I got given a very tired JK tire Truer this week. In pieces.
Actually I got given two. Well the second one wasn’t just for me -it’s working well and was donated by a racer from a nearby city for our Clubmembers use, but that’s another story. It’s working ok - just a coincidence.
The one I got in pieces was well flogged out. I rebuilt with new bearings and a good cleanup. I want it for occasional 2mm axle use rather than the 3/32 that’s used 99.9% of the time.
Sadly, I’ve found out my spare Hudy drum and 2mm tyre shaft don’t fit, the bearings have different spec. Hudy are 3x8x3 (mm) and JK are 1/8 x 5/16 x 1/8
So the shaft slops around - not very 'true'
A quick phone to the local hobby shops open today proved hopeless on replacement bearings, and I’m not even sure if I could shoehorn 8mm into a 5/16 hole anyway
So, then I had a 'Phenomenon' moment. Use the existing shaft, and just grind it down to size!
Out with the lathe, dremel and a grinding bit....voila!! Of course I did the 1/8th end so now can just swap it around and do 3/32....
Been a fruitful day in the end...
Now - where do I get a replacement motor for the JK from, this ones very noisy???
2mm shaft for JK truer
Posted 07 July 2018 - 04:18 AM
Steve Meadows
Posted 07 July 2018 - 05:45 AM
Check with a RC shop to see what they carry for motors or can order.
Posted 07 July 2018 - 05:50 AM
Yeah tried that Bill, all theirs are 50mm diameter. The JK is about 35mm
Steve Meadows
Posted 07 July 2018 - 06:41 AM
Posted 07 July 2018 - 07:15 AM
How much TIR in that chuck?
Not a chuck. Its a collet.
Runout is less than the difference between an axle hole and axle shaft.
Steve Meadows
Posted 07 July 2018 - 08:44 AM
Nice ingenuity on that set up!
Posted 07 July 2018 - 11:12 AM
Posted 07 July 2018 - 07:54 PM
This might work...
https://www.ebay.com...qcAAOSwOgdYwhmU
Y’know I have checked all the dimensions and they seem fine, just rotation is wrong way. I need CW when viewed from the can end. This one is CCW
Steve Meadows
Posted 07 July 2018 - 08:07 PM
Dennis Dominey
IRRA National Director
Posted 07 July 2018 - 08:25 PM
Steve Meadows
Posted 07 July 2018 - 08:31 PM
Cheers
Dennis Dominey
Posted 08 July 2018 - 09:22 AM
Posted 08 July 2018 - 10:21 AM
Hi Steve,
Send me an email and we should be able to help you out.
Tim
- Jesse Gonzales likes this
Tim Homola
JK Products
Posted 08 July 2018 - 03:41 PM
Adjustable timing?
https://www.ebay.com...5.c100005.m1851
Nice looking motor but it’s still CCW at can end. I need CW otherwise all the rubber dust gets thrown skywards.
Steve
Steve Meadows
#15
Posted 08 July 2018 - 08:41 PM
Steve,
I have a spare 12 volt motor that I bought from Jaycar as a replacement for my Hudy.
It is 35mm in diameter, has a .125" shaft, but runs CCW
When powered back to front, it still runs OK.
Want me to hold it for you for the Nats or is that too far away?
Ron
#16
Posted 09 July 2018 - 02:01 PM
Thanks man
Steve Meadows
#17
Posted 10 July 2018 - 08:56 PM
Zippity to the rescue!!!
(Man did I ever think I would say that!!??)
Thanks Zip!
- Zippity likes this
Steve Meadows
#18
Posted 10 July 2018 - 10:11 PM
Wonders never cease.
#19
Posted 12 July 2018 - 05:33 AM
Cheers Zip - fits perfect.
It ain’t fast....but it’s smooth and quiet and I don’t run high RPM anyway when doing rubber
Steve Meadows
#20
Posted 12 July 2018 - 07:28 AM
Nothing like a bit of Kiwi cooperation.....
Dennis Dominey
