Cuca Pablo does it again
30 replies to this topic
#1 Asp
Asp
  • 72 posts
Posted 12 March 2018 - 02:22 AM
Pleased to report that CUCA Pablo  finished in second place at the vintage meeting in Roncole
against very stiff competition. First against Giovanni Montiglio, former world and italian champion.
  • Bud Greene, bluecars and mike1972chev like this
Luciano Luppi
#2 Pablo
  • 16,100 posts
Posted 12 March 2018 - 08:21 AM
:D I'll take silver any day  :D
#3 Pablo
  • 16,100 posts
Posted 14 February 2019 - 06:25 PM
"Mine Cucaracha", AKA "Luciano's Cuc" arrived back to the USA this morning for a tune up and some minor improvements after a series of overseas racing successes. I've always built my cars to run hard and this is the first time one of them has actually been run and raced to the point of needing service. So I am very honored to have it back for the opportunity to see what went "right" and what can be improved  :D
I don't have much time, as Luciano says she races again soon. So, my first priority was the motor. At a minimum, she needs the Havlicek arm serviced and checked. That needs to go out ASAP, and I can fiddle with the other stuff waiting for the arm to return.
Good news on the motor, not a single problem, the alignments are still perfect, the shaft is still perfectly straight, BB's and EB bushing still fine, brush track on comm looks fine, etc. All she needs is a cleanup, an arm service, and might as well zap the mags in can as long as we are sending stuff out.....
New Koford Big Foot brushes marked +/- and pre-radiused, arm gently cleaned with Dial liquid soap and a soft toothbrush, EB and can cleaned with lighter fluid, Q-tips, and pipe cleaners
  • Jencar17, Peter Horvath, Asp and 1 other like this
#4 Pablo
  • 16,100 posts
Posted 15 February 2019 - 06:26 PM
Arm is en-route to the Havlicek factory, new Ortmann knife-edge Cucaracha front tires are inbound from California, now it's time for a complete tear-down. Examine, clean, fix, improve :)
To my delight, I found out my JB Welded rear brace did not fail - it had to be removed to satisfy the rules. The same dollop of JB that secured the brace also secured the stock Cox roller bearings to the chassis. Once the brace was removed, it allowed hits to move the uprights which bound up the axle.
I'm proud to brag, the Pablo/Havlicek motor didn't fail, it soldiered onward and continued to produce podium finishes :good: Now the rules have been relaxed for a modified Cuc Class, allowing a brace. So I found some speed :D
Front axle/wheel assembly was undamaged, axle is still straight, all it needs is a cleaning and new tires.
My weight system came dislodged early on so I need to improve that
  • Jencar17 and Asp like this
#5 Pablo
  • 16,100 posts
Posted 15 February 2019 - 08:09 PM
The lead strip here indicates some chassis bending has occurred. In the Navy, we call this a "tattletale"
The new rules allow it, so I am soaking a pair of 1/8 ID sealed BB's in lighter fluid. The original Cox roller bearings will be retired
  • Jencar17 and Peter Horvath like this
#6 Bill from NH
  • 11,314 posts
Posted 15 February 2019 - 08:27 PM
A straight edge works too. I used a small surface plate to see high & low spots as well as the directions & where a chassis rocked.
#7 Pablo
  • 16,100 posts
Posted 16 February 2019 - 08:26 AM
I didn't mean the lead acts as a precise tool, other than simply giving evidence of bending.
#8 Pablo
  • 16,100 posts
Posted 16 February 2019 - 05:24 PM
Cox roller bearings removed, oiled and bagged for posterity. They are really sloppy. Maybe Luciano can use them for a future Cuc build that requires them stock. Front wheels cleaned and oiled, ready for Ortmanns
Chassis cleaned and flattened, easy day, it wasn't bad at all. The JB schwarf that refused to come off was left on and new JB will soon join it
-I saved the weights so I can use them as a pattern to make new ones
-Flag at some point got changed from a Jet Flag (.063 deck) to a cut down Parma "The Blade" (.038 deck). The Parma is a better racing choice but as long as we are using one, let's go to a standard deck (.063) instead of stacking a bunch of Koford spacers
-Genuine original Cox tapered axle was galled and bent really bad so I tagged it and cut a Koford to proper size
Every little problem I find gives me a jolt of happiness, because I'm finding speed :dance3:
#9 Asp
Asp
  • 72 posts
Posted 16 February 2019 - 06:05 PM
I'm really enjoying the way our Cuc is getting a new lease of life and back to its former glory.
I'm sorry that I had to ruin your original set up, but pleased that there is a new category for modified Cucs,
Thank you.
  • Pablo likes this
Luciano Luppi
#10 Pablo
  • 16,100 posts
Posted 16 February 2019 - 06:20 PM
Anything I build, I can fix :D
-Parma crown washed and inspected, zero damage, no noticeable wear.
