Brabham-Ford 1/24 1967 Grand Prix chassis
19 replies to this topic
#1 Pablo
  • 14,128 posts
Posted 02 March 2018 - 08:59 AM
My plan is to make a 1967 style brass rod chassis to custom fit the body.
Build it to fit a 16D Mabuchi type motor, then offer body and chassis for sale.
Owner would supply and assemble parts.
Body has determined to be a Lancer #218, but I have no way of knowing if it's a repop or original.
The Russkit bracket, I can vouch for as genuine :yes3:
Wheelbase 3 7/8", guide lead 5/8".
1/8 axles, rear wheels 7/8" X 5/8", fronts 7/8" X 3/16", widths 3"
Clearance 1/16 level
Drop arm will be designed for a Cox quickchange
  • Jencar17, MSwiss, Tex and 2 others like this
#2 Lone Wolf
Lone Wolf
  • 2,276 posts
Posted 02 March 2018 - 10:05 AM
Pablo, the color of that body is fantastic.
Although this is not the prettiest car in my stable, perhaps you can garner some ideas here. This one uses a 26D.
Be happy to supply more pics if you so desire.
  • Jencar17 and Geary Carrier like this
Joe Lupo
#3 Pablo
  • 14,128 posts
Posted 03 March 2018 - 07:56 PM
I've done this enough times, it's like riding a bike. No brag, just fact :D :crazy:
Jig wheels will be Russkit replica, Professor Motor part #'s R724 and R721.
You can see the beginnings of my rear axle tubing math -
with a pair of 1/16" plastic spacers, the empty space is 1.437".
Trivia FYI - bracket width of a genuine Russkit is .907" :wink2:
Nubs were removed, as I've never found any use for them in a pro type chassis like this.
Bracket was given a rough polish to remove 45 years of pixie dust.
Axle tube holes enlarged with a Uni-Bit to 5/16", as I plan to use vintage oilites.
This bracket only needed very minor correction to make it perfectly square.
I left the drill ridges intact just like Mike Steube recommended in his retro video :)
  • Jencar17 likes this
#4 Don Weaver
Don Weaver
  • 1,373 posts
Posted 03 March 2018 - 08:08 PM
"Nubs were removed, as I've never found any use for them in a pro type chassis like this."
Only use I've ever found for the "nubs" is to tell if it's a genuine Russkit bracket.
Don Weaver
L.H. Lapham
it will starve to death...
#5 Pablo
  • 14,128 posts
Posted 03 March 2018 - 10:39 PM
Good one, Don  :)
Inner 5/16" OD tubing piece was sized about 1.225" to allow for oilite widths plus "fudge factor".
Centered it up and minitorched it home with Koford Hi-Temp solder.
Math on the outer 7/32" OD tubes is critical - they will butt up against the outside of the bracket. Oilite lips are .03 each, X 2 = .06". 1.437" minus .06 = 1.377" tube width. 1.377" minus bracket width .907 = .470 / 2 = .235" tube extensions per side. It's easier to do the math than to explain it :big_boss:
The real trick is making perfect tube pieces to exacting tolerances using a drill, Dremel, sandpaper, and calipers  :umnik2:
  • Jencar17 and mike1972chev like this
#6 slotcarone
  • 3,437 posts
Posted 04 March 2018 - 08:31 AM
That looks like a vintage pre-painted body to me! :)
#7 dc-65x
  • 5,254 posts
Posted 04 March 2018 - 11:18 AM
Hi Pablo,
Looks like another fun project. :victory:
The real trick is making perfect tube pieces to exacting tolerances using a drill, Dremel, sandpaper, and calipers..........................
I have a small hobby lathe but I like making mine the same way with the drill - Dremel method. :dance3:
#8 Pablo
  • 14,128 posts
Posted 04 March 2018 - 07:57 PM
Thanks, gentlemen :)  Here is the braced bracket with new Champion oilites.
#9 Pablo
  • 14,128 posts
Posted 04 March 2018 - 10:13 PM
Centered and squared, ready for rails
  • Jencar17, miko and Bud Greene like this
#10 Pablo
  • 14,128 posts
Posted 05 March 2018 - 04:07 PM
One thing I've never been 100% satisfied with on pro-era Grand Prix chassis like this is,
the wheels are mandated to make the clearance 1/16 with wheels touching,
but I've always wanted my fronts to be elevated slightly to act as stabilizers, not rollers.
In other words, once I get the flag spacing where I want it to allow for braid recess,
the wheels are touching the track more than I want. Just personal preference.
So this time I simply raised both jig wheels with pieces of 15 thou brass
#11 Pablo
  • 14,128 posts
Posted 05 March 2018 - 09:13 PM
Rails and body mounts done
  • olescratch and Tom Katsanis like this
#12 dc-65x
  • 5,254 posts
Posted 05 March 2018 - 10:19 PM
:good:   :popcorm1:
#13 Pablo
  • 14,128 posts
Posted 07 March 2018 - 09:08 PM
Drop arm hinge - nothing really special here.
Tube against the hinge does triple duty as hinge buttress, extra body mounts, and outrigger strengthener
  • olescratch likes this
#14 Horsepower
Horsepower
    **Numb Thumbs**
  • 4,197 posts
Posted 07 March 2018 - 09:58 PM
Paul, that color IS beautiful! I believe it was AMT that put out a color rattle can called "Peacock metalflake" that looked just like that. Maybe Jairus would know for sure.
Gary Stelter
#15 Pablo
  • 14,128 posts
Posted 08 March 2018 - 09:44 PM
Yes, it is nice paint, Gary :)
If this drop arm chunk doesn't keep the flag planted in the slot, nothing will :aggressive: :curtsey:
#16 Pablo
  • 14,128 posts
Posted 09 March 2018 - 12:29 AM
Drop arm mini-torched to hinge and tubing upstop added
  • Samiam likes this
#17 Pablo
  • 14,128 posts
Posted 09 March 2018 - 06:32 PM
Flag tube quality control
#18 Pablo
  • 14,128 posts
Posted 09 March 2018 - 08:21 PM
My new method of raising the front wheels an additional 15 thou worked perfectly.
Mocking up the wheels/clearances/flag/braid to determine best flag limiter type and location proves it.
You can't tell from the photo so you'll just have to trust me  :D
#19 Pablo
  • 14,128 posts
Posted 10 March 2018 - 10:17 AM
Out of the tumbler
#20 Pablo
  • 14,128 posts
Posted 10 March 2018 - 10:19 AM
For sale in Swap Shop along with the Brabham-Ford body
