Controller brakes
19 replies to this topic
#1 mark1
mark1
  • 88 posts
Posted 25 May 2018 - 06:44 PM
A few years back I read about a controller or a kit. This thing would make the brakes turn off on a track call (track power off). Ensured that the car would coast. I wish I would have printed that out to save it.
Anybody know about that?
Mark Anderson
#2 Half Fast
Half Fast
    Keeper Of Odd Knowledge
  • 2,129 posts
Posted 25 May 2018 - 06:47 PM
Brakes don't work at all when the power goes off with any controller and you can simply keep the trigger pulled to avoid going back to the brake band.
Cheers
Faster then, wiser now.
#3 slotcarone
  • 3,458 posts
Posted 25 May 2018 - 07:26 PM
Bill is right. Just hold the trigger down when the power goes off! Your car will coast. I have seen a few races decided by the coast.
#4 old & gray
old & gray
  • 590 posts
Posted 25 May 2018 - 07:30 PM
It should be simple enough to put a relay in the brake circuit; closed when power is on, open when power is off, but it seems like a lot of complication for little gain.
  • mark1 likes this
Bob Schlain
#5 mark1
mark1
  • 88 posts
Posted 25 May 2018 - 07:33 PM
True. Doesn't happen if you are on the brakes when the power is cut off, though. I read about the product and thought, so what. Now I'm racing oval, with a whole bunch of track calls. A guy could  get another lap with a device like that. A relay, maybe?
Mark Anderson
#6 mark1
mark1
  • 88 posts
Posted 25 May 2018 - 07:34 PM
Ha! posting at the same time Gray.
Mark Anderson
#7 Bill from NH
  • 9,937 posts
Posted 25 May 2018 - 08:28 PM
Don't some HO controllers have a coast feature/
#8 MSwiss
  • 20,822 posts
Posted 25 May 2018 - 09:52 PM
Like guys said, no power, no brakes.
When I do a track call, guys fall off all the time, in turns they hadn't been at all, because they lose their brakes.
What happens at a track call is totally predicated by what you were doing right before the power went off.
If you are full trigger on the straightaway, you coast a long distance, especially with an FK motor with short brushes.
If you are braking for a turn, just as the power goes off, no circuitry is going to negate the dynamic braking action that has already taken place.
(edit-above comment totally wrong on my part-apologies)
#9 smichslot
smichslot
  • 88 posts
Posted 26 May 2018 - 02:43 AM
Well,
some of you are dead wrong. My controllers have brakes even when the power goes off. In some classes it can be a death-penalty not to have brakes at track-calls.
And of course, in other classes coasting when the power is off can win you the race. And of course a modern controller should allow you to do that. I can name one.
Steen
  • CDavis7, NSwanberg, mark1 and 1 other like this
Steen Michaelsen
#10 Eddie Fleming
  • 1,241 posts
Posted 26 May 2018 - 07:16 AM
Any controller that does not have functioning brakes when the power goes off is not working properly or is poorly designed!
If you want no brakes hold the trigger down.
#11 mark1
mark1
  • 88 posts
Posted 26 May 2018 - 07:32 AM
I thought that when the wiper button is on the brake band, it shorts out the motor. Brakes. Makes no difference if track power is on or off? Most times I am on the throttle for track calls. Get a good roll. A few times, though, track call happens while I'm braking. Can't get back on the trigger fast enough. No roll. Win or lose a race by 2 feet and you think about that roll.
Mark Anderson
#12 Eddie Fleming
  • 1,241 posts
Posted 26 May 2018 - 08:07 AM
If you don't have brakes with power off, and you are charging into the deadman and power goes off just as you are hitting the brakes.
Your bent car can be put back on the track but how well does it run now?
That's not to mention every time you come off and the track call takes longer because you had no brakes and your car had to be put back on in addition to the the one that started the track call.
#13 drrufo
drrufo
    DR Racing Products
  • 288 posts
Posted 26 May 2018 - 10:18 AM
There is a racer that wanted me to put a push button on his controller to allow him to coast when there was a  track call. Never got around to it.
John Andersen
  • mark1 likes this
John Andersen
DR Racing Products
#14 mark1
mark1
  • 88 posts
Posted 26 May 2018 - 10:37 AM
Eddie, easy there buddy. It's roundy round racin'. The fastest guys run little to no brake.
Mark Anderson
#15 MSwiss
  • 20,822 posts
Posted 26 May 2018 - 11:19 AM
I stand corrected on this.
My super-dumb comment was based on an 11 hour day, hustling to the movies afterward, and exposed to, too many 7 year old racers who never hit the brakes.
  • NSwanberg and Dale B. like this
#16 mark1
mark1
  • 88 posts
Posted 26 May 2018 - 01:19 PM
Hey Mike, I feel your pain. I worked 7 days a week for over 20 years. After a while you don't know what day it is. Every day is Monday. Thanks to everybody for the input.
Mark Anderson
#17 Benno - SAC
Benno - SAC
    Beyond the Atlantic
  • 156 posts
Posted 27 May 2018 - 04:00 AM
Because of most of the reasons mentioned above, we recently changed our track wireing. We added relays, so that the two braids are shortened when the power is switched of. All cars will brake and do not hit any wall. No one will coast, with any type of controller.
Seems to me the solution most fair.
Schöne Grüße (Kind regards)
Benno Stolberg
www.SAC-Stolberg.de
#18 mark1
mark1
  • 88 posts
Posted 27 May 2018 - 12:25 PM
Benno, perfect solution.
Mark Anderson
#19 smichslot
smichslot
  • 88 posts
Posted 28 May 2018 - 09:18 AM
In order for a track in Denmark to be approved for hard-body-racing at a national Level the track will have to equipped with relays that prevent coasting when the power is off. It is preventing some crashing and is also preventing several changes in the race-results after the power has been turned off.
  • Mike K likes this
Steen Michaelsen
#20 gotboostedvr6
  • 1,571 posts
Posted 28 May 2018 - 06:17 PM
Guys with 3rd eye controllers have no brakes when power goes off.
David Parrotta
