Mounting LMP body for flat track
10 replies to this topic
#1 Ukulele
Ukulele
  • 3 posts
Posted 17 August 2018 - 02:05 AM
Question about mounting an LMP body for a flat track.
1. Should the body be mounted forward, middle, or rearward on a JK flexi chassis?
2. Should the body be mounted as low as possible on the chassis?
Regards,
Philip
Philip Perdue
Two home tracks - Buena Park Raceway and Motown Raceway.
Support your local tracks!
  • 10,302 posts
Posted 17 August 2018 - 05:54 AM
1.) Try each body position  on your particular track & see with which position your car is the fastest. I would tend to think rearward, but definitely track-test.
2.) Yes.
Disclaimer: I haven't had a flat track to run on since 2010.
:) Insect jokes bug me! :)
#3 Phil Beukema
Phil Beukema
  • 196 posts
Posted 17 August 2018 - 01:44 PM
I vote for Back and Low.
  • Tim Wood likes this
"Line 'em up!"
#4 W. J. Dougherty
W. J. Dougherty
  • 1,142 posts
Posted 17 August 2018 - 01:57 PM
When you say low, do you mean lower than the1 5/8 min? Just how high do you mount it in the back?
Yortuk & Georg Festrunk
#5 swodem
swodem
  • 886 posts
Posted 17 August 2018 - 03:51 PM
Depends on the track.
A shorter tighter twistier technical track, I would mount with the tail as high as possible.
Long tracks with long straights, lower is faster.
Also depends which body...
Steve Meadows
#6 swodem
swodem
  • 886 posts
Posted 18 August 2018 - 06:25 PM
I recently tested a variety of different LMP bodies using same chassis
Amazing the difference, and how some bodies perform better than others on different lanes
Some are more stable but not as fast, others are faster but deslot more especially on high speed corners under power.
Test and test...only way to find out. I could repeat at a different track and get a different result.
  • Tim Neja and Phil Beukema like this
Steve Meadows
#7 Shiggy
Shiggy
    Green Hornet race director
  • 143 posts
Posted 18 August 2018 - 06:31 PM
Test and test...only way to find out. I could repeat at a different track and get a different result.9810505d7efa116170e17ecf5474bfd9.jpg
What is body 4?
D. "shiggy" Person
#8 swodem
swodem
  • 886 posts
Posted 18 August 2018 - 06:34 PM
BPA Bentley K044
http://www.hobbiespl...044-p-1831.html
  • Shiggy likes this
Steve Meadows
#9 Tim Neja
  • 5,814 posts
Posted 19 August 2018 - 09:21 PM
I don't see a "Toyota" there??
#10 swodem
swodem
  • 886 posts
Posted 19 August 2018 - 09:28 PM
Jk?
No, don’t rate it. Better bodies have surpassed it
Steve Meadows
#11 Bazzie
Bazzie
  • 139 posts
Posted 02 October 2018 - 07:08 PM
If you deslot more under power in a corner it may mean that with the body in that position you have too much grip.
I’ve found that with the BPA Lola body (which seems to be the fastest at our Wellington track) I had to move it forward a bit to get it low enough to clear the ps4002fk at the back
Eben Brand
