit form? It looks like a very interesting metal frame to tinker with.
As you can see, I did not clean the parts for the photos. That is the next step. I would like to build one.
I really like the technical details on the few pieces I now have.
Up to now I have worked on modern plastic frames, and classic WOMPs.
Back in the day, I used to fabricate 1/24 frames from brass tubes and solder.
Motor works very smoothly.
Can you recognize the frame manufacturer?
Many thanks,
Steelhat Hal