-Stop limiter screws and nuts for the center section secured with Loctite 271
  • Jencar17 and mike1972chev like this
#11 Pablo
  • 16,100 posts
Posted 19 February 2019 - 10:01 AM
Modern new BB's with upright brace JB Welded in place. I know it ain't pretty. She's a race car now :)
Arm should be arriving at Havlicek's door today (yesterday was President's Day - no mail service).
  • Jencar17, Chris Stemman and olescratch like this
#12 Asp
Asp
  • 72 posts
Posted 19 February 2019 - 06:50 PM
She is not a shelf queen. She is there to cause problems.
Luciano Luppi
#13 Jaeger Team
Jaeger Team
  • 316 posts
Posted 20 February 2019 - 02:34 AM
(to Mr. Montiglio !?)
Maurizio Salerno
#14 Pablo
  • 16,100 posts
Posted 20 February 2019 - 09:21 AM
Arm is done, she is in perfect shape, a very minute correction for balance was all it took.
H Man gave you free labor, Luciano :dance3:
  • Asp likes this
#15 Asp
Asp
  • 72 posts
Posted 20 February 2019 - 05:27 PM
Hopefully, But it's not easy.
  • Pablo likes this
Luciano Luppi
#16 Pablo
  • 16,100 posts
Posted 20 February 2019 - 08:02 PM
To compensate for the use of a thinner flag deck than the stock Cox, I found Mylar spacers in the perfect size at local hardware store, 15 cents apiece. They are .032 thickness :good:
#17 Pablo
  • 16,100 posts
Posted 21 February 2019 - 10:59 AM
New lead pieces under shaft and on both sides of the pan are secured, same as originals, secured with CA
New form-fitted piece up front is same shape as before
But this time a Team Associated 7 gram iron weight is JB Welded to it, then JB Welded to the chassis. Forward end is secured via JB Weld with a cross connector lead strip
That's all the "permanent" weights for now. I still have a 7 gram lead chunk to install later if I want :)
  • Silver Fox and Peter Horvath like this
#18 Bill from NH
  • 11,314 posts
Posted 21 February 2019 - 05:42 PM
The "old-time" glue for lead weights on metal chassis was rubber cement. CA glue was available back then but would have been too expensive. Adhesion problems using rubber cement were few & none  if it was applied properly.
#19 tonyp
  • 14,960 posts
Posted 21 February 2019 - 05:57 PM
Contact cement. Rubber cement does not hold. At least none of the ones I ever tried.
1965 "Evil Bucks Racer" Team
Revtech Team Trinity
Retro East co-founder
First IM Nationals Champion
Arco Champion
ip
#20 Noose
Noose
  • 22,159 posts
Posted 21 February 2019 - 07:54 PM
ShooGoo!
#21 Pablo
  • 16,100 posts
Posted 22 February 2019 - 05:19 PM
Floppy sloppy body mounts re-done same as before
#22 Pablo
  • 16,100 posts
Posted 24 February 2019 - 11:33 AM
The car needed new fronts. Mounting a ball bearing 1/8 Cuc front wheel to a Hudy is a real chore, so I slipped both Orttmann's Cox knife-edge tires onto a modern 1/8 rim, same OD as the Cox wheel, and ground them to about .740" OD which gives the front end 1/32" clearance with the tires barely touching or slightly above the racing surface
Koford pre-cut big head pins bent and ready for action. Front wheels in place. JK hubs with natural rubber are working on Luciano's tracks, but they were worn down to about .805" OD and the car was riding too low in the rear. So I'll mount new JK D14 donuts
New 30T H & R crown, dyed black with Rit powder, salt, vinegar, and boiling Mississippi pure water :D
  • Peter Horvath, olescratch and mike1972chev like this
#23 Pablo
  • 16,100 posts
Posted 25 February 2019 - 04:20 PM
When is the last time your motor refurbisher actually took the time to hand-write notes on what he did to your arm? Havlicek rocks :good: :good: :good:
Motor re-assembly time........
  • C. J. Bupgoo likes this
#24 havlicek
Posted 25 February 2019 - 04:48 PM
Thanks Pablo, but I prefer more along the lines of classic rock :)
(if this works?) https://www.facebook...57142090983420/
#25 Pablo
  • 16,100 posts
Posted 25 February 2019 - 05:57 PM
:D See, I told you Havlicek rocks :D
Havlicek Cuc arm back into the setup - piece of cake. Power supply hooked up, click, instant rotation.
2 volts, so smooth it was a moot point. 3v, 1.06 amps. Steady for 5 minutes, 3v/1.0 amps. Dead cool temp and smooth as silk.
Then a rev test. No sparks, no heat, pure and smooth power. I know a happy motor when I see and feel it. Motor is done, even better than before :) Ready for battle
