Set screw and tap size for Pro Track wheels
15 replies to this topic
#1 Dale B.
Dale B.
  • 1,742 posts
Posted 09 August 2018 - 08:14 PM
We run Protrack exclusively on our newer cars.   We (I build everything)   have the occaisional wheel that gets stripped.   The usual repair is to epoxy the wheel to the axle.   This works on our low powered cars, but is not the best fix.     Using the stripped hole as a guide it should be pretty easy to drill thru the other side of the hub and tap it and have fresh threads.
My question is what size are the threads.  Are these M2?    I've bought bags of screws, but don't remember the size.    I also wonder if there is a set screw that is slightly larger that would go in a stripped out hole and cut new, slightly larger threads for a slightly larger set screw.
Anybody with some info?
thanks
mb
Vintage Cox Slot Cars
#2 MSwiss
  • 20,900 posts
Posted 09 August 2018 - 08:30 PM
I'm 98% sure this is the container for the correct tap.
  • Steve Roope likes this
#3 Dale B.
Dale B.
  • 1,742 posts
Posted 09 August 2018 - 09:35 PM
Mike I've seen 4-40 listed, but I thought that was the size of the old machine screws Cox and Monogram used to mount bodies.  Is this 4-40 set screw size different than those old  body mount screws?
#4 MSwiss
  • 20,900 posts
Posted 09 August 2018 - 10:13 PM
You sure you aren't thinking of 5-40 on the body mounts?
4-40 is definitely what common gear and wheel set screws are.
I think you might be visually tricked because one screw has a head, and the other, a hole.
Here is a Parma controller bolt, in a regular slot car wheel.
#5 Bill from NH
  • 10,029 posts
Posted 09 August 2018 - 10:19 PM
I don't have Cox or Monogram body screws, but I'm sure most hubs & gears sold in US commercial raceways are the 4-40 Mike shows. Any Protrack hubs I've had were 4-40. The next larger size tap is a 5-40 which requires a #38 drill bit. A 5-40 screw is .013" larger than a 4-40 & might be easier to find. Personally, I'd prefer to keep everything 4-40.
#6 Tim Neja
  • 5,780 posts
Posted 09 August 2018 - 11:09 PM
The set screws are 4-40 and .050 size wrench.  Simple--- you can get everything you need at a decent hardware store --or McMaster Carr.
#7 Ramcatlarry
  • 2,241 posts
Posted 10 August 2018 - 07:46 AM
and many of the euro/plastic cars use a metric 2mm with the .o39 hex.
Host 2006 ISRA/USA Nats
#8 Courtney S
Courtney S
  • 105 posts
Posted 10 August 2018 - 07:51 AM
I have done this a few times due to my ham hands...
Use the original hole as a guide and drill through it to the other side then tap, it is simple.
Courtney Smith
#9 Pablo
  • 14,315 posts
Posted 10 August 2018 - 08:12 AM
Concur with drilling through existing hole to make new one with #43 drill bit, tap with 4-40, use standard set screw.
I used to do it all the time with Slot-It gears, it's easy.
#10 Dale B.
Dale B.
  • 1,742 posts
Posted 10 August 2018 - 08:29 AM
Thanks so much guys.     Quick and easy answer, I knew it would be.    I guess the visual difference between a set screw and a pan head screw (4-40) is enough for me to not realize they are the same threads.    It should be an easy process to fix the old wheels properly.    I'll order  a tap todayl
I do have a 5-40 tap for old wheels.  I also have used it on tapered hub Cox wheels.
Thanks to all
#11 Bill from NH
  • 10,029 posts
Posted 10 August 2018 - 08:58 AM
Aren't threaded axles also 5-40?
#12 Mike Patterson
    Village Luddite™
  • 2,189 posts
Posted 10 August 2018 - 09:30 AM
I would suggest filling the old threads with JB Weld, and retapping the existing hole. I have never done this on slot car wheels, but in every application I have tried it on, it has worked well. YMMV.
"You're not drunk if you can lie on the floor without holding on." - Dean Martin
#13 MSwiss
  • 20,900 posts
Posted 10 August 2018 - 10:24 AM
Yes.
That's why Matt is modifying taper-loc to 5-40.
That was a common thing at my local raceway, where Charlie Vrba, a retired machinist, would modify taper-loc(which local racers hated) Cox Sil Sliks, he had in stock, to the preferred 5-40.
#14 Bill from NH
  • 10,029 posts
Posted 10 August 2018 - 02:20 PM
Thanks, I missed that in Matt's post. The Cuc I bought in 1967 had the Cox tapered hubs. The first thing I did to it was install a French arm & change the rear tires to Cox silicones. I ran Champion taper-loc hubs a lot in 1967-68 & liked them. They even had taper-loc pinions.
#15 Dale B.
Dale B.
  • 1,742 posts
Posted 10 August 2018 - 04:33 PM
Mike, I am going to stay with the 4-40 threads, I just was't sure  what size  they are.  To change to 5-40 would be no issue, but it would require having two different sizes of set screws on hand.  I do have a 5-40 tap, but it only for  old threaded wheels  or for Cox tapered hub wheels that I want to use with threaded axles.
 I have 50 or so 4-40 set screws, so I'll just stay with that size.    I figured it would be pretty easy to use the stripped hole for the pilot hole to drill the other side.     I see that is how most  guys have "fixed" stripped wheels successfully.
I do appreciate the quick answers.   Always  easy to get answers here.
#16 Dan Miller
Dan Miller
  • 105 posts
Posted 12 August 2018 - 12:23 PM
Matt,
Do what Mike did and buy a quality HSS tap. The Cleveland brand is just fine for your use. Try for US or Japan made.
