Motor clip hack
17 replies to this topic
#1 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 21 February 2018 - 04:07 PM
Who out there doesn't like motor clips on your FK motors?  I for one until I had a dream, haha
Got some old  PS motors... you're in luck.  Take the screws from off the brush hoods and they tap right into those tiny holes on the FK terminals.   You need to drill a hole in your clip to run the screw, easy easy.
  • Pappy, Gary Pershall, NSwanberg and 2 others like this
Mark Wampler
?/?/1950-3/8/22
  • 14,992 posts
Posted 21 February 2018 - 06:14 PM
Aren't some or those screws torx heads or are they all?
#3 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 21 February 2018 - 06:24 PM
Very tiny Philips head !  I don't know about other brush hood screws.  These off the Speed FX work perf.
Mark Wampler
?/?/1950-3/8/22
#4 Pappy
Pappy
  • 14,161 posts
Posted 21 February 2018 - 08:27 PM
That's thinking out of the box, Mark. I like it.  :good:
  • Mark Wampler likes this
Jim "Butch" Dunaway
#5 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 21 February 2018 - 09:20 PM
This of course can be expanded to use a standard screw and nut.  The self tap screw from the PS motor doesn't fit especially tight, so you may want to put a tiny amount of loctite under the screw head before running it down.
Mark Wampler
?/?/1950-3/8/22
#6 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 21 February 2018 - 11:28 PM
Nothing for sale here, just a hack.  The screws  from a PS motor  are lightweight, fit existing holes in the terminals with no extra drilling to fit    If you can get pre-drilled clips, cheap, that would be the way to go.
Mark Wampler
?/?/1950-3/8/22
#7 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 22 February 2018 - 12:30 AM
Oops, got locked out.  Okay, here's my response:
1st of all the holes drilled in the clip should be on the tight side.  You will pre-run the screws in the clip to cut their own threads before you mount on the terminal.  Check for any burrs afterward. The hole in the terminal is just right as is.  Not to tight, not too loose.  When you cinch down the screws, they Will be secure.  So let racer decide as I'm sure they're looking on.  Free advice here, free screws from your old motors, but I think if Mike can provide pre-drilled clips that will allow the tap screw to pre-cut threads, that's where he can make a couple bucks.
If the self tap screws don't stand up, then standard thread screws and nuts will do the job.
A wire inserted sure may be easier and work okay, but again, it won't assure that the clip will not move around, vibrate  on the terminal.  Might be just fine for most applications.  I'm  sure going to be experimenting and welcome to see other racers results.
Mark Wampler
?/?/1950-3/8/22
#8 Samiam
  • 4,789 posts
Posted 22 February 2018 - 03:50 AM
Just mount a 2nd lead wire holder near the front of the motor. This prevents the wires from moving around and falling off.
#9 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 22 February 2018 - 09:30 AM
Its only 6:30 am. I'm waiting for Ace Hardware to open so I can get a drill bit.  I'm going to try a slightly oversize bit to drill the clips, If I have any here at all.  With the way these screws tap into the terminal, they're not too tight and not too loose.  I'm going to bet there's enough grip to hold clips secure without any movement.  That would be super easy.
Mark Wampler
?/?/1950-3/8/22
#10 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 24 February 2018 - 03:30 PM
This morning I took a small strip of  .032 brass and came up with this to make a pair  You will need to slightly enlarge the terminal holes so the screw will slip in and out easy.  Use a strong magnet tip screw driver.  The most tedious part is running the screw several times through the connector (clip) so when you mount it, there isn’t stress placed on the terminal.  While I'm drilling  the 1.02 mm hole in the connector, I twist it around to enlarge the hole to make threading the screw easier. I would take a few old motors and practice mounting and dismounting the connectors until you get a system.   The connectors mount under the terminal.  The hardware store may also have 1mm self tap screws.
  • miko and Alchemist like this
Mark Wampler
?/?/1950-3/8/22
#11 swodem
swodem
  • 1,176 posts
Posted 09 February 2019 - 01:50 PM
Why not just solder your wires?
  • Phil Beukema likes this
Steve Meadows
#12 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 09 February 2019 - 07:10 PM
I was wondering the exact same thing.  :unknw:
Rotor
  • Sean Mikuen likes this
Jeff Chambers
                                         "Kinky Kar"
#13 Bill from NH
  • 14,992 posts
Posted 09 February 2019 - 08:00 PM
Soldering works, some people like to keep as much external heat away from sealed motors as they possibly can. Some will even glue on pinions, rather than soldering them for the same reason. I solder on both.
#14 MSwiss
  • 26,012 posts
Posted 09 February 2019 - 08:29 PM
Some people think heat affects the tension on those little leaf springs.
#15 Ramcatlarry
  • 2,956 posts
Posted 09 February 2019 - 08:42 PM
I still like Mikes' push on terminals for the brush hardware to keep the soldering heat on the springs down.
  • Jesse Gonzales likes this
#16 Rotorranch
Rotorranch
    What's a title?
  • 1,755 posts
Posted 09 February 2019 - 09:20 PM
Crimp connector = current/ voltage loss.  Screw terminal = more current/voltage loss.
Why???  Makes no sense to me.
Rotor
Jeff Chambers
                                         "Kinky Kar"
#17 MSwiss
  • 26,012 posts
Posted 09 February 2019 - 09:53 PM
If you choose to race with this type of motor, you are free to connect the lead wires as you wish.
#18 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 10 February 2019 - 02:59 AM
One reason I like Thomas Edison.  He kept messing around  and messing around  and then the light went on.
  • Alchemist likes this
Mark Wampler
?/?/1950-3/8/22
