Gear source?
5 replies to this topic
#1 Ecurie Martini
Ecurie Martini
    Ecurie Martini
  • 985 posts
Posted 23 July 2018 - 04:26 PM
I was just on the Sonic site and it appears that most of their line is "discontinued"  I am not familiar with some of the other gear sources that I have seen mentioned over the years.
Looking for a vendor/source for 64-80 DP pinion/spur sets for sidewinder application with 2.2:1 to 2.4:1 ratios - application:  very light 1/32 cars for a series limited to 14.5K motors.
Any suggestions?
EM
Alan Schwartz
#2 chaparrAL
chaparrAL
  • 4,256 posts
Posted 24 July 2018 - 12:17 AM
Google  Gizmoszone
They have 0.4 module gears  that are 64 pitch   and   0.3 module gears that I think are the same as 80 pitch.
Al Thurman
"Hold my stones". Keith Stone
My link
#3 MSwiss
  • 21,844 posts
Posted 24 July 2018 - 09:44 AM
You'll get an awesome gear mesh using a 64P ARP 15T pinion, with a JK 34 or 35T, 64P spur.
If it's a sidewinder application, go with a 6415 straight pinion, if a anglewinder, an angled 6415A pinion.
#4 Phil Hackett
  • 4,875 posts
  • Location:Was Silicon Beach Adjacent - Now the Playa District
Posted 24 July 2018 - 10:01 AM
Any suggestions?
EM
The website is extremely outdated and, yes, many things listed are not available. Not listed are 64p, 17-20t pinions (in stock), solder on (30-xx). They are intended for "Big Block" drag racing. We also have 44t drag crowns made of aluminum (231-44) and I believe there might be some 44t spurs (again aluminum) around. So, there's your 2.2:1 ration.... 44/22....
#5 MSwiss
  • 21,844 posts
Posted 24 July 2018 - 11:16 AM
Phil,
I think you meant 44/20.
Regardless, he's using these for 1/32 scale.
I have a feeling the 44 tooth spur would be way too big.
#6 Ecurie Martini
Ecurie Martini
    Ecurie Martini
  • 985 posts
Posted 24 July 2018 - 12:59 PM
Gentlemen:
Thank you for the advice and counsel.  It looks like I have several options including the 44t 64DP spur.  My gear dimension chart comes up with an OD of 18.25 mm.  The cars in question will be pre-1962 sports/racing carrying tires between 20.5 and 22 mm so gear clearance is not a problem.
I'll need to make a few measurements and run some numbers to make the choice.  In an effort to minimize weight, the motor can is part of the chassis with an axle carrier soldered directly so the motor shaft to axle dimension is critical.  The pitch diameter of a 44T 64 DP spur is 44/64 = 17.46 mm and the corresponding 20t pinion is 20/64 = 7.4 mm so the shaft/axle measurement will be 25.4 mm +/- allowing for clearance etc.  I believe that will work. (the 15/35 combination yields a center-to-center measurement of 19.8 mm - also a good figure.)
Last question - stocking dealers?
THX
EM
Alan Schwartz
