Redneck motor clips
7 replies to this topic
#1 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 22 February 2018 - 07:02 PM
Here's what I've done so far.  If you're going to use a fixed screw to attach the clip,  you can save some weight by making up your own clips.  Making the clip is fairly straight forward using an old braid.  I started off by drilling the starter hole in the clip with a 1.02 mm bit.  Then I threaded it through with the smallest screw (on the left side pic)  Clean off burrs as needed. On PS sealed motors, there are 2 different screws,  the middle screw is slightly larger in diameter.  The far right screw is from a Parma Death Star, too big for this purpose.  You will then solder on the lead wire, trim and cut the clip to size.
The screw goes in tight with the 1.02 mm hole.  Much tighter than the terminal hole.  I was able to use the larger screw after removing the smaller screw, but there isn't enough thick material on the terminal to securely hold the clip, unless you bore out the hole for a bigger size screw.  Not necessary  If you reverse the clip by placing it on the bottom and then run the (small) screw from the top,  there is enough grip in the clip to hold the clip securely.  That would the best approach, should be adequate.
If that seems to be inadequate, then a standard 1mm screw and nut combo will do the job
Mark Wampler
?/?/1950-3/8/22
#2 Brinkley47
Brinkley47
    A winner is a loser who gave it one more try
  • 857 posts
Posted 22 February 2018 - 07:04 PM
What are you trying to solve for with these clips?
Will Brinkley
willbrinkley@gmail.com
#3 Greg VanPeenen
Greg VanPeenen
  • 1,200 posts
Posted 22 February 2018 - 07:14 PM
No sure but I think they are trying not to put heat in the spring arms that hold the motor brushes. Mike Swiss sells push on clips and I saw somewhere on here where someone put a screw through them as sometimes they would come off in a crash. I use them for awhile then went back to soldering the wires on.
GVP
  • Thom likes this
Greg VanPeenen
12/4/49-4/17/24
#4 Mark Wampler
Mark Wampler
  • 7,206 posts
I tell myself there isn't any dumb questions.  I'll still believe that.  The main reason to do this  is to answer the main criticism of motor clips.  That being the weakness to stay secure.  Vibration, wrecks cause them to come loose and may  become dislodged.  The traditional clip uses a forced fit to attach.  Heat from soldering impacts the delicate brush arm tension to some extent, so that's the reason for motor clips.  By introducing a secure means to keep clips from vibrating on the terminal and tendency to dislodge, it answers the basic complaint I've already mentioned.
Mark Wampler
?/?/1950-3/8/22
#5 Brinkley47
Brinkley47
  • 857 posts
Posted 22 February 2018 - 07:17 PM
I have soldered wires on for years. No issues. I tested 32 motors in 90 minutes at Tom Thumb. Soldered wires on every motor.
  • Greg VanPeenen likes this
Will Brinkley
#6 Greg VanPeenen
Greg VanPeenen
  • 1,200 posts
Posted 22 February 2018 - 07:22 PM
Seems like a lot of B.S. to address a problem that already has a solution and that is putting a screw through Mike Swisses clip. That clip has been around for several years. But what the heck if you have a lot of time and like doing it yourself your solution looks like it would work just fine also. We have won a lot of big races over the years with soldered wires. Never had any issues.
GVP
Greg VanPeenen
12/4/49-4/17/24
#7 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 22 February 2018 - 07:23 PM
Another issue with soldering is how many times are terminals soldered and desolderd.  The motor gets plenty hot without a soldering iron add to its degradation.   Its a perception that several racers have.  I'm simply offering an alternative.  For those who solder, this thread isn't for you, but you might learn something if you hang around.
  • Jesse Gonzales likes this
Mark Wampler
?/?/1950-3/8/22
#8 Mark Wampler
Mark Wampler
  • 7,206 posts
Posted 22 February 2018 - 07:24 PM
GVP
Its about making your own clip.  Notice the title?
Mark Wampler
?/?/1950-3/8/22
